Hi All,
First post, so to get started, hi. I have a 2010 TDCI Powershift Mondeo wagon and have started experiencing some intermittent issues. I have only owned it for about 7 months, it has 135,000k's. Oil (transmission) was changed at 120,000k service by Ford. So far it seems to be the same three fault codes popping up. One for an input/output sensor on the Powershift (Ford quoting nearly $3k to fix). Second one is the active grille shutter. Thirdly the ECM. Now, the symptoms are under normal driving, at complete random times it will highlight the information symbol on the dash and Check Transmission will appear in text. The car will then over rev, and then only select odd gears for eg: 5th then 3rd etc. If I turn the car off and re start it the problem resets and it will drive normally again. I am reluctant to just throw money at it hoping we change the right parts, so am waiting for it to happen again so Ford can read the fault codes whilst "live" without any ignition cycles. I had a look through the grille and noticed it does appear to have one broken vain on the shutter, so that might explain that fault code. Ford seemed concerned about this, but, I can't see it contributing to the shifting problems?? No overheating issues with it at all. So for the collective, any suggestions at to what might be going on? Where the problem is? Anyone experienced similar? |
Firstly the active grille - I doubt you will experience much difficulty in practice, so I wouldn't be concerned with it now.
Secondly, what is the exact code you are seeing regarding the ECM? (to Ford its the PCM) The 120k Ford service must have been before you bought it. You can't be truly 100% sure that the trans fluid actually did get changed, even if it was paid for ![]() What do you know about the previous owner? Was the fluid changed at 60k? You could get a mechanic you trust to check the condition (colour) of the fluid, although having done 15k since the change it probably won't be conclusive as to how new it is. Out of interest, is this the 'facelift' model? ie is it MB or MC?
_ __ __ __ __ __ __ __ _ _____________________ 2010.11 Mondeo Titanium MC Ink Blue Diesel Hatch Last edited by Deo; 08-01-2015 at 09:15 AM. |
#3 | |||
I am not sure of the fault code number, Ford themselves read it and referred to it as ECM.. Correct, the 120k service was completed just as I bought the car, from a Ford dealership (not the same one I have had look at the fault codes). I raised that with my local Ford dealership too, as I was suspect that the trans fluid had been done, they contacted the dealership I purchased it from and obtained a report from the 120k service, apparently it was completed. But, who knows. I bought the car from a Dealership, I think the previous owner was RACV as a service/fleet car. The dealership I bought it from completed the 120k service as part of the purchase etc as it was due. The service book is up to date with no services missed, however I don't have receipts of what was done. It is the MC, I think the build date is September 2010. |
#4 | ||||
Hm I'm guessing you have moved interstate because you bought it from one Ford dealer but are having a different one look at it.
Sent from my GT-I9305 using Tapatalk 2
_ __ __ __ __ __ __ __ _ _____________________ 2010.11 Mondeo Titanium MC Ink Blue Diesel Hatch |
Sorry to hear about your problems.
To see the cost of that quote makes me thankful I shelled out for the extra MyFord factory warranty to 200k. If you do have to get the sensor changed I assume it must be inside the transmission based on that cost. If it has one on each gear shaft it might be worth asking how much to get the other one done at the same time. Most of that cost is probably labour to pull the transmission out and pull it apart. Hopefully you can get it sorted for cheaper.
2016 Kuga Trend TDCi |
#6 | |||
I've had the "dropping into Neutral" problem only twice. But gear changes have been Intermittently rough, so I took it into Ford for my first ever dealer service. They want to change some sort of Shaft sensor (which they say is actually causing the problems) and while they're at it, replace the Clutch pack, cause there's metal fragments in the oil... $4500 is almost half the value of the vehicle! It's a tough pill to swallow! Did you end up getting the job done Bobthekelpy? |
Solution Was Boost 4?, 6 & 8
Big thread here on the PowerShift auto...
