Old 30-07-2021, 12:04 AM   #31
M&Ms
M&Ms's Avatar
Talking Re: Upgrade to 8 speed?
Originally Posted by DFB FGXR6 View Post
Can agree with that, the ZF8 in our XE makes the 147 kW engine feel way more powerful than that. Butter smooth up and down the box, and rev matches on the downshifts via paddles. And unlike most DSG's, it can schlep around at low speeds unobtrusively.
I think an 8 speed is probably the best compromise between having enough gears for economy, and not being a pain by hunting for for the right gear.
Agree.
Honestly I didn't get the focal point of your photo, so I'll upload mine
My Resume:
Current:
Alfa Romeo Giulia Quadrifoglio in Vulcano Black
MY18 Black WRX STi Spec-R
Previous:
'16 White FGX XR8
'09 Black FG FPV GT 5th Anniversary
'04 Blueprint BA XR8
'97 Mocha Foam EL Fairmont
M&Ms is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2021, 08:43 AM   #32
wodahs
wodahs's Avatar
Default Re: Upgrade to 8 speed?
seeing we sharing pics if our dash setups , heres mine in my 8speed auto
yes still (as money n time permit) doing the
rebuilding the zh fairlane with a clevo 400m 4v heads injected whipple blown with aode 4 speed trans to a 9" ....... we'll get there eventually
just remember don't be afraid to try something new.
Remember, amateurs built the Ark...Professionals built the Titanic!
I have taken up meditation... at least it's better than sitting around doing nothing !!
wodahs is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2021, 12:51 PM   #33
Vesper Martini
Vesper Martini's Avatar
I recall driving the 10 speed ranger, and thought it wasn't really using all 10 gears, perhaps if you were towing and needed the best gear to climb a hill it would come into play.
______________________________
2015 Territory Titanium RWD Diesel - SOLD
2016 BMW X5 xdrive 30D Msport
Seadoo Challenger 210SE 310HP
Vesper Martini is offline   Reply With Quote Multi-Quote with this Post
Old 30-07-2021, 01:45 PM   #34
Crazy Dazz
I don't see how 8 gears could ever be considered a "compromise" (in a car at least)
I've driven trucks with (a lot) more, but that's because the "power to weight ratio" was practically zero, and some of the engines have only 500rpm of usable range.
Old 30-07-2021, 06:58 PM   #35
Well this is a car based forum, so obviously my comment was directed towards cars.
In performance driving conditions, a 10 speed can feel very odd with the ultra short gearing. And obviously a 4 or 5 speed automatic is a drain on performance and economy. That is where the 7 or 8 speed auto is a compromise, not too short in the gearing and also not constantly hunting for a gear, but also not straining the engine.
Old 30-07-2021, 07:11 PM   #36
In sedate driving in D, the 10 speed skips gears. For example, it will start in 1st, skip to 3rd, skip to 5th ect.
For towing, heavy accelerating and when S is selected, the gearbox then shifts sequentially through the gears.
With so many gears, it can be hard to know what gear is actually in. One trick I have found with the 10 speed Ranger, click the + or - selector while in D and a gear map will be displayed on the cluster screen. Handy for knowing what gear the transmission is in and a interesting thing to observe.
Old 30-07-2021, 07:13 PM   #37
Originally Posted by M&Ms View Post
Agree.
Ha ha, I'm a visual person and like to add images to flesh out my posts, I though that one was appropriate. And, I also love how when in manual mode, the current gear is shown in a somewhat retro graphic.
Old 30-07-2021, 09:22 PM   #38
Crazy Dazz
Last edited by Crazy Dazz; 30-07-2021 at 09:29 PM. Reason: You need to revisit your understanding of the term "Compromise"
Old 30-07-2021, 09:31 PM   #39
fiestaz
fiestaz's Avatar
I think you’re the only one not getting it
2016 Mazda 3 SP25 GT
2019 Hyundai i30 Active.
fiestaz is online now   Reply With Quote Multi-Quote with this Post
Old 30-07-2021, 09:32 PM   #40
Franco Cozzo
Franco Cozzo's Avatar
Needs more BTR 1st gear with 3.08 diff ratio, 1 gear does everything from car park to freeway legal speed limit
Old 30-07-2021, 09:33 PM   #41
fiestaz
fiestaz's Avatar
Like a Tesla!
Old 30-07-2021, 09:43 PM   #42
Franco Cozzo
Given the space constraints of a light vehicle transmission - makes me wonder how strong the components are inside the gearbox - they can't be of significant size, right?
Old 30-07-2021, 11:25 PM   #43
jpd80
jpd80's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Thoughtful contributions to our community
Shades of Powerglide with first good to about 70 mph…….
jpd80 is offline   Reply With Quote Multi-Quote with this Post
Old 31-07-2021, 12:02 AM   #44
wodahs
wodahs's Avatar
Originally Posted by fiestaz View Post
Like a Tesla!
dont knock it ! mines a 1 speed !!...
D
thats d for drag
never use r for race its broken
Old 31-07-2021, 03:42 PM   #45
Bossxr8
Peter Car
Bossxr8's Avatar
https://www.motortrend.com/how-to/10...nd-trans-swap/
The 10R80 is the new kit on the block; it's Ford's implementation of the joint Ford-GM collaboration on a new high-tech trans. (GM's version is the 10L80 and 10L90.) Few, if any, performance hard parts are available yet for either manufacturer's version, but so far it seems to be a pretty stout piece under most hot rod scenarios. Dolejsi reports the only broken 10R80s he's seen are out of heavy four-wheel-drive trucks that (paradoxically) were lowered on drag radials, turbocharged, and subject to a full spool-up "hot launch" at the drags. "But only under that extreme boost-building condition—and only in trucks. Starting at the 600-hp level with power-adders in a car, the 10R80 only needs better clutches so far, which are available. Clutch failure starts with the F clutch pack; the E-clutch is next." If the trans is in good shape with low mileage, going through it for performance at the 1,000-hp level costs around $2,500 parts and labor.
Old 31-07-2021, 07:53 PM   #46
slowsnake
Try a Hewland gearbox?.....served Jack Brabham well, lol,
Cheers BBBBB
slowsnake is offline   Reply With Quote Multi-Quote with this Post
Old 02-08-2021, 11:06 AM   #47
Vesper Martini
So you have the XE, which got me looking as I knew jags came with the Lion v6.
Looks like the XF-250 did. and the last of them in 2012 had an 8 speed.
In theory this Trans should mate up to the territory diesel.
to those in the know would the transmission module plug in.. and work?
last problem of course is how many wreck 2012 XF 250s are in australia..
