Go Back   Australian Ford Forums > The Sales Yard > Spare Parts and Other Accessory Items > Genuine Ford Parts
Genuine Ford Parts A forum for the purchase of genuine Ford parts via an AFF member.
Old 10-06-2024, 02:30 PM   #1981
GTLEGEND
Default Re: Genuine Ford Parts
Originally Posted by mad2 View Post
Hi Legend.
another quick question for you. is there any differance between the replacement fuel pumps re sedan/ute/wagon?. just the pump. and yes most likely obsolete too.
Thank you.
Hey mate,
What car(s)?
Old 10-06-2024, 02:32 PM   #1982
GTLEGEND
Rear diff drain plug UH7126051: Can get $30..
Old 10-06-2024, 02:44 PM   #1983
DJM83
Barra Turbo > V8
DJM83's Avatar
Originally Posted by GTLEGEND View Post
Had a part number of BA3A006A, but long obsolete now.
Need to search the usual places..
Thanks mate.
Would one from an earlier falcon work, like this one.
https://www.ebay.com.au/itm/15468532...3Avlp_homepage
-2011 XR6 Turbo Ute - Lux Pack - M6 - OEM+ Tuned by LS Tuning and Performance
-2022 Hyundai Tucson Highlander Diesel N Line
DJM83 is online now   Reply With Quote Multi-Quote with this Post
Old 10-06-2024, 04:15 PM   #1984
GTLEGEND
Originally Posted by DJM83 View Post
Thanks mate.
I would say no as they had the different power steer pump, I would say you would need one from BA to FGX..
Old 10-06-2024, 10:17 PM   #1985
mad2
Regular...with metamusal
Hey mate,
What car(s)?
ohh - sorry umm.. BA? [don't think the BF would be any differant?]
Thanks
mad2 is online now   Reply With Quote Multi-Quote with this Post
Old 11-06-2024, 12:58 AM   #1986
GTLEGEND
Thanks
So here are all the combinations of fuel pumps, remember they are a module so from Ford they only came complete, you could not just buy the pump separately from the rest of the module.
Falcon/Fairlane/LTD Sedans.
7/2002 to 9/2007
BA9350A: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (4.0L DOHC VCT EFI OR 5.4 V8 SOHC EFI 24V)
BAT9350A: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (5.4 V8 DOHC EFI 32V OR ALL 4.0 TURBO PETROL ENGINES)
10/2007-
BAF29350A: PUMP ASSY - FUEL (4.0L DOHC VCT EFI OR 5.4 V8 SOHC EFI 24V)
BAF29350B: PUMP ASSY - FUEL (ALL 4.0 TURBO PETROL ENGINES OR 5.4 V8 DOHC EFI 32V)
All Wagons:
BA9350B: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT
Utes
7/2002-8/2007
BAC9350C: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (4.0L DOHC VCT EFI)
BACT9350A: PUMP ASSY - FUEL, FUEL TANK PUMP/SENDER UNIT (ALL 4.0 TURBO PETROL ENGINES OR 5.4 V8 DOHC EFI 32V OR 5.4 V8 SOHC EFI 24V)
9/2007 on
AR2Z9350BA: PUMP ASSY - FUEL (ALL 4.0 TURBO PETROL ENGINES OR 5.4 V8 DOHC EFI 32V)
BAFC29350A: PUMP ASSY - FUEL (4.0L DOHC VCT EFI OR 5.4 V8 SOHC EFI 24V)
Old 11-06-2024, 02:01 PM   #1987
mad2
Many Thanks you Legend
Old 17-06-2024, 06:37 PM   #1988
bondy99
GT,
I've been trying to find out what the part number of the Supply Tank Hose that goes to the radiator, whether it's still available and do you have an image of it?
Reason I ask is mine needs replacement.
I checked Mackay Rubber and they list a completey different hose that shows a straight hose with a upward bend on both ends.
The hose in my vehicle has only one bend.
Vehicle in question
AU2 6 cylinder year 2000.
Thanks
bondy99 is offline   Reply With Quote Multi-Quote with this Post
Old 17-06-2024, 10:38 PM   #1989
GTLEGEND
Originally Posted by bondy99 View Post
GT,
Vehicle in question
Thanks
Hey Bondy,
I guess your talking about the large hose that goes from under the resevoir to the radiator, not one of the other two skinnier hoses.
If it is then I only have a pic from the catalogue,it has a part number of ER8A365AMC. May be able to source you one, but would need to confirm.
Let me know if you want me to chase.
GT
Old 18-06-2024, 03:33 PM   #1990
gonads
Howdy GTL. I'm after a set of 4 pot rear Brembo calipers (from the Premium brake package) to suit an FG, including the mounting brackets and lines if possible. I've seen a couple of sets floating around but I didn't act quick enough or can't drive halfway across the country to pick them up. If figure if anyone can find them, you're the man.
Thanks,
Ben
It's easier to get forgiveness than permission.
gonads is offline   Reply With Quote Multi-Quote with this Post
Old 18-06-2024, 08:56 PM   #1991
GTLEGEND
Thanks,
Ben
Hey Ben,
New or used?