http://fordforums.com.au/showthread.php?t=11399507
[SIGPIC][/SIGPIC]
AUTOTECH TUNED EDELEBROCK CHARGED 2017 GT Mustang Plenty of RWKW |
#8 | |||
Sent from my GTi-9305 using bloody Tapatalk
#9 | |||
I had two quotes both around $2500 to remove transmission, strip down and replace sensor, refit box and fill with fresh oil. The sensor alone is over $500 plus $300 worth of fluid. I asked about the clutch pack and apparently they don't go near that part of the transmission when stripping it down. Mines a 2012 tdci wagon (ex fleet) with 135k km on it. Hopefully that sorts out all the problems as I brought this to commute in and have spent the last 3 weeks driving my uneconomical 4x4 ute I instead. Last edited by bundybear75; 27-02-2016 at 01:06 AM. Reason: stupid predictive text on crappy windows phone |
#10 | |||
I'm guessing the clutch packs are worth a pretty penny, so your $2500 quote sounds about on the money of you weren't to do that part of the job. |
I'm seriously considering just doing it..
My alternative is to trade it, but I'm guessing I'll lose $3k in the trade. plus another $500 Stamp Duty. So, all of a sudden the new clutch is "only" an extra $1000 which seems far more palateable... Is that just crazy maths? |
I might have the same problem with my 2012 MC, 72,000km. A Transmission "limited function" warning message appeared yesterday. I stopped immediately and all seems fine after a restart.
The car was bought from a Mazda dealer, 2 weeks ago. Should I take back there or get someone else to check it out first? (Ford or my usual independent mechanic). Do I need to address ASAP? Can I damage transmission if it happens and I'm not able to stop quickly? |
#13 | |||
Definitely should be high on the priority list. |
#14 | |||
In the case of a transmission Limp Home I gather there are many programs the TCM may adopt depending on the particulars. So you may find a gear or number of gears restricted. The point of that would be to allow you to continue as necessary to safety or workshop. When the situation allows, remove the ignition key for 15s and try restarting, which may clear the fault. The above info is from the pdf which was recently linked here in Mondeo section. See if there's a fault code set. I don't get why codes are cleared by the car when they might be useful later? If you have Forscan on your phone and a BT adapter permanently plugged in you can access codes which are not permanently set? That's worked for me before. |
#15 | |||
It is, but it'll take me a few days to get it booked in and looked at so worried whether I should be driving it or not. Is it the sort of fault that presents itself regularly after the first time. |
#16 | ||||
http://www.fordforums.com.au/showthread.php?t=11447964 http://ddl2.data.hu/get/0/7459943/powershift.pdf Quote:
So is this 'Transmission Function Limited' fault one that is logged? Will Mazda guys will see it when I take it in when all is working fine. |
#17 | |||
Drove fine after CEL reset but started getting neutral between gears more and more regularly. Have done approx 500km more since problems started. Drove the 100km to work fine this morning (played up yesterday afternoon quite bad), just need to get it the 15km to the transmission specialist this afternoon to drop it off. Hopefully the problems will be sorted with a new sensor installed. |
#18 | ||
Mine has had a Transmission fault once. Restart cleared it and it's never popped up again.
Stupidly I just wrote it off as a computer malfunction and didn't got it checked out until the next service months later. |
#19 | |||
I take in now that's not likely/possible. |
#20 | |||
Glitches do happen though. My wife's Mondy has had one EML relating to an oxy sensor which has not yet recurred since 04/15 (marvelous records!) Last edited by rondeo; 29-02-2016 at 12:45 PM. Reason: addition |
#21 | ||
bugger. So I wonder what the dealer will say/do if there's no way to prove there's been a problem? Its booked in for Monday 7/3
Maybe I should get one of those BT adapters. where from? Edit. anyone know about adapters/apps for iPhone. I can only find forscan lite, which seems like it need a OBD2 WIFI adapter. I guess that'll do? Last edited by manchu; 29-02-2016 at 01:21 PM. |
#22 | ||
https://www.scantool.net/
Exactly, that's the problem as I see it. No experience with i phone, just android. |
#23 | |||
http://www.australianrobotics.com.au...wifi-scan-tool I wonder if this $25 fella would do the job well enough. http://www.ebay.com.au/itm/ELM327-OB...AAAOSwBahVWcPH |
#24 | ||
Yes that'll be fine.
