Old 08-12-2014, 07:42 PM   #1
WHYME
Next up?
WHYME's Avatar
Default HTTP 500 Internal Server Error
Hello all,
It seems that when I try to click on this thread Show us your BA/BF!! in the Show' N Shine section, I keep getting this HTTP 500 error (I even get the error when I try to click on some other threads too).
I've tried clearing my cache and refreshing the page but with no luck, if anyone could get this sorted for me it'd be greatly appreciated.
To be further assisted I am using IE11, but have also tried using Google Chrome to no avail.
If it ain't a Ford you're bored.
Blue blooded to the core.
WHYME is offline   Reply With Quote Multi-Quote with this Post
Old 09-12-2014, 12:06 PM   #2
GasoLane
Former BTIKD
GasoLane's Avatar
Default Re: HTTP 500 Internal Server Error
Works fine here.
Opera 12.17 and Opera 26.0 (Win 8)
Old 09-12-2014, 02:55 PM   #3
Uncle_Ken
Next upgraded Mk1 Leopard
Uncle_Ken's Avatar
Me to IE 9, firefox 33.1 and chrome
UK
Old 09-12-2014, 03:30 PM   #4
WHYME
Next up?
WHYME's Avatar
So no one has a solution for me?
Old 09-12-2014, 08:08 PM   #5
Falcon Coupe
Clevo Mafia Inc.
Falcon Coupe's Avatar
Chairman's Award: Chairman's Award - Issue reason: The exceptional contribution made to AFF over an extended period of time. Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Your tireless efforts behind the scenes in keeping AFF the place it is.
First port of call is usually to run CCleaner and clear your cache/temporary files and registry cleanup. Try again after that.
Must be your end if it's working fine for everyone else.
Falcon Coupe is offline   Reply With Quote Multi-Quote with this Post
Old 10-12-2014, 03:30 PM   #6
WHYME
Next up?
WHYME's Avatar
Yep, it's definitely on my end. I just wanted to know if there was an easy fix, thanks for the help and hopefully this works.
Old 10-12-2014, 07:49 PM   #7
russellw
russellw's Avatar
Failing that check whether you are using a proxy server as these can introduce that type of error.
Russ
Old 10-12-2014, 07:56 PM   #8
Streets
Streets's Avatar
Try going to the page you were getting the error message on, and hitting Ctrl+F5. This will force your browser to reload the page from scratch, instead of recalling the error page out of its own memory. If Ctrl+F5 doesn't work, try going into your browser options and clearing your cache there as Falcon Coupe said.
Streets is offline   Reply With Quote Multi-Quote with this Post