I am sure the rear bracket is part of the caliper and bolts straight to the rear hub.
GT
Old 19-06-2024, 07:50 AM   #1992
Thanks again, for another prompt and personalised delivery!
Old 19-06-2024, 08:51 AM   #1993
mad2
Thank you Legend and Mr. Bender
Old 19-06-2024, 09:03 AM   #1994
GTLEGEND
No problem, happy to help where possible!
Old 19-06-2024, 09:04 AM   #1995
GTLEGEND
Thanks for taking it off my hands lol..this one took up a bit of space!
Old 19-06-2024, 01:01 PM   #1996
mad2
if i had of known who's whom ...... i 'might' have asked earlier
but thanks for your help
Old 20-06-2024, 01:03 AM   #1997
gonads
Hey Ben,
New or used?
GT
I think the Brembo 4 pot Caliper is a generic unit with a Brembo-branded, alloy-coloured adapter bracket to suit the rear knuckle assembly. I could be wrong, but I’m pretty confident the Caliper is red and the bracket is a silver colour.
I’d prefer new, but 2nd hand would be ok if new isn’t an option. I can dig up some part numbers tomorrow if it helps.
Thanks mate,
Ben
EDIT: Yes, the bracket is part of the assembly and is usually included with the Ford part number. I’ll get it to you asap.
Old 20-06-2024, 07:56 AM   #1998
GTLEGEND
Thanks mate,
Ben
Hey Ben,
I can get the Genuine Ford Brembo Rear calipers for FG for around $1100 each side plus postage.
From what I can tell, there is nothing else you need as they come with the brake line and pads, that is unless you need mounting bolts as the bracket is part of the caliper.
Let me know if you want me to source.
GT
Old 20-06-2024, 12:47 PM   #1999
bondy99
Hey Bondy,
GT
Hi GT,
Yep, that's the one. it goes from under the reservoir to the radiator. Let me know if its still available and cost thanks.
Bondy
Old 20-06-2024, 05:42 PM   #2000
GTLEGEND
Hi GT,
Bondy
Still available $60 plus freight..
Old 20-06-2024, 09:41 PM   #2001
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Hi GT,
Just a query on a SZII Territory Titanium 2016.
Are the indicator lenses/clear cover on the LH side mirror available to purchase separately ?
or do you have to purchase the whole mirror assembly ?
Regards,
Old 20-06-2024, 10:42 PM   #2002
GTLEGEND
Originally Posted by galaxy xr8 View Post
Hi GT,
Regards,
Hey mate,
Well originally you could buy the lens seperately (part number 9R7Z13B383BA) how ever that part has become obsolete and you have to buy the whole mirror assembly. Would need to confirm exactly, but the mirror assembly is around the $400 mark. If you want me to chase one for you with a definte price, let me know.
Cheers,
GT
Old 21-06-2024, 10:51 AM   #2003
galaxy xr8
Giddy up.
galaxy xr8's Avatar
Hey mate,
Cheers,
GT
Thanks mate, I'll sit on it for now and let you know in the future if I head in that direction.
Cheers.
Old 21-06-2024, 08:03 PM   #2004
GTLEGEND
Cheers.
No worries, dont leave your run too late as there is only a limited number of those left too!
Old 21-06-2024, 08:42 PM   #2005
bondy99
Thanks GT,
Send me a pm with details.
Old 28-06-2024, 12:53 PM   #2006
crmpicco
crmpicco's Avatar
I’m chasing a couple of parts for a 2013 Ford Falcon FG MK2.
Windscreen washer bottle
Power steering hose
I’m wondering if GTLEGEND still has access to parts and what the cost of both would be to ship to WA.
2013 Falcon XR6 FG MKII Kinetic Blue
Craig R Morton -WA-based Web Developer
crmpicco is offline   Reply With Quote Multi-Quote with this Post
Old 28-06-2024, 01:38 PM   #2007
GTLEGEND
Power steering hose
Windscreen washer bottle is obsolete, I would need to see if I can track one down.
As for the power steering hose, you need to be a bit more specific, return or supply hose, what sort of Falcon is it, 2.0,4.0 or 5.0. A VIN would help but not essential if you can provide specific information. There are a few variations.
Old 28-06-2024, 02:36 PM   #2008
crmpicco
crmpicco's Avatar
Would this one fit my Falcon? By the looks of it, it would but I noticed the part is listed as “Ute”.
https://www.ebay.com.au/itm/33511133...mis&media=COPY
The VIN is 6FPAAAJGSWDU24780
Old 28-06-2024, 05:32 PM   #2009
crmpicco
crmpicco's Avatar
Hi again mate, it’s a 4.0 L Falcon FG MK2 XR6 and it’s the pressure hose which I understand to be the pricey one. I have called the local Ford dealership here in Rockingham and they have said there is no availability showing and they will need to contact their distributor up in Welshpool near Perth.
Do you have any availability of this part?
Old 28-06-2024, 06:28 PM   #2010
GTLEGEND
Sedan and ute have the same bottle, how ever FG1 is different to FG2 and FGX (the later 2 are the same) so if it is an FG1 style it wont fit your car being an FG2.
