21-05-2012, 09:05 PM | #61 | ||
Performance moderator
Trust me synthetic oils run MUCH cleaner than Dino oils..
I've pulled down 1000's of imported U.S V8's.. Some engines you couldn't see the valve gear when taking rocker covers off.. Yes that as much an oil change issue too... It's a bit like eating Mcdonalds or Steakhouse food... One is cheaper.. BUT ?? !!!
21-05-2012, 11:40 PM | #62 | |||
21-05-2012, 11:51 PM | #63 | ||
More important than semi or full synth is the frequency with which you change your oil... Every 5K if you're hardcore (or have a built engine). This ensures longevity of an engine more than anything else.
22-05-2012, 02:18 AM | #64 | ||
SY TS AWD LPG TEZZA
On LPG the oil doesn't dirty up at all compared to petrol. I change mine at 10000km but use the best oil I can get (and believe in). I don't drive my cars hard though.
1st car 75 XB Fairmont wagon 302C converted to 351C. 2nd car 82 ZK Fairlane 351C 4spd AOD LPG/Avgas 3rd car 97 EL Falcon police car 4L auto dual fuel 4th car 90 XF ute (work car) 5th car 06 SY TS AWD Territory Orbital LPi 6th car 95 XG ute 7th car 2014 SZ Territory TX Petrol Fords all my life. |
22-05-2012, 09:49 AM | #65 | ||||
Rob
23-05-2012, 06:13 PM | #66 | |||
My engines mains have no oil pressure from the oil pump and nor does the cam and it's a OHC and it does 11000 RPM and i have been into it for 3 years now. it has pressure to the big end and that feeds to splash under the piston. But like i said oil does not need pressure to work, as that is another subject. Oil is oil and pressure is just pressure. |
23-05-2012, 06:18 PM | #67 | |||
23-05-2012, 06:23 PM | #68 | |||
Your way out of your league here!!! What OHC engine revs to 11000RPM ??
23-05-2012, 08:21 PM | #69 | |||
VFII SS UTE
clearly your driving a 1932 rolls royce, the only engine in the world to use the splash system with spectacular failure.
I don't often hear the sound of a screaming LSX. But when I do, So do the neighbours.. GO SOUTHS
24-05-2012, 07:54 PM | #70 | ||
Early Briggs and Straton lawn mower engines are splash feed.. Along with Chev engines before the Blue flame 6 cylinder which work well at low rpm..
There are no modern engines using this oil lube system... http://www.waybuilder.net/sweethaven...um=3&modNum=13
24-05-2012, 08:09 PM | #71 | ||
i change my oil and filter every 10,000. The old oil is still clean, just has a little darker colour to it. engine is 200,000kms on it. I use moblie 2000 its semi synthic. cooper filters.
the oil splash system is still used today isn,t it? as it helps lower cylinder lubrication, is my understanding. |
24-05-2012, 08:20 PM | #72 | ||
VFII SS UTE
lawn mowers still, brigg/stratton, honda, howard.
24-05-2012, 08:25 PM | #73 | |||
VFII SS UTE
the system ok in level staionary units. lawn mowers have a limit of 20* angle off horizontal plane.
24-05-2012, 09:02 PM | #74 | ||
Twin cam heads are pressure fed or at least have oil galleries feeding critical parts..Some early twin cam engines such as Nissan , Subaru had issues when not serviced .. The galleries would choke up and valve gear would fail...
The new Subaru's, Nissan's have larger oil galleries now.. Some sliding parts are lubricated by the oil mist that flows through engine.. Hardly splash fed the way engines where done with crank scrappers picking up the oil.. Besides there's issues when oil level drops and the level engine operated on.. Honda's etc these days have an oil pump in them feeding the crank...
24-05-2012, 09:16 PM | #75 | ||
VFII SS UTE
my honda (hr194) lunched it self when mowing a slope in the front yard, slinger fed setup.
no info in the book but online honda states 25* slope max.
