#1711 | ||
#1712 | ||
#1713 | |||
I am getting this done as a repair through insurance, and the panelbeater can only use his "standard" supply chain, and won't source from overseas/ebay etc, but is happy for me to source and they will reimburse. I will double check with them in the morning if they have found anything, or if I should go ahead. I now have a spare lower grill, so it might be that I replace the bottom piece BG8A317B and we do a custom top grill made from the spare lower grille ......maybe! |
#1714 | |||
Does my head in that the grille can't be found anywhere, but that definitely seems to be the case. I can by brand new gear for a 60 year old mini, but not for a 15 year old Falcon. |
#1715 | |||
Just need to make sure I can definitely get and get you a price. Leave it with me, see what I can find out. GT |
#1716 | |||
PM me if your interested. |
#1717 | ||
Regular...with metamusal
![]() Join Date: Oct 2009
Hi Legend.
just wondering if you could tell me what model part number 5R29 9F856 BC came from please. it's a memory pedal assembly which i 'think' is from a BF. and if it's from a BF, are the accelerator pedal assemblies the same as the BA's?. Thanks ![]() Ps. you doing/keeping well?. |
#1718 | |||
I cannot get a straight correlation with that number. But the basic 9F856 advises its from an SX SY Territory. For some reason the number you have given does not come up. Will need to see if I can find out more. GT |
#1719 | |||
well that's a strange one?. they are definitely NOT SX/SY. will get the part number from the looms. part number on loom section is - 5R29-12K531-CA with 4 zero's under K531. and good to hear your keeping well & occupied ![]() cheers Last edited by mad2; 22-11-2023 at 10:49 PM. |
#1720 | ||
So the loom part number works and comes out of a BF from 1/10/2005 on Sedan/Fairlane/LTD with auto trans, adjustable pedals and cruise control.
2 users like this post: |
#1721 | ||
#1722 | ||
Hey Gt is ford still producing motor craft branded genuine headlights for the ba bf xr models? Use to see heaps of listings last year off bayford and Jefferson ford, but it seems to have disappeared?
#1723 | ||
Still the odd one around, but no they are not making anymore unfortunately.
#1724 | ||
Hey there GT Legend. I'm after a replacement bolt that goes through the passenger side front diff bush into the diff "wing". Hard to believe, but I've had a tramping issue and that bolt has broken. I get the feeling I'm not on my lonesome with this issue and an IMS rear diff bush setup might be in my future. Already got SuperPro bushes for all 3 rear diff bushes and still the problem persists.
Point me towards an exploded parts diagram and I can find it easily enough. Just couldn't find one after a little searching. EDIT: I just had a look and I'd guess it's an M12. Been a few months since I last dropped the rear cradle. Might help if I add that the car is an FG FPV F6. Stupid me for not adding that up front. Dunce hat on, back in the corner. Again. ![]() Thanks, Ben
It's easier to get forgiveness than permission. Last edited by gonads; 30-11-2023 at 05:04 PM. Reason: Minor brain fart |
#1725 | |||
Are you referring to the ones highlighted in green in the image below? FG Rear Diff Mounts.png |
#1726 | |||
Alternatively, I'll try the part number at the local stealership and see how I go. Thanks again for your awesome service! Cheers, Ben
It's easier to get forgiveness than permission. |
#1727 | |||
Bolts are $30 each plus $11 for tracked postage. Happy to arrange for you. GT |
#1728 | |||
Thanks again, Ben
#1729 | ||
Not counting my chickens but hoping for a listing for 1992 KH Laser boot spoiler end clips. Worst case is silicone haha
#1730 | |||
KF KH Laser Spoiler.png |
#1731 | ||
2 or 22 by the looks. It's on the tailgate side
#1732 | ||
#1733 | ||
Morning @GTLEGEND,
Looking for a catalytic convertor for a '08 BF MKII XR6 NA Ute, are OEM still available and if so, how much? I'm in MEL so interested also in parts location. Can provide VIN if needed. The current cat looks to be the oval shaped one if that helps. |
#1734 | |||
No luck, part is obsolete. Part number you would be looking for is BAF25E211A. GT |
#1735 | ||
#1736 | |||
There's every chance the spoiler was available over there also.
#1737 | |||
#1738 | ||
Hi GT Legend,
Looking for new set of injectors for the 5.4L 3v Barra 220. Can you please confirm if the part number is CM-5144? And what is the price from Ford Aus? Thanks!
~~~~~~~~~~~~~~ Rides (past and present) Current: 2004 Ford Falcon 5.4L 3v Barra 220, Manual Past: Mitsubishi Sigma (m), Toyota Seca (m), Toyota Seca SX (m), Toyota Vienta V6 (m), Toyota Soarer 4L v8 (a), BA XR8 ute (m), T3 TE50 (m), BMW Z4 (m) AFF motto - If contrary views trigger, please use ignore button. ![]() |
#1739 | |||
5.4 3V 24V V8 Injectors had genuine part number 3L3Z9F593BA, obsolete from Ford. GT |
#1740 | ||
Hi GT Legend, me again. Would you be able to give me the part number for the fuel pump for the 5.4L 3v Barra 220 sedan?
I believe that part is also obsolete, but I want to see what equivalents there are out there. Thanks.
