TSCoA member Qld
Hi all,
Bit of a long shot I know, and I am following up on a couple of other leads, but I am after a specific wheel lock nut coded 5B38 (as pictured). Enquiries at a Ford Parts depot lead me to believe that the lock nuts were outsourced, and the company has since gone under. However, the silver lining is that this coded lock nut was one of the more common ones used for Tickford wheels (apparently there were only about 6 differing combinations). If you have any old lock nuts from original wheels lying around, I would greatly appreciate it if you could check the code. I am happy to pay a small fee to compensate if required and postage. I live in the north end of the Gold Coast. Any help would be greatly appreciated before I get a 'flat'! [IMG] ![]()
Cheers, Martin Mac. ![]() T-Series Club of Australia member; QLD |
Next upgraded Mk1 Leopard
I have these 2 types and the wheel nuts they fit... one is yours
Hope this helps UK
Last edited by Uncle_Ken; 07-01-2016 at 06:54 PM. Reason: pic insert didn't work |
Ford T3 Partsologist
you should be able to get replacements made Thru Ford - i think they are done out of South Australia - will check it out on Monday for u
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() |
Ford have 1 set left in the country in WA warehouse - 1 of the 6 types of GENUINE sets of 4 lock nuts and 1 socket (different codes on socket tho) can have it with me on Tuesday
$185.00 inc GST plus post still will check Monday to see if i can get a 5B38 replacement nut and socket
TSCoA member Qld
First thing I did was check with Ford...and they told me the SA company that made them for Ford has gone, as is no longer trading.
#6 | |||
TSCoA member Qld
Cheers, Martin Mac. ![]() T-Series Club of Australia member; QLD Last edited by falcongt4me; 10-01-2016 at 04:30 PM. |
TSCoA member Qld
PM sent...
Howdy Martin FYI the Ford set that i can lay my hands on out of Perth, has a Socket marked 6B38 (yours is 5B38) and the lock nuts are 40mm overall length
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() Last edited by Dingo; 11-01-2016 at 03:16 PM. |
![]() 2002 Blueprint T3 TE50 Manual Koni Suspension # 161 ![]() ![]() T-Series Club of Australia - www.tseriesclub.org ![]() ![]() Last edited by Dingo; 11-01-2016 at 04:18 PM. |
Hello all, looking for an Ford Wheel Lock Nut as close to this as I could photo;
https://drive.google.com/file/d/1Koe...usp=drive_link https://drive.google.com/file/d/1gcC...usp=drive_link https://drive.google.com/file/d/1v7_...usp=drive_link It is NOT 6B38 because I have that and it does not fit. Happy to pay for postage and tracking and than can send it back to you my cost. All I need to do is take 4 nuts off. Misplaced this damn original socket and cannot find it. |
