Old 21-08-2005, 09:49 PM   #1
melbzetec
Old enough to know better
melbzetec's Avatar
Default Wet footwell
Well, this has to be the first problem I've had with the Focus. Water in the passenger side footwell.................and yes I know, it's probably the Pollen Filter. Apparently a common Focus problem.
I assume this is a dealer fix. Where exactly is the pollen filter anyhow? And can I fix it myself?
Old 21-08-2005, 11:44 PM   #2
Timmeh
Fairmont Ghia
Timmeh's Avatar
This photo of my car should give you a good idea of where it is. The plastic cover (that covers half the windscreen, you can see the drivers side one still in place) has a little channel in it (edit: on the underside) that should channel water down away from the filter - but the top of the plastic cover is supposed to be glued onto the windscreen as well, to keep water out. I assume the standard glue either isn't working, or the channel isn't drawing the water that does seep thru away.
When my windscreen was replaced, the cover was glued back on all the way across to avoid water ingress (and of course the channel on the underside to draw water away was still moulded into the plastic cover).
Hope that helps.
Tim
Timmeh is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 12:09 AM   #3
zetec
Zoom Zoom
zetec's Avatar
There's a TSB for it in service workshops, one of the earliest problems actually!
2012 Mazda3 MPS
Old 22-08-2005, 09:56 AM   #4
melbzetec
melbzetec's Avatar
Thanks Guys.
Old 22-08-2005, 05:05 PM   #5
Danny
GT4.
Danny's Avatar
Its actually allowing water in there is it??? Hope ya get it all sorted steve! The discomfort of wet feet do nothing for your heel and toe-ing ability!!!
Danny is offline   Reply With Quote Multi-Quote with this Post
Old 22-08-2005, 05:20 PM   #6
melbzetec
melbzetec's Avatar
Luckily, only on the passenger side Danny. I can still heel and toe to my hearts delight!!!!...And how much easier if I had the pedals on your fiery Fiesta!
Old 23-08-2005, 04:11 PM   #7
Danny
GT4.
Danny's Avatar
Hahaha well since you taught me how they work I've been practicing a bit, so next cruise will be interesting ;)
Hope ya get the water issues solved regardless mate, Cheers.
Old 23-08-2005, 09:33 PM   #8
melbzetec
melbzetec's Avatar
Yeh. Well just got a little letter from the Vicki Policki asking for a contribution of $131 following the cruise. I just didn't see that bloody grey Toyota HiLux early enough. Puts a bit of a "heel and toe" into the bank account!!
Here's a couple of articles on "heel and toe" technique
http://www.edmunds.com/ownership/how...2/article.html
http://www.waycoolinc.com/z3/essenti...e/shifting.htm
Old 24-08-2005, 12:06 AM   #9
zetec
Zoom Zoom
zetec's Avatar
The bastards. What speed were you doing, you naughty society-disrespecting criminal mastermind you...?
Hope I don't get one, although I think I'm cool. I was hanging back with xurbanx
2012 Mazda3 MPS
Old 24-08-2005, 09:57 AM   #10
whippet_zetec
Supes
whippet_zetec's Avatar
15km/h and under I take it?
Yes I DO drive a Toyota
whippet_zetec is offline   Reply With Quote Multi-Quote with this Post
Old 24-08-2005, 10:13 AM   #11
melbzetec
melbzetec's Avatar
87km/h in an 80 zone. Downhill.(Actual speed 92 or something like that)
I didn't think they were supposed to put speed cameras on downhill sections. Or is that wishful thinking?
