Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 26-05-2024, 10:01 PM   #1951
mad2
Regular...with metamusal
Default Re: Genuine Ford Parts
Originally Posted by 78xcgxl View Post
Wagon loom is different. I have both. They are similar but the looms are different. The actual sensors are the same but. With a wagon you also need the special trailer plug loom to suit the parking sensors. This is what i don't have and will have to try and source one off a wreck.
with the plug all you need is the one with the small magnet fitted.
i have the factory wagooon wiring/sensors one x3. i tried setting up the factory unit quite a few times. even had it working on 'Ol yella [x-taxi wagooon]. but i could never get it going/working properly on the BA M7 wagooon?. i ended up fitting aftermarket sensors with my own wiring [except for the sensor part] and the trailer part [for which i will eventually throw away the factory 12 pin & replace with a flat 7 pin, with a magnet of course!]. all works great now! .... well did till i blew/contaminated the gearbox
cheers
Ps. all you need then is the wiring which you can easily get a hold of. and the 12 pin plug which is easy to find here or here. i will be trialling this one or this one as i don't remember what 12 pin i used? [wired up my own edition with a change to the reverse lights as well].
Old 27-05-2024, 01:37 PM   #1952
daddymac
Hi GTLEGEND
Was referred to you by other members as you may be able to help
2013 Ford FG EcoLpi MKII LPG
We want to order a new oxygen sensor. i have seen some on ebay and other sites but the one they are selling has 4 wires. The one we have is 2 wires. My question is do we need to get a 2 wire sensor or can we use the 4 wire.
Does that also mean that the FG has 2 types of sensors a 4 wire and a 2 wire one?
Strange
Any help would be appreciated
daddymac is offline   Reply With Quote Multi-Quote with this Post
Old 27-05-2024, 05:44 PM   #1953
GTLEGEND
Originally Posted by daddymac View Post
Hi GTLEGEND
Strange
So for LPi vehicles there are two different O2 sensor pending on build date. From 10/2011 to 3/2013 you need 5W6Z9G444BA, from 4/2013 you need BE5Z9G444A. If your not sure, pass on your VIN and we can confirm which one you need.
Hope that helps,
GT
Old 31-05-2024, 03:33 PM   #1954
AussieGreg
I am currently looking at a BA MkII Fairlane and I am wondering what the chances would be in obtaining a Bonnet Protector, Headlight Protectors and the plastic Mud Spats for this Model. A few cars I am looking at do not have them on.
AussieGreg is offline   Reply With Quote Multi-Quote with this Post
Old 31-05-2024, 04:57 PM   #1955
GTLEGEND
Nothing genuine from Ford, keep an eye out on eBay, Market Place etc etc
Old 01-06-2024, 07:32 PM   #1956
swamp
hi
Many thanks
Looking for part no. for Ford Ranger pj/pk and Mazda UN 4x4 model
location /part
front lower inner wishbone bushing [mounted in front position ]
rear wishbone bushing mounted in chassis
bolts nuts washers etc
both wishbones lower inner bushing fasteners ,,position front and rear both LHS and RHS
My vehicle is corroded in that area
swamp is offline   Reply With Quote Multi-Quote with this Post
Old 01-06-2024, 07:40 PM   #1957
GTLEGEND
Originally Posted by swamp View Post
hi
Many thanks
location /part
PJ PK Ranger have different catalogues, so you need to be more specific. If you want to supply a VIN that would be the easiest and then we can look up the relative page(s) of the catalogue.
Old 02-06-2024, 10:36 AM   #1958
swamp
hi GT
Mazda BT50 UN
single/regular cab 3.0lt diesel 4x4 5spd man
del date jun 011
build date 1/11
Vin MM00UNY0E400891415
I read the 0 as Zero from recent Maz dealer road worthy receipt
Old 02-06-2024, 11:09 AM   #1959
GTLEGEND
hi GT
Mazda BT50 UN
del date jun 011
build date 1/11
I don't have access to Mazda so not sure if its entirely the same as Ranger, but below is the front suspension of 2011 PK Ranger 4x4, let me know what parts you need from this and we can go from there.
Old 02-06-2024, 07:22 PM   #1960
swamp
Suspension bushings
lower inner wishbone 2 different bushings / 2 different mountings
2x parts diagrams required
A/ the one u have shown [bushing mounts in wishbone]
B/****chassis picture required [bushing mounts in chassis ]
34-463 front bush
9YA00-1208 bolt plus the washer and nut
9YA14-W601 plus washer and nut
Old 02-06-2024, 07:38 PM   #1961
GTLEGEND
Suspension bushings
34-463 front bush
Is this the other picture you need?
34-463 $25 each plus postage.
9YA00-1208 Need to chase, not coming up for some reason.
9YA14-W601 $20 each plus postage.
GT
Old 02-06-2024, 08:23 PM   #1962
swamp
hi
When looking to find I found a picture in the chassis parts section showing the suspension bushing . This section showed no other suspension components . I will try to get the sections title name .
Chassis,piping and fuel tank >>>> then >>>sub menu chassis and undercover
From an official Mazda o/seas site
Oh yea exactly where the only suspension bush should be ,,really !!! An idea might be to keep it in the front suspension area ,, geeeezus LOL
Old 02-06-2024, 09:00 PM   #1963
GTLEGEND
hi
I guess this pic, part 34460A?