24-05-2012, 09:46 PM | #76 | |||
Yes o/k on stationary engines..just !!! On OLD boat engines were oiled by hand with open crankcase... VERY low rpm and long stroke.. Lubed be a guy with oil can..Sheesh !!
24-05-2012, 11:23 PM | #77 | ||
SY TS AWD LPG TEZZA
I can't believe I'm reading about splash lubrication here, on a Ford forum in 2012. Maybe this is the Fordson 1922 forum.
25-05-2012, 01:48 PM | #78 | ||
Older 2 strokes were lubricated by oil mixed with the petrol that circulated around the crankcase, and some of them seemed to go for ever.
25-05-2012, 02:16 PM | #79 | |||
Briggs&Stratton and Honda recommended there own oil, SAE30, and SAE10W/30 respectively I am in the oil field, communicate with them all the time Last edited by RASER; 25-05-2012 at 02:43 PM. |
25-05-2012, 02:27 PM | #80 | ||
"erwgbwer
25-05-2012, 04:26 PM | #81 | |||
VFII SS UTE
would be an early 50's unit, at my sisters place for a lawn ornament. possably run if i could find/make a carby for it.
25-05-2012, 06:02 PM | #82 | ||
i have a 6' howard slasher
25-05-2012, 07:11 PM | #83 | |||
I started using fully synthetic oil in my au with about 140 odd on the clock and it actually stopped my timing case leak so make of it what you will.
Big dreams, not enough money Smoke tyres, not drugs |
25-05-2012, 08:21 PM | #84 | ||
SY TS AWD LPG TEZZA
Synthetic oil in my XF stopped a large timing chain slap. Well it appears to have for now.
26-05-2012, 04:10 PM | #85 | |||
Mains are bathed in oil and the timing chain feeds the top end. So you know that pressure is only one thing and the oil does the work as oil pump pressure is only pressure feeding to where it has to be for a reason and that's all. So if it needs pressure it has to do with why it needs it, oil is oil. |
26-05-2012, 04:22 PM | #86 | |||
29-05-2014, 11:44 PM | #87 | ||
Hi all, I'm running nulon semi 10 30, in 2001 xr6 engine about 70k km on clock. Nulon have a full syn 10 40 thinking of using? As about to replace lifters, and getting the tick ford tick! On inlet 1 or 2. Any input welcome! Probs bite the bullet next week, also nason or dynotec lifters? Cheers.
29-05-2014, 11:54 PM | #88 | ||
Old thread, nice bump :P
You shouldn't have any issues with it, I run my BA on 5w-30 full synth with nearly 150 ks, other people run 15w-40 (I personally wouldn't). |
30-05-2014, 12:02 AM | #89 | ||
When in doubt, GAS IT!!
switch to Penrite HPR 10W-50 and your tick will probably go away.
Our wagon has 350k on it now and I've tried Nulon and Valvoline and Mobil but I always came back to Penrite and have stuck with it now for the last 150k and the motor is still happy as with no ticks.
. HERS- BFIII Wagon Gold, alloys, dual fuel, bullbar, big tow pack, trans cooler, fully rebuilt HD suspension, Clarion, alarmed, full 2 1/2" sports system, mint body MINE- AUII Forte Meteorite, dual fuel but otherwise bog stock. MINE- AUII Fairlane Sportsman Liquid Silver over meteorite,HIDs', Airhog, Eagle Leads, dual fuel, custom rear springs, BA slotted discs + a second one for spares . Last edited by Bushbasher; 30-05-2014 at 12:09 AM. |
30-05-2014, 12:59 AM | #90 | ||
Thailand Specials
Whats the consensus on Penrite Racing 5W-30 fully synthetic for a road car? I used it in the WS Fiesta which used to run Shell Helix Ultra Extra 5W-30 and it stopped lifter tick on cold startup which would occur until the engine was up to operating temp.
Car is serviced by me every 10,000km. |
