Has anyone had issues with front tyres wearing on the inside, both my fronts have the canvas showing approx the same on either side they have done 27,000 km's & been rotated front to back every 7,500km's the vehicle has not been tracked or driven excessively hard as in cornering etc it is a late 2020 SA Mrk 4 ST so just gone 2yrs old, I was really surprised to see this amount of wear the tread in the centre of the tyre is fine still well above the wear markers
I have not hit any pot holes etc that would cause an alignment issue & it steers straight when on level ground, I am replacing the tyres within the next week & will obviously have the alignment checked, all I can think of is to much negative camber or toe out or both, what camber do they run from factory? I saw something that said anywhere from 0 to -1.6, thanks for any info. |
Force Fed Fords
I had excessive wear front two tyres, toe -2.5mm left front and -2.9 right front, but my vehicle was lowered, mountune springs all round. I still managed to 22000k approx
After alignment, set of new tyres, running .8mm and .9mm
2021 Focus ST-3 Mountune Enhanced |
Thanks for the info mine is standard but I'm sure there is a camber or toe issue getting new Pilot sport 5's next week & definitely a wheel alignment, I think these tyres should last for at least 40,000km's without to much maniac driving they have a tread ware rating of 340 & get good reviews so here's hoping.
#4 | |||
Force Fed Fords
I will let you Know how they are as soon as I get a few k's on them all tests suggest there better then the pilot sport 4, we will see, all the best.
Hi Redrum I have my new Pilot Sport 5's & have done about 400k's simply they are great, IMO slightly less noise than the 4s's, in corners they are very precise with really positive turn in, I have not driven in the wet as yet but from all the tests i have read they are even better in those conditions, another positive is the tread wear rating is 340 as against the 4s's which are 300 so going on that they should last longer with similar use, I had them fitted at Tempe Tyres in Sydney by far the cheapest $365 when the vehicle was on the wheel aligner I was informed there is no way to adjust the Camber from the factory settings on the front wheels so it stays as is & that was -1.8 on the passengers side & -1.9 on the other so i will be rotating the wheels every 5,000km's,they are my thoughts on them so far, cheers.
T3/Sprint8
![]() Join Date: Jan 2005
I don’t sense any road noise from my PS4’s and they are 20’s.
Good to hear 5’s are good as I expect. Sent from my iPhone using Tapatalk
Tickfords T3/TS50 '02 Sprint8 manual Sept 24 '16 Daily Macan GTS LFC title #20 24/25 season YNWA "Don't believe everything you read on the internet. Abraham Lincoln" |
Hi Redrum I have my new Pilot Sport 5's & have done about 400k's simply they are great, IMO slightly less noise than the 4s's, in corners they are very precise with really positive turn in, I have not driven in the wet as yet but from all the tests i have read they are even better in those conditions, another positive is the tread wear rating is 340 as against the 4s's which are 300 so going on that they should last longer with similar use, I had them fitted at Tempe Tyres in Sydney by far the cheapest $365 when the vehicle was on the wheel aligner I was informed there is no way to adjust the Camber from the factory settings on the front wheels so it stays as is & that was -1.8 on the passengers side & -1.9 on the other so i will be rotating the wheels every 5,000km's,they are my thoughts on them so far, cheers. (sorry I originally put this in the wrong place, cheers)
Hi it was just a sense that the 5's might be just a shade quieter but there's really nothing in it, the 4s's were awesome but more expensive, cheers.
T3/Sprint8
yep all good, yer your pricing looked pretty damn fair, wish 20x275's would be cheaper when I need to replace em haha and fronts.
