Old 31-12-2015, 04:50 PM   #1
+Rennie+
Default mk1 Focus 2.0L air intake mods?
Is it worth getting one of these ~125 ebay CAI systems or should I just do a DIY using the stock location for air intake?
The CAI seems like it would place the filter down behind the fog light. I guess there is enough pressure down there. The stock location isn't so bad if using a bigger pipe to the airbox/resonator assembly since the air pressure is high enough at that location when moving.
There are also more expensive CAI with foam filters and custom airboxes but I'm not sure they would be worth it on an older car. (Pipercross, volante etc)
+Rennie+ is offline   Reply With Quote Multi-Quote with this Post
Old 31-12-2015, 06:33 PM   #2
pajoda
pajoda's Avatar
Default Re: mk1 Focus 2.0L air intake mods?
isn't the stock unit is pretty much cold, there is nothing to gain unless you want some noise from an open filter which isn't really legal in most states
2018 Ford Focus RS
pajoda is offline   Reply With Quote Multi-Quote with this Post
Old 01-01-2016, 06:17 PM   #3
DZFord
DZFord's Avatar
All the info you need is right here: http://fordforums.com.au/showthread.php?t=11322333
Old 03-01-2016, 11:12 AM   #4
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Nice find DZFord.
Interior Enhancements: Footwell Lighting, Brushed Alum. H/brake Handle, 6 Disc In-Dash System.
Exterior Enhancements: ST170 Wheels, Richbrook Shorty Aerial, Euro-Spec Hatch Handle.
Performance Enhancements: Ate Callipers/EBC Rotors/EBC Greens Stuff Pads, ST170 Suspension, Herrod's Custom Tune, Ford Racing Coated Exhaust Manifold & Bespoke 2.25in Exhaust.
Awards: AFD '07 EFOC Best Focus, SFS '09 EFOC Best Focus, SFS '10 RSOC O/all Best Focus, AFD '10 CFC O/all Best Focus.
Fast Eddie is offline   Reply With Quote Multi-Quote with this Post
Old 03-01-2016, 02:36 PM   #5
DZFord
DZFord's Avatar
Blast from the past hey Eddie?
Old 04-01-2016, 04:34 PM   #6
Fast Eddie
Motorsport Guru
Fast Eddie's Avatar
Absolutely. Lot of water under the bridge since our last Car Show with the owner of that MK1 Focus in the link to that Thread. It was their pride and joy and took home their fair share of Trophies and deservedly so i.m.h.o.
Old 20-01-2016, 04:04 PM   #7
+Rennie+
I was thinking that since the stock airbox is tuned with that resonator I could just use a larger pipe that is insulated from heat, possibly taking air from the bottom grill since there is a nice opening that is separated from the radiator.