Old 03-06-2024, 05:00 AM   #1964
swamp
hi
Correct
34-460A
Remember when there were 1995 Ford Spectron vans . The rear upper wishbone bush is the same ,, all be it in the 4wd version .
Old 03-06-2024, 02:02 PM   #1965
GTLEGEND
hi
Correct
34-460A
So the 34-460A Bush is $80 plus postage each, the 9YA00-1208 is $25 each plus postage..
Old 03-06-2024, 11:59 PM   #1966
swamp
hi
Thankyou
PS Do Ford only do one version of Torsion rod ??
price and availability please
Maz numbers
Lh,,, UR7634T21
RH ,,,UR7634T11
Old 05-06-2024, 12:46 AM   #1967
GTLEGEND
hi
Thankyou
Maz numbers
Lh,,, UR7634T21
RH ,,,UR7634T11
Yes only one torsion rod.
RH UR7634T11 $130
LH Need to chase and get back to you.
Old 05-06-2024, 01:02 AM   #1968
swamp
hi
The ""other"" unit is nil stock Australia ex Japan my enquires tell me . Is this true ? Waiting 2mth approx is ok
Once the prices are known I will make decision from there
Happy with the price of the in stock unit
Thanks
PS
My research tells me there is no optional factory HD set .
Strong believer in factory style torsion bars in good condition . There is a reason why after market suspension requires shock mount re enforcement ,, way to hard suspension setup .
Old 06-06-2024, 01:20 PM   #1969
swamp
Hi Gt
How is the price and availability looking for the LH , UR7634T21 any info yet ?
Cheers Paul
Old 06-06-2024, 01:37 PM   #1970
GTLEGEND
Hi Gt
Cheers Paul
Hi Paul,
I had to double check as I was in a bit of disbelief.
Ex-Japan $650 with no ETA on when it would arrive.
GT
Old 06-06-2024, 06:25 PM   #1971
swamp
hi
LHS $650
RHS $130
Anyway of enquiring about the price .??
Sounds like someone drunk at there keyboard when setting the price .!!
Not going to say there the same part physically [I did] but wow .
Old 06-06-2024, 06:36 PM   #1972
GTLEGEND
hi
LHS $650
RHS $130
Yeh I am trying another contact whom I am waiting a call back from, will let you know asap..
Old 07-06-2024, 01:52 PM   #1973
GTLEGEND
hi
LHS $650
RHS $130
So confirmed the price of the LHS and that is correct, reason being that it is ex Japan and may actually need to be remade.
Old 07-06-2024, 04:41 PM   #1974
swamp
hi
Do both brands Mazda and Ford get there parts from the same source ??
Who did u enquire thru ??
Old 07-06-2024, 05:22 PM   #1975
GTLEGEND
hi
Ford would get their parts from mazda..
One is through Ford the othe is Mazda..
Old 09-06-2024, 08:40 AM   #1976
swamp
hi
Thanks for trying on the torsion rods
Rear diff drain plug UH7126051
washer to suit UH7126187
sway bar link bolt 9YA001002
washers 018734776
rubbers UH7134152
nuts 999211000 and 999221000
* enough qty to do both sides
bumpstop rebound UH7126187 2 x req
front diff mounting bushes
UR6139540 3x req
UR6139550 4x req
UR6839560A 1x req
rear leaf springs
UR7628L10B
Old 09-06-2024, 03:51 PM   #1977
DJM83
Barra Turbo > V8
DJM83's Avatar
Chasing an FGI 6 cyl Power steering reservoir cap/dipstick, seems the seal on mine has failed. Have searched but come up with nothing.
2011 XR6 Turbo Ute
- Manual
- Lux Pack
- Twin 2.5" Stainless Exhaust
- Antz Turboside Intake
- CCForged Phatlux wheels
- Tuned by LS Tuning and Performance
Old 09-06-2024, 10:02 PM   #1978
GTLEGEND
Thanks for trying on the torsion rods Managed to find one a bit cheaperat $550.
Rear diff drain plug UH7126051 Obsolete but may be ableto source one. Need to confirm.
washer to suit UH7126187 Available $3.50 each.
sway bar link bolt 9YA001002 Only 3 left then obsolete $12 each.
washers 018734776 Invalid number. I have washer UH7234157 at $7 each and 9 left then obsolete. The other is a retainer 022328776 available $34 each.
rubbers UH7134152 Available $3.50 each.
nuts 999211000 15 left then obsolete $9.50 each and 999221000 4 left then obsolete $6.50 each but they need to be sourced interstate so will need freight to get in approx $10.
bumpstop rebound UH7126187 2 x req I think you have wrong number here, this is diff plug gasket. I think you mean UH7434110 $32 each.
UR6139540 3x req $12.50 each
UR6139550 4x req $12.50 each
UR6839560A 1x req $28
rear leaf springs
UR7628L10B[/QUOTE] Obsolete..
Old 10-06-2024, 01:33 PM   #1979
mad2
Hi Legend.
another quick question for you. is there any differance between the replacement fuel pumps re sedan/ute/wagon?. just the pump. and yes most likely obsolete too.
Thank you.
Old 10-06-2024, 02:29 PM   #1980
GTLEGEND
Had a part number of BA3A006A, but long obsolete now.
Need to search the usual places..
