Old 18-09-2011, 07:46 PM   #1
XpV8
Default 2009 interior light or lack of?
Howdy
We have a 2009 focus hatch . Just wondering anyone noticed how little light the front interior light pumps out? Is a front only interior light standard these days ? Very annoying trying to strap the little one in at night time!
So thats my whinge, just wondering is it straight forward hooking an after market one in the centre and has anyone done it?
XpV8 is offline   Reply With Quote Multi-Quote with this Post
Old 18-09-2011, 07:51 PM   #2
MAGPIE
MAGPIE's Avatar
Default Re: 2009 interior light or lack of?
Try a LED replacement for the OEM bulb first, it will make a difference (whether it is enough is another matter).
MAGPIE is offline   Reply With Quote Multi-Quote with this Post
Old 19-09-2011, 12:07 AM   #3
XpV8
Good idea I'll start with that
Thanks!
Old 19-09-2011, 07:58 AM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
I don't mind the front light, it's the rear that really annoys me actually. No light at all. At night you open the rear doors to get something and it's pitch black.
Cost cutting.... I want to look into getting some LED fittings for each side of the rear wired into the front lights but want it to look neat.
At least you have the option of putting brighter lights in a fitting that's there!
Old 20-09-2011, 01:17 AM   #5
rand0mn00b
yep the front light is next to useless for the front, don't even mention the rear
one of my main gripes with the Focus
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 02:32 PM   #6
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: This member has made a few valuable contributions to the Forum in the Focus section, seems to know exactly what he is talking about with his posts, which are helpful and concise.
Originally Posted by XpV8
Howdy
I did this to mine:
Bought a secondhand light assembly from the UK (same as the one used in the front) and put a LED globe in there. Works a treat.
2006 LX FOCUS SEDAN
Titanium Grey, factory bodykit, slightly debadged
CSA Motorvatr 17's/Kumho KU31's, Eibach Prokit/Lovells rear springs, Koni Sports Kit
Lower airbox removed, K&N Panel filter
Momo gear knob + boot + pedals, Ghia boot garnish, Zetec Chrome interior door handles
JVC KW-XR816 Headunit + more to come...
#Russ#Es# is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 04:15 PM   #7
Russ
Russ's Avatar
Contributor: For members who make a contribution worthy of recognition. - Issue reason: Very helpful and gracious with photoshop work to help others..
Originally Posted by #Russ#Es#
I did this to mine:
Looks tidy mate, where did you source the power from ?
Russ is offline   Reply With Quote Multi-Quote with this Post
Old 20-09-2011, 04:43 PM   #8
Yellow_Festiva
Where to next??
Curious to know that as well. One of the main reasons I haven't bothered doing it as yet.
Does the boot light illuminate with the doors I wonder? Perhaps that's an option?
Old 20-09-2011, 06:05 PM   #9
Russ
Russ's Avatar
It probably does, I wouldn't particularly want to pull the hood lining down just to wire it up, seen it done before and it never sits the same
Old 20-09-2011, 06:19 PM   #10
Franco Cozzo
Thailand Specials
Franco Cozzo's Avatar
Not to mention, touch it once.
BLACK MARKS, EVERYWHERE!
Old 20-09-2011, 07:17 PM   #11
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
I did it a while ago, but pretty sure I ran it from the drivers door. Had to run a wire above the roof lining. I didn't actually use the complete surround - see shot below (NB. every time I look at the pic it seems like the fitting isn't installed straight, but it definitely is!):
I have toyed with idea of fitting the surrounding trim but need to look at how to make it work - unfortunately the trim has a slight curve to it that's different to the curve of the roof lining.
2006 LX FOCUS SEDAN
Old 20-09-2011, 07:23 PM   #12
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
Sorry for the off topic link, but for anyone looking for better light in the boot I can vouch for this: 12VDC Flexible 21 LED Lgihts White
Have used one in my sedan for 4+ years and no problems at all, every LED still works perfectly (despite being on firmer suspension).
2006 LX FOCUS SEDAN
Old 20-09-2011, 08:01 PM   #13
Russ
Russ's Avatar
I guess another option would be to just stick one of those LED push lights onto an easy to access plastic section somewhere in the back, they last for ages, I have a couple of them stuck outside on my verandah, rather than having to chuck on the big light at night and encourage 20 million moths into the house, I just press on an LED. Just took a quick snap on my phone
Old 20-09-2011, 10:13 PM   #14
casabonka
You can call me Chris
casabonka's Avatar
out of 10 whats the degree in difficulty in installing that second light?
'06 LS Focus Hatch
-2 1/4" Lukey Exhaust
-RDA Slotted discs/Greenstuff pads
-Rear Whiteline swaybay
-Lenso 18's w/Kumho rubber
-Tinted Windows
casabonka is offline   Reply With Quote Multi-Quote with this Post
Old 21-09-2011, 04:58 PM   #15
XpV8
I did this to mine:
that looks great, where was your entry point to run the wire inside the hood lining from?
cheers
Old 21-09-2011, 08:20 PM   #16
#Russ#Es#
Hello Koni's!
#Russ#Es#'s Avatar
I would say a 6/10, takes a little patience to run the wire through.
cheers
On second thought, I ran the rear light off the front one - I had to put in a higher amp fuse. Just need to drop the lining on one side to get enough access. I joined a piece of fencing wire to feed the wire from the front to the rear and out the small hole I cut for the new light.
2006 LX FOCUS SEDAN
Old 01-10-2011, 01:48 PM   #17
leakey
leakey's Avatar
Hey guys. I would strongly suggest cruising Ebay UK for oem parts.
You can usually pick up a genuine LR or LS Ghia rear light with a plug (important) and the metal backing (super important) and land it here in OZ, using Royal Mail small packets service for abou AUD$10 all up.
Whilst you are looking for that, also look for the small vanity lights that go under the visors, an additional footwell or boot light, and best of all, an XR5 style front interior light.
I've done all these mods very easily myself, and they look and work a treat.
All run through the front interior light assembly, so they dim at the same time.
My next mod will be using foot well light assemblies in the wing mirrors to use as puddle lights. Also run through the centre interior light.
I did a how to on the rear light and I think also the vanity lights. Have a look for it.
But changing the centre to an XR5 unit is just brilliant. Map lights and super bright OEM lamps too.
You should be able to upgrade all of your lighting for under $50 using Ebay UK.
Have fun!
XG Falcon Ute, XE Fairmont Ghia & BA Mk II Falcon SR
leakey is offline   Reply With Quote Multi-Quote with this Post