#25 | ||
I also have had the "Transmission Limited Function" exactly once. Came about 1000km into my ownership of an 89,000km car (private sale). I think rondeo is on the money, there are several different limp-home programs the computer may select, and the TLF message is a catch-all alert for all of them. In my case I had no gears, until I shut down and restarted the car, after which it seemed to be fine again. TLF itself doesn't create a permanent fault code it seems, it's up to whatever the underlying cause is as to whether you get a code logged and it stays in limp mode. I took the car to Ford within days but they found no fault codes stored (they did find software updates for the PCM, TCM & ECU though).
Since then the car has behaved normally through a further 2000-ish km. The only issue is that sometimes it revs and lurches between first and second gear when in auto mode, like it momentarily selects the wrong gear or finds neutral. Not sure whether this represents an issue, or is part of normal operation. My understanding of these gearboxes is, although they're marketed as an automatic, it's really a manual with computer-controlled shifts. It just happens the computer has also been programmed to shift automatically during driving for you. I'm inclined to think the computer is not infallible, and it can get confused and make a wrong shift at times. I've decided to try driving in manual mode for a while to see how it goes when I (partially) take over the decisions of when to shift for it. Also inclined to get an OBDII dongle to monitor in real time. |
#26 | ||
[QUOTE=manchu;5603171]cheers. $155! from local distributor.
http://www.australianrobotics.com.au...wifi-scan-tool I wonder if this $25 fella would do the job well enough. http://www.ebay.com.au/itm/ELM327-OB...AAAOSwBahVWcPH[/QU Maybe. Any experience? Another thing to consider is if MS CAN is supported. Service at Ford will cost you more, just plugging in to IDS twice. Another factor is whether or not you will have a flat battery after a few days. The scantool OBD MX has battery saving technology. The OBDlink MX will not fit under the plastic dash trim though, you need a low profile right angle adapter and some plastic ground off. I forgot to mention that. This is really another thread though? Last edited by rondeo; 29-02-2016 at 02:17 PM. Reason: correction and addition |
#27 | ||||
except I also occasionally had hard shifts 2nd to 3rd as well. Definitely worth checking that your shaft sensors are working correctly at your next service (or before) Quote:
In my case, the robot is worse than a learner driver 1 out of every 10 drives. |
2 users like this post: |
#28 | ||
The DCT transmission was designed partly as an emission control device. Like DPF and EGR it may add to operation cost and reliability. We'll see to what extent? I don't miss my EF.
#29 | ||
Aaarrrrgggghh!!. I'm in Powershift hell. Any advice on how to handle it would be greatly appreciated.
06/2012 TDCi Wagon, 72,000km, bought from dealer. 2 days ago I got "Trans Limited Function" warning, which corrected after re-start. Service book is fully stamped, by either ford dealer (last at 30,000km) or RACV workshop. I just got off the phone to the RACV workshop who had some bad news: - 60,000km service didn't include trans fluid change. - The trans problem is known and was the reason the car was traded. Apparently it's been looked at twice but fault was never resolved. I'm kicking myself for not either calling previous owner, or calling the workshop to check service record. I'm concerned that the dealer will stuff around re-diagnosing, attempting cheap fixes, or claim there's no problem... dragging on the process, out of stat warranty period and leave me without a car for a long time. It's obvious the trans needs significant work, so how can I make sure this happens without getting stuffed around? I haven't mentioned todays findings to the dealer yet. |
#30 | |||
As far as the dealer knows, you brought the car with the full service history as per the book. Has it logged a fault code or is the check engine light on? Do you have a tame mechanic mate who could scan it and check? (don't reset code though) A vehicle that age with that many km has to have a warranty, take it back to them and see what they say. If they start the muck around then start making suggestions. Give them a chance first. Good luck with it. |
