Old 14-03-2012, 06:27 PM   #1
Franco Cozzo
Franco Cozzo's Avatar
Default Mondeo XR5 wheels on LV Focus?
Hey guys, I'm looking into 18" wheels for my LV Focus, as I lowered it with the eibach pro-kit springs on Friday and yesterday I smashed off the wheel sensor wires on a speed hump, as the car is too low, so I'd like to lift it up a bit with some new wheels.
I'm looking at the 18" Mondeo XR5 wheels, will they fit on my Focus with the lowering? Or are they too wide and wrong offset?
Thanks much.
Old 14-03-2012, 06:47 PM   #2
Neale
Neale's Avatar
Default Re: Mondeo XR5 wheels on LV Focus?
The mondeo wheels should fit the focus, as im pretty sure there the same dimentions as the focus XR5 wheels
The ony problems I can think of is that the wheels whont raise the car because the hight of the sidewall is smaller on the 18's so it should have the same overall diameter as a smaller focus wheel.
Why dont you try getting some tryes with a higher sidewall on the current rims, which should do what your after.
One thing that you may have to look at it changing the overall diameter of the wheels will make your speedo inaccurate unless you get it re-calibrated
Neale is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 06:55 PM   #3
Franco Cozzo
Oh ok, damn. I've got 205/55/R16 on the car at the moment, I'm hoping to go to 235/40/R18 with the new Mondeo wheels, but if it ends up the same I'll just have to be really careful in where I drive now.
That looks fantastic by the way.
Old 14-03-2012, 09:22 PM   #4
Yellow_Festiva
Where to next??
Yellow_Festiva's Avatar
My calculations say that the car will be raised by about 7mm with the Mondeo wheels you quote.
Old 14-03-2012, 10:23 PM   #5
DZFord
DZFord's Avatar
Damo, have you done a search for a tyre size calculator?
As yellow festiva said, there will be a 7mm difference, which also means that you're speedo will be thrown out by a couple of km/h.
Old 14-03-2012, 11:05 PM   #6
DZFord
DZFord's Avatar
Also, with the car sitting so low, did you check that European parts sent you the right springs? Eibach have different spring rates for different Focus models, depending on engine type. For the 2.0L duratec, as well as the 2.0L TDCi, the correct part number should be: E10-35-016-02-22
Old 14-03-2012, 11:24 PM   #7
andrich
Those wheels look really good on that focus, suit it nicely
andrich is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 12:18 AM   #8
ConradP
ConradP's Avatar
With 18s and 40 profile tyres I'm pretty sure there was a >1% difference in overall speed on the speedo and it was lower, did the calculations when I was looking at wheels last year.
2010 LV Focus LX Titanium Grey - K&N Apollo CAI - 2" Cat-back Exhaust -18" Black with machined front RS rims - DRL/Halo Headlights - Eibach prokit springs - Front Strut Brace - Black XR5 Spoiler
Plans: Whiteline Rear Sway bar
ConradP is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 10:44 AM   #9
DJM83
Barra Turbo > V8
DJM83's Avatar
Which model Mondeo?
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ Tuned by LS Tuning and Performance
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 12:16 PM   #10
DZFord
DZFord's Avatar
This is the calculator I've found to be pretty good: http://www.inawise.com/tyre-calculat...alculator.html
The radius of the tyre will change, according to it's width.
"40 profile" refers to aspect ratio, which is a percentage of the tyre's width.
So a 225/40/18 will have a different ratio / sidewall height to a 235/40/18, which is what Damo is referring to.
To keep your Speedo + rolling diameter close as possible to stock, I`d recommend 225/40/18. But if you wanted to 'raise' the car a little go the 235/40/18.
Old 15-03-2012, 02:40 PM   #11
Franco Cozzo
225/40/18 are a hell of a lot more expensive than 235/40/18 it seems, I think the rims already have 225s on them. I'm finding out what year now.
Old 15-03-2012, 03:33 PM   #12
DZFord
DZFord's Avatar
Too right they are, 225 is a lot more expensive but I think that is because they are more rare than the 235s.
Let me know how you go with spring model number.
Old 15-03-2012, 03:58 PM   #13
Franco Cozzo
They're E10-35-016-02-22 for the springs. The wheels are for a 2009 Mondeo.
Old 15-03-2012, 05:29 PM   #14
Foconatic
Foconatic's Avatar
[quote=Big Damo]Hey guys, I'm looking into 18" wheels for my LV Focus, as I lowered it with the eibach pro-kit springs on Friday and yesterday I smashed off the wheel sensor wires on a speed hump, as the car is too low, so I'd like to lift it up a bit with some new wheels.
Thanks much.[/quote
Larger diameter wheels will get your speedo readings out.
Last edited by Foconatic; 15-03-2012 at 05:34 PM. Reason: Oops ! Already stated in the second post above..sorry.
Foconatic is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 05:42 PM   #15
Franco Cozzo
With speedo reading, bigger wheel I guess means it reads high, so I don't really mind.
Old 15-03-2012, 06:10 PM   #16
rand0mn00b
no, larger diameter wheels will read lower than the real speed
i.e. your speedo will say you're traveling 50km/h but you are in fact going quicker than that
rand0mn00b is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 07:11 PM   #17
DJM83
Barra Turbo > V8
DJM83's Avatar
So the ones in the above picture of the PB XR5. Are they cheap? Cause if it were me id just buy some LV XR5 Focus wheels it i were upgrading.
Old 15-03-2012, 07:17 PM   #18
Bucknaked
Bucknaked's Avatar
Good idea i think. They would look pretty sweet. Not a fan of the MB's. I could be biased but the MA ones are a nice wheel. Anyway, post some pics, keen to see how they look on your car.
Bucknaked is offline   Reply With Quote Multi-Quote with this Post
Old 15-03-2012, 09:24 PM   #19
Franco Cozzo
$650 for a set of 4 with 225/40/18 tyres
Old 19-03-2012, 08:38 PM   #20
Franco Cozzo
Well the guy never showed up on Friday, said he couldn't get a car down to get the wheels to me, and then supposed to show up at 1pm today, messaged him, no reply, he didn't send me anything.
I guess if a deal is too good to be true it probably is, lol.
Tossing up between new better tyres for the 16s or do I still proceed with bigger wheels?
