any suggestions on what to spray on a noisy belt......damn thing makes all sorts of weird noises
I put some "belt conditioner" on it but thats seems to be a short term fix looking at replacing it if I cant keep it quiet.......ideas please!!!
--------------------------------------------------------------- G'day....I'm Dave, ...everyone calls me Poppa,..05.. B.A. Fairmont mark II... may your day's be filled with smiles, your life be filled with love, may your children know nothing but happiness and joy, cherish the memory of those who strove before us for they cleared the way, spare a thought for those who serve we owe so much to so many, life and the freedom to enjoy it is a special gift that can be taken away far too soon! |
Get a lube stick or just replace it, they're not that pricey
Just replace the thing. Will save your ears.
Whilst the motor is idling, get a candle & allow it to (carefully) rub against both the inner & outer face of the belt. Don't use soap or any other product that gets slippery if wet (apologies to Bon Jovi).
a smear of rubber grease usually does the trick, just put a tiny amount on !
Quick spray of WD40 or RP7
A dash of lavender oil and a chocolate biccy
#8 | |||
Might smell pretty ... but ???
#9 | |||
a very poor attempt at, what he see's as, humour! thanks for the replies, much appreciated.....as i get time I will work down the list......one must work surely Mik where would I get the rubber grease and can I use it on other things such as stabiliser bar rubbers and shocker mounts
#10 | |||
I now have the sweetest smelling under bonnet of any vehicle I know jasmine I believe!!!........flower power is NOT dead!!!
poppa smurf,
Rubber grease is available from the usual places...Repco , Autobahn etc. Usually comes in a tube about 250 grammes from memory. Haven't bought any for ages. Peter. |
#12 | |||
#13 | ||
it`s handy stuff , comes in most popular sizes.
#14 | ||
nou
Replace the belt! lol takes $20 and 5 minutes.
If you don't know how, cut it just before a caravan park and limp your car over out front, pop the hood and look confused, one of em will help out for a 20 or a slab of beer. |
#15 | ||
I know everybody (with one or 2 exceptions) is trying to help but why would you put a lubricant on a drive belt when it needs grip to work properly? Just pull the belt off, turn it inside out and check for cracks or splits. If you find them, there is the cause of your noise. Replace. While the belt is off, check the tensioner and idler pullies for noise. Usually a mild grumble or squeal. Replace. Also check your water pump for free turning and play. Free turning is ok, play is not. While you are there, again, make sure the water pump spindle is not making any noise as well. I had one sieze on me and cost me a new pump and belt plus was finding bits of destroyed serpentine belt for months after all around the engine bay. Hope this helps.
I forgot to mention, alternators can make noise when they are on their deathbed as can air con compressors. |
#16 | ||
I understand what you are saying but all is good mechanically, simply a noisy belt
I had my suspicions about it being something more sinister as well but as soon as I put some "belt conditioner" on it ( I use a lot of the stuff around my workshop on different machines so i know it's good gear) the noise ceased leading me to believe it is only the belt this turned out to be a short term fix the noise has returned after treating it yesterday with candle wax so i think it may be time for a new belt I'll look at it on the weekend I dont like the look of the job but easily do-able
#17 | |||
nou
#18 | ||
Poppa Smurf what series Falcon is it?
#19 | |||
nou
#20 | |||
#21 | ||
Silicone spray works , my VW Crafter had this problem and the techs put me onto the spray while a permanent remedy was being worked on .
#22 | |||
#23 | ||
any reason why I should buy a "gates" belt at $70 odd dollars compared to normal $25 belts
longevity I assume???
