Go Back   Australian Ford Forums > Club and Speciality Forums > Ford Car Clubs > Ford Coupe Club of Australia > Technical Area
Old 22-04-2012, 07:34 PM   #1
Tha Jack
Legend!!!
Tha Jack's Avatar
Default XB Warning lights???
Hi,
Are all three warning lights Seatbelt-Brake-Alternator supposed to light up when you turn on your ignition before starting.
I noticed only two seem to light up.
Cheers Jack
BARE BONES RACING
BACK TO THE BONE YARD
Tha Jack is offline   Reply With Quote Multi-Quote with this Post
Old 22-04-2012, 07:54 PM   #2
Jim Goose
Default Re: XB Warning lights???
Ahh checked bulbs?
Which one doesnt work?
You've seen it, you've heard it and your still asking questions??
Don't write off the Goose until you see the box going into the hole....
Jim Goose is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2012, 06:56 PM   #3
Phil B
Clevo power!
Phil B's Avatar
I'm pretty sure I only get the alternator one light up so I'm curious as well. I haven't checked anything yet though
The beast: XB coupe, 302, manual all the way!
Fixing up thread
The purple monster, daily BA XR6 turbo.
Scale Lego Technic XB Coupe with working bits! Build thread
Phil B is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2012, 08:01 PM   #4
Apollo66
My toy
Apollo66's Avatar
Location: South Ozz on the only leg Australia has to stand on
Alt lights up before starting
Seat belt should light up for a short time. (5-10 sec's) mine will sometimes.
Brake light will anly light up if you have a problem with the brake system.
Apollo66 is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2012, 08:13 PM   #5
Jim Goose
Brake light will come on as a self test when you turn the ignition on... unless you turn it off and on again in a short period of time (within a few seconds).
If the brake light doesnt come on with the ignition you have NO way of knowing the light works...
Old 02-05-2012, 08:51 PM   #6
Tha Jack
Legend!!!
Tha Jack's Avatar
Yeah its the brake light that doesn't light up.
I've changed the globe but it still doesn't light up.
BARE BONES RACING
Old 02-05-2012, 10:26 PM   #7
kahless351
kahless351's Avatar
The brake light only lights up while cranking, if it stays on then your fluid is low.
kahless351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2012, 12:02 AM   #8
Apollo66
My toy
Apollo66's Avatar
Pull the plug and bridge the pins and the light should work. If not there maybe a connection problem in the loom somewhere.
When there is an imbalance between the front & rear brakes the switch mounted in the master will activate.
Cheers Kerry
Old 03-05-2012, 03:09 AM   #9
GTB 351
GTB 351's Avatar
Just unplugging it should make the light come on.
The Car -
http://www.fordforums.com.au/showthread.php?t=11358570
The Engine Rebuild-
http://www.fordforums.com.au/showthread.php?t=11361067
GTB 351 is offline   Reply With Quote Multi-Quote with this Post
Old 03-05-2012, 12:21 PM   #10
Tha Jack
Legend!!!
Tha Jack's Avatar
Will give it a try. Thanks Guys!!!
BARE BONES RACING
Old 04-05-2012, 12:07 AM   #11
Snake Bite
Snake Bite's Avatar
s#$it ive never looked
Cobras Rock
Snake Bite is offline   Reply With Quote Multi-Quote with this Post
Old 16-06-2012, 07:35 AM   #12
TheGTCoupe
TheGTCoupe's Avatar
haha ever since seeing those lights on mad max i always look
TheGTCoupe is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2021, 05:04 PM   #13
bear351c
BEAR
Bumping an old thread, does anyone have a photo of the seat belt light relay.??
Think it's a long thin metal relay.? My light is coming on when I press the horn.
If you're still in control.....you're not going fast enough.
bear351c is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2021, 08:54 PM   #14
73 4V XB
Frankenford pilot
73 4V XB's Avatar
This one.
Cheers Bretto
73 XB GT
Last of the Big Ports
73 4V XB is online now   Reply With Quote Multi-Quote with this Post
Old 14-02-2021, 06:34 PM   #15
thefargo
black xb
thefargo's Avatar
check your earth feed
thefargo is offline   Reply With Quote Multi-Quote with this Post
Old 16-02-2021, 12:32 PM   #16
bear351c
BEAR
Yeah, was thinking the earth/ground. Trouble is it's intermittent, sometimes I press the horn and it beeps, other times the seatbelt light comes on.... will continue exploring.
