Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member. |
01-09-2021, 05:15 PM | #421 | |||
Have a look at the below pic and advise which part you are referring to as there is a trim on the interior and exterior. I will also need to know what model SX/Y you are chasing along with month/year as they differ accordingly or a VIN would make it easier. SX SY Tailgate Trim.PNG |
01-09-2021, 05:31 PM | #422 | |||
0o\==^==/o0
Honorary Tony Oldest to youngest 1971 ZD Fairlane 1978 W123 Mercedes Benz 280e 2004 BA XR8 2007 W211 E63 ////AMG 2008 Fiat Ritmo -for the kids to take ownership of while I pay for running costs 2009 SYii Territory Ts 2011 W212 Mercedes Benz E350 returned to the kid but now bent. |
02-09-2021, 08:13 PM | #423 | |||
I can try to see if I can get the box dimensions and weight and go from there if you are interested.. |
02-09-2021, 08:35 PM | #424 | |||
0o\==^==/o0
02-09-2021, 08:40 PM | #425 | ||
07-09-2021, 01:59 AM | #426 | |||
Thanks |
07-09-2021, 09:41 AM | #427 | |||
regards Blue |
11-09-2021, 09:48 AM | #428 | ||
11-09-2021, 07:56 PM | #429 | |||
Regular...with metamusal
easier to get out of a Terri than the Falcon. |
15-09-2021, 10:11 AM | #430 | ||
15-09-2021, 09:35 PM | #431 | ||
Hey GT Legend,
Whats the cost for a OEM front crankshaft oil seal for a 2004 BA MK2 Falcon, 5.4L 3v, barra 220? Thanks.
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. |
15-09-2021, 09:40 PM | #432 | ||
16-09-2021, 08:18 AM | #433 | ||
Hey mate, was looking for the two bolts that mount the air intake box to the sheet metal just underneath the pcm. Car is a 08/2011 FG petrol NA 6cyl manual sedan
I was also curious if genuine sets/kits/assemblys of screws/bolts exist for sale from ford? Things like the radiator shrouds, lower air deflector and other plastic exterior parts that use metal screws or plastic scrivets. I'm not after specific ones as of yet just looking for a convenient solution if it exists. Thanks mate |
16-09-2021, 09:16 AM | #434 | ||
PM sent.
16-09-2021, 10:44 AM | #435 | |||
Have a look at the image below, believe you are referring to bolt labeled HS1. They are $3 each plus postage if required. Ford do not do fastener kits, you have to buy each individual one bu one unfortunately. FG Air Cleaner 4.0 NA.PNG Cheers |
16-09-2021, 01:22 PM | #436 | |||
17-09-2021, 12:12 PM | #437 | ||
Hey GT,
Do you know the part number and rough cost for an fgx xr6 turbo drivers side(fuse box) engine loom? I know the FG mk2 was BR29-14K011-ke/BR29-14K011-kc part number I believe. |
17-09-2021, 12:32 PM | #438 | |||
In FGX there are 14 different part numbers for that part. Maybe a VIN would narrow it down to the correct one you are after. For turbo from what I can see it will either be ER2Z14K011JB or ER2Z14K011KB. The JB is $390 and the KB is obsolete. Need a bit more information to clarify.. GT |
17-09-2021, 12:37 PM | #439 | |||
I don’t have a specific vin as it’s part of a conversion process to go from FGX G6e to FGX g6e turbo, I specifically have been trying to find the entire fuse box loom from an fgx turbo automatic car to save me cutting into the original engine loom. I need the turbo automatic engine loom on the drivers side(including fuse box) as it has the boost solenoid loom section attached and the correct wiring loom to dual thermo fans compared to the NA FGX being a single fan. |
17-09-2021, 12:47 PM | #440 | |||
JB: WIRING - ENGINE CHARGE TEMP. SENSOR (4.0 DOHC PETROL EFI TURBO 24V VCT, HIGH FRONT LAMPS W/SIGNATURE DTRL) KB: WIRING - ENGINE CHARGE TEMP. SENSOR (4.0 DOHC PETROL EFI TURBO 24V VCT, WITH QUAD HEADLAMPS) These are the only two where turbo engine is mentioned. |
17-09-2021, 01:12 PM | #441 | ||
17-09-2021, 02:45 PM | #442 | |||
Peter Car
21-09-2021, 04:19 PM | #443 | ||
Mr GT,
You mentioned in another post you might be able to source the BA/BF handbrake TSB service kit BA22K068AK1T. If you can, let me know and a price for it. If its a headache to do I'll get that ebay one you found. But I'd rather get from a forum source if it works out. |
21-09-2021, 04:35 PM | #444 | |||
Yes I actually have a NOS one here left over from old bits and pieces I had collected for an old car I no longer have. $20 plus postage is what it is worth and its not an issue to send if you want it. Let me know GT. |
21-09-2021, 04:57 PM | #445 | |||
I'm only really interested in the springs, so as long as they are good then I am happy. I have to rush to Dad's workshop to help him out with a problem. Maybe drop me a PM with payment details and whatever and I'll fix it up when I get home tonight. Thanks for that. |
27-09-2021, 08:39 PM | #446 | ||
EL XR6
Hey GT, i'm after full black FGX sedan carpet if possible... My clutch pedal has worn a nice hole right through it, and presuming like most it's all one piece?
Winter white 15' FG X XR8 Shockworks coilovers | 1000cc injectors | DiFillipo Twin 3" exhaust | Bluepower tuned | 380rwkw Navy 97' EL XR8 Factory manual | Tickford kit | Pacemakers + Full exhaust |
27-09-2021, 10:17 PM | #447 | |||
Happy to assist if need be, but it may be cheaper in this case to buy local to you in Vic based on the size of the item. Let me know if you still want me to chase..will need a VIN if so. |
28-09-2021, 10:56 AM | #448 | ||
GT,
The handbrake spring kit arrived safely, thank you very much. Just curious, it came with 2 sets of those retaining plates. You also get 2 plates per side when you buy an aftermarket shoe kit. But you only need one plate... Is there a reason why they supply 2 per side? I was also after a price and availability for a BF XR 17" wheel centre cap. Are they NLA or obscenely expensive? Found out yesterday the previous owner glued one with broken tabs to the wheel and another is missing the steel tension ring, so its just ready to fall out. Will see if Dad wants to spruce up his sh*tbox. |
28-09-2021, 11:05 AM | #449 | |||
When looking for the brake spring kit I found an extra two plates so I thought I would just give them to you as you may have better use for them then me, so it was a bit of a bonus for you. The kit only normally comes with two plates and two springs. There are a few different centre caps available for BF 17" wheels, I think the correct ones you need are around $35 each, but to be sure can you get me the engineering number off the back of it and then I can confirm. GT |
28-09-2021, 11:57 AM | #450 | |||
I'll get the number when Dad gets home. |
