05-12-2012, 03:42 PM | #1 | ||
Hi All,
Recently picked up a 2012 Focus MKII Trend .Great car by the way. The manual refers to being able to open the windows using the Key Fob. Various sites on the net state the same. I cant seeem to get it to work and wonder if it is only for higher models. Anyone have any experience or knowledge on this? Cheers |
05-12-2012, 04:17 PM | #2 | ||
Noobie
not sure on the current model, but with my old LS Focus you held down the unlock button on the keyfob for about 3-4 seconds and the windows would all come down.
BrisVegas WS Fiesta Zetec 3dr NM Pajero TD LWB LS Focus Zetec 5dr - gone WS Fiesta Zetec 5dr - gone |
05-12-2012, 04:37 PM | #3 | |||
Nothing seems to make it work. Has me a bit puzzled. Cheers |
05-12-2012, 07:26 PM | #4 | ||
my MY08 LT focus has global opening. You hold the "unlock" symbol on the remote control down for about 3-4 seconds and all four windows come down great on hot days to open the car up. My manual says "where fitted which suggest some variations may not have it installed
05-12-2012, 07:46 PM | #5 | ||
Barra Turbo > V8
If it is the same as LV when putting them down you need to press once and hold, they will go down.
To go up i need to press once, then press and hold.
2011 XR6 Turbo Ute - Manual - Lux Pack - Twin 2.5" Stainless Exhaust - Antz Turboside Intake - CCForged Phatlux wheels - Tuned by LS Tuning and Performance |
05-12-2012, 10:02 PM | #7 | ||
05-12-2012, 11:25 PM | #8 | ||
Force Fed Fords
Now that this has been mentioned I remember my sales man at Binks Ford explaining it to me....
2021 Focus ST-3 Mountune Enhanced |
05-12-2012, 11:30 PM | #9 | ||
If it's not working by simply pressing and holding either the unlock button on the remote to open the windows or the same process to close them via the lock button on the remote then there is obviously something wrong. It's possible that there is a setting which needs to be activated on yours, this should be able to be done quite simply via the OBD port using a suitable reader. It's under warranty so I would suggest taking to the dealer and having it checked or as it's not really urgent, mention it at your next service
06-12-2012, 05:36 AM | #10 | |||||
I found something on this forum (from owners of the current Focus): http://www.fordownersclub.com/forums...touch-windows/ Quote:
I followed a similar procedure (may not have been exact) before for my 2006 Focus after I changed the battery, it worked. |
06-12-2012, 12:29 PM | #11 | |||
06-12-2012, 01:33 PM | #12 | ||
HUGE MEMBER
Thanks for the heads up. I called the Mrs to give it a crack. Works great. Orsm for Qld heat. Auto close aswell. I should read the book. I wonder what else the little terror does.
I would not pee on a Holden if it were on fire. I would take pics and post for your pleasure My cruiser. 1979 Zh Marquis. "T" code 351. My garage queen :(. 1980 TF Cortina Ghia Wagon. 4.1. My dog. 2011 Sierra My Daily. 2012 ZH (lol) OUTLANDER xls. 4WD CVT. Sapphire blue Wanted Borg Warner Lsd or centre. 25 spline |
06-12-2012, 05:44 PM | #13 | ||
It's only available on sports and titanium in lw2
06-12-2012, 06:54 PM | #14 | ||
06-12-2012, 06:58 PM | #15 | ||
HUGE MEMBER
Mine listed below is a base model Ambiante and it works
06-12-2012, 07:07 PM | #16 | ||
06-12-2012, 07:27 PM | #17 | ||
HUGE MEMBER
Must be a 1 bud.
07-12-2012, 11:05 AM | #18 | ||
