23-05-2011, 06:59 PM | #1 | ||
more of an alternator
hi all i have a ford au fairmont on gas it wont start after stopping at shops turns over but wont fire can hear solenoids clicking when putting ignition on. oil light water light petrol light and volts gauge all stay iluminated while turning over any ideas
23-05-2011, 07:02 PM | #2 | ||
meh.
Is it out of gear?
If it is out of gear, Try moving the shifter from P to N, then see if it will crank.. Just run it quickly from P to 1 then back again.. then try starting it in P and N If that works, then it's your inhibitor switch.. Cheap and easy part to replace..
Previous - BF XR6T - 325rwkw, 6 Speed Auto, Process West, X-Force and Turbosmart gear |
23-05-2011, 07:16 PM | #3 | ||
tried it it n and p no difference still turns over and wont the inhibitor switch stop it from cranking
23-05-2011, 07:42 PM | #4 | ||
is it an egas, or has it had an aftermarket gas conversion?
23-05-2011, 08:10 PM | #5 | ||
its aftermarket
23-05-2011, 08:16 PM | #6 | ||
dont all the dash lights usually go off when turning over the fuel light is staying on even though the gauge is reading 3/4 full
23-05-2011, 08:40 PM | #7 | ||
any other symptoms , has it been running well prior to this?
23-05-2011, 08:44 PM | #8 | ||
car has been fine wife said she jumped in tried to start it went to fire then stopped now just cranks over
24-05-2011, 01:23 PM | #9 | ||
Since the conversion, is it now only able to run on gas...
If so, does it automatically switch to petrol for starting... If you can switch to petrol, do so and try that... Cheers... |
26-05-2011, 10:30 PM | #10 | ||
got fuel in it? not uncommon for people to overlook stuff, i had a lady once ask for help with a flat battery, after dragging a booster battery and jumper leads 200 metres to her car, the woman had forgotten to put the tbar into park
26-05-2011, 11:47 PM | #11 | ||
not here much anymore
Has the interior light fuse blown?
RAM 1500
