Old 09-12-2009, 05:57 PM   #31
melbzetec
Old enough to know better
melbzetec's Avatar
Thanks Eddie.
Yep, the Ford Racing head will be bolted onto the new shortblock
I've just bought a ported US 2000 intake manifold, which is a superior design in terms of flow to the stock one. So that will be going on
I love the Pipercross Viper, but there is no clean way to route the Cold Air intake pipe through the engine bay.
I have run it on the Dyno with just the short ram bellmouth, and it did what I'd thought it'd do....lost some midrange torque, but gained top end power.
So I'll use cold air intake for daily driving, bellmouth for show!
Manual 2003 Machine Silver 5 Door LR Focus Zetec.
Mods: Ford Racing CNC'd cylinder head milled .040", 3 angle valve grind. Ford Racing Stage II camshafts. Ford Racing cam gears. Ford Racing long tube header. Random Technology hi flow cat. Herrod 2.25" stainless cat-back. Pipercross Viper intake. CFM 65mm throttle body. 2000 ported intake manifold. Herrod Custom SCT tune. Eibach suspension. Quaife ATB diff. Wilwood 13" brakes. Custom ST170 leather interior.
www.cardomain.com/ride/2773918
melbzetec is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2009, 12:47 AM   #32
FOCUSonTHIS
FOCUSonTHIS's Avatar
Steve....I haven't been on the forums in a while and just read everything that has happened to your car. It's a shame it happened because it was going well and was looking the goods. Hopefully this new short motor will keep itself in shape for a lot longer than the orginal one does
2015 MK7 VW GOLF GTI
Previous Cars
2002 AUIII XR6
1995 EF Falcon XR6
2003 LR Focus Zetec
1989 KE Laser TX3
FOCUSonTHIS is offline   Reply With Quote Multi-Quote with this Post
Old 07-03-2010, 06:23 PM   #33
melbzetec
melbzetec's Avatar
Car is back.
Still some issues with battery and starting (supposed to be sorted...but not) but engine is very strong.
And Quaife LSD is BRILLIANT! Hard launches, or drive it HARD into a corner, and it just lays the power down.
More news when fully sorted
Old 08-03-2010, 10:37 AM   #34
Tj-zetec
Knows nothing. Apparently
Tj-zetec's Avatar
Fantastic news mate!!! (allthough a boat would probably be of more use down in M-town at the moment)
The kids over on the XR5 forums love their quaifes, but they are finding them to be putting a lot more wear on clutches and drive shafts, which are barely adequate in the 5 anyway.
A few guys have reported that it makes the back behave a little differently, but that may be a trait of Fwd with an LSD.
Anyway, best of luck with it mate!!
2008 Electric Orange LV XR5. With dreamscience strategem SCT, K&N 57i Gen2 cold air intake for more fun and demonic vaccum cleaner noise!!
1975 Mitsubishi/Chrysler GC Galant 2-door Hardtop. 4G63 DOHC heart transplant nearly complete!
Check out the build over here
Tj-zetec is offline   Reply With Quote Multi-Quote with this Post
Old 08-03-2010, 01:37 PM   #35
DZFord
DZFord's Avatar
It must be great haivng the car back. Where did you get the engine and LSD done?
Old 09-03-2010, 03:08 PM   #36
melbzetec
melbzetec's Avatar
Rob Herrod did the engine, and he got his "gearbox guy" to fit the LSD...don't know who that is!
Old 09-03-2010, 03:24 PM   #37
XR5-Boy
You mad, bro?
XR5-Boy's Avatar
excellent news Steve! I'm calling a meet! How's this sunday? lol
2009 LV Focus XR5 Turbo Performance Blue
SFS 2007 Best Cougar, SFS 2010/2011 Best Focus XR5
XR5-Boy is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2010, 04:10 PM   #38
Fled74
The Thread Killa
Fled74's Avatar
Good to hear you're back on track Steve.
"It is the mark of an educated mind to be able to entertain a thought without accepting it." - Aristotle
Fled74 is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2010, 05:51 PM   #39
Talldude
Talldude's Avatar
Good to hear that its alright now.
Do you know what power the motor develops now?
LR Zetec 3-Door black
With ST170 Suspension all round, ST170 Snorkel, K&N air filter, 2.0 Auto Air deflector, MSD Ignition coils and high amp leads. (In red adds at least 5bhp!) Also Under pulley kit. Refreshed ST170 wheels now!
Talldude is offline   Reply With Quote Multi-Quote with this Post
Old 09-03-2010, 07:01 PM   #40
Tj-zetec
Tj-zetec's Avatar
Good question. I wonder if the manifold will be enough to nudge it over the magic 100Kw mark?
Old 09-03-2010, 07:23 PM   #41
melbzetec
melbzetec's Avatar
I'm going to let the engine settle in for a while before testing it.
But I'm hoping to crack 100kW at the wheels.
Then no more engine mods!!!!
I also have a tune coming from the U.S. (one of Tom's Tunes for those that frequent the Focus Fanatics site..... probably the most experienced Focus tuner in the U.S.), so hopefully that will squeeze a bit more out of it. Rob is happy to do a back to back dyno run between the two tunes.
Mind you, it is back in the shop today....we've struck a problem with the starter motor which is draining the battery. I'd bought one from a wreckers but it didn't fit, and whilst the old one bench tested OK, it is obviously faulty.
Frustrating, but we'll get there.
Next (final ???) mods are:
Fitting an AEM wideband Air Fuel Ratio gauge....so we can datalog the air fuel ratio, allowing Tom to make final tweaks to his tune (gauge will be mounted in the glovebox cause it's ugly!)
Have Boston Acoustic speakers and JL amp fitted.
Get Wilwood brakes fitted (once I get the bloody hub nuts off the ST170 driveshafts to free the brake knuckles....god that nut is hard to shift!)
Then a couple of little cosmetic things......and then hopefully I'll just drive the bloody thing and stop breaking it
Old 09-03-2010, 09:01 PM   #42
DBourne
DBourne's Avatar
sounds good buddy!!
Didn't realise what had happened, but glad to see u have bounced back better than ever!
flickr
DBourne is offline   Reply With Quote Multi-Quote with this Post
Old 11-03-2010, 02:16 PM   #43
DZFord
DZFord's Avatar
Wise choice, I should have guessed!
I sometimes visit the Focus Fanatics site and I hear that the wideband A/F device is a worthy addition when undertaking more in-depth custom tuning. On the whole, I've read good things about Tom's tunes.
By the way, I can't wait to see some pics of the new brakes fitted on your car. Good luck with the stuck nut! (That sounds really wrong for some reason).
Old 19-03-2010, 12:17 AM   #44
photn
AFF Post NAZI
photn's Avatar
Hey steve,
Glad to hear/see the car is back up and on the road.
how are you going with the brakes? everything okay? if there is anything i can do or you need let me know..
If there are any parts you dont need let me know and if possible sent them back up to me (ill pay of course).
Sent ya a PM. let me know how you go.
Old 19-03-2010, 09:38 AM   #45
melbzetec
melbzetec's Avatar
Thanks Sean. Finally got the driveshaftfs out of the brake knuckles yesterday. Want to clean them up first before getting the brakes put in. It will be a few months yet, as the bank balance is pretty desolate after having to spend money on the engine
Old 30-03-2010, 08:59 PM   #46
20focus05
I wanna XR5
20focus05's Avatar
those driveshaft nuts can be really tight, we have had a car on the ground (tyre still on) with brakes on then 3/4 socket with breaker bar then a 2 meter tube on that, then jump on it.
But wow on the mods
Great Wall X240. Bouncing around the APY Lands
Ex Ford owner and member of this great site for ages.
South Australia, where the RIGHT hand lane is the NEW LEFT lane??????!!! %&#@*
20focus05 is offline   Reply With Quote Multi-Quote with this Post
