26-02-2008, 06:27 PM | #1 | ||
Knowing that my current auto is shagged I'm wanting to replace it with a manual.
Problem is I have my auto license so I have to get the condition taken off it by re sitting the license test in a manual car. Yesterday my mate was drunk so I had to drive him home in his heavy clutch 5speed VL and didn't have any problems. But I'm going to get 3 lessons or beforehand. I just got a few little questions regarding how to drive them (Some might be hard to understand). When I was in reverse in his car with the clutch fully "up" his reverse was rather fast, Once at friction point the more I bring the clutch up the faster it went in reverse. So should I bring the clutch completely up (engaged?) and then use the brake to control my reversing speed like in my auto, or do I reverse with the clutch say 4/5s up/use the clutch to control my speed? When changing gears do I completely take my foot off the accelerator and only reapply my foot to the accelerator after I have fully engaged the next gear? Again with gear changes if I bring the clutch up too fast will it stall? (I know this is the case on takeoff). When slowing to a stop from even 5th gear my old instructor (I had 2 manual lessons in the past) taught me to down gear form 5th>4th>3rd>2nd>1st>then clutch in at stop. On my mates car you can just leave it in 5th until you need to put the clutch in at 3kmph or something like that . Which way is the right way? Everything else I'm pretty solid on from my previous lessons and logic.
EB II 1992 Fairmont - koni reds, wade 977b, 2.5inch/4480's and much more to come! |
26-02-2008, 06:36 PM | #2 | ||
Ya Joking right?
It is all common sense & everyone should know answers to the questions you have asked, use your feet & brain at the same time & it is easy :P And YOU had 2 lessons from a teacher, more than I had & I started Driving a manual with no help when I was 12 lol |
26-02-2008, 06:36 PM | #3 | ||||||
Former BTIKD
26-02-2008, 06:40 PM | #4 | |||
26-02-2008, 06:43 PM | #5 | |||
With the reverse if I need to go slower do I use the brake or is it basically impossible to reverse slower in a manual?
26-02-2008, 06:46 PM | #6 | |||
It is your accelerator that controls the speed in a sense not the clutch, that enables the gear / reverse mode |
26-02-2008, 06:47 PM | #7 | |||
Ha Ha Ha Ha, try using the Brake & Clutch along with less go Pedal to go slower in reverse or turn ya Mates idle down as either his car is idling at 2500 rpm or you are using too much Throttle :P Or you could try flooring it in reverse & when fast enough swing the steering wheel hard either way & as you do that reef on the Handbrake & as you are sliding into a 180 engage 1st & get ready to floor it when you are facing the direction you wish to travel LMAO Is what we used to do at your age & in the Wet as well lol Sorry could not resist |
26-02-2008, 06:56 PM | #8 | |||
The idle could be a part of it it, I know it idles high I can't remember a figure but it sounds like my car when it's at 1700RPM or so but I doubt it'd be that high lol.
26-02-2008, 07:25 PM | #9 | ||
The gearing for reverse is shorter than the forward gears, so at the same rpm the car will go faster than if would in 1st. It can be tricky sometimes if you are in a car you haven't driven before but most people (men anyway...) work it out pretty quick.
Generally the clutch accelerator thing is exactly the same as taking off in first but a little more sensitive because of the gearing. Also i'm not sure what everyone else does but personally, i don't shift into first while the car is moving unless i'm trying to get a bark from the exhaust to scare some pedestrians. |
26-02-2008, 07:26 PM | #10 | |||
let it burn
Auto has the stall converter, meaning you can brake at idle and the car wont stall. Manual does not, if you use the brake and the car is moving too slowly, the car will try to stall unless you use the clutch. So clearly you need to use the clutch. Most situations like reversing into a parking spot etc, you dont ride the clutch, you should always avoid riding the clutch as per above reasons of nasty expense. When youd put your foot on the brake in an auto, treat a manual the same but put your left foot on the clutch to take the drive force off the wheels (basically, your foot and the clutch are the stall converter). Just remember when your foots on the clutch, theres no engine drive like an auto has dragging on the brakes with feathered brake, so you use less brake in the manual as its simply rolling. youll work it out. |
26-02-2008, 07:29 PM | #11 | ||
When reversing, you usually just engage it fully with your foot very gently on the accelerator, if you are going too fast, brake and put the clutch pedal in if its going to stall.
If you want to keep the speed slow and more controlled eg, very slow backing out of parking spaces etc, you can sort of ride the clutch a bit (engaging for a second and then disengaging while giving it some gas), but you can wear out the clutch if you keep it at that contact point for too long all the time. The same applies for when driving forward in slow moving traffic. Yes take your foot right off, but practice a smooth motion when applying throttle again while engaging the clutch, giving it a few revs at the time the clutch engages will make a smoother change. It won't stall because it can't stall as long as you are moving, but usually if you engage it too fast the change will be a lot rougher. Changing down through the gears (engine braking), helps slows the car down and puts less strain on the brakes as they're not doing all the work to stop the car. It depends how fast/slow you are going and the situation though, (Sometimes you skip gears, eg. you might be going to slow and changing to 3rd won't do anything so you go straight to 2nd.) I'm usually going slow enough when I reach 2nd then put the clutch in and/or slot into Neutral, and stop. Just give it a bit of practice though, it will all come naturally soon enough.
2003 BA Fairmont Ghia 4.0 Blue Pearl |
26-02-2008, 07:36 PM | #12 | |||
let it burn
I think its some idea about constant control of the vehicle or similar, its what I was taught anyway just for the tester, dont go skipping gears. |
26-02-2008, 07:55 PM | #13 | |||
26-02-2008, 07:56 PM | #14 | ||
i agree with every thing sloth said but for reversing in a V8 i can just use the cluth without reving but when i drive my LPG 6 i cant. i didnt skip any gears in the test but now i do :
Many Thanks 2001 AUII Factory LPG Manual XL Styleside Box High series bonnet Clear Side Indicator K&N Air Filter BAXR6T Snorkle Low Fronts, Super Low Leafs |
26-02-2008, 07:57 PM | #15 | |||
Living the dream
After the test, drive how you feel comfortable. A combination of engine braking and conventional brakes, whatever suits the situation. Example, you wouldn't bother faffing about with selecting 5-4-3-2-1 if you need to pull up hard on the highway from 100kph. Slam on the anchors and depress the clutch, ferk what gear its in. |
26-02-2008, 08:36 PM | #16 | ||
On the topic of skip shifting, my instructor said that skipping was fine. I could only see it as a problem if you can't do it properly. Spose you could always ask before you proceed?
As for changing gears, if you drop/release the clutch too fast, you can shock the drivetrain. Really depends on how fast and what car you're driving though. |
26-02-2008, 09:27 PM | #17 | ||
My boyfriend taught me to drive his manual Pursuit 250 (oh yeah I got taught in style!) and while I still havent sat my manual licence (yes I'm slack) I feel quite comfortable driving it.
Tips from me, when reversing as the guys have said gently let the clutch out, braking when necessary and "massaging" the clutch so that the revs dont drop and she doesnt stall. I have strict instructions NEVER to put the car into first until she is at a complete stop, so for example, I'm in 4th, need to slow down for lights, clutch, 3rd, clutch, 2nd, clutch, brakes to a complte stop then into 1st. But as the other guys have said, if you need to pull up quickly, brakes and clutch, then whatever gear is necessary but i still dont skip ie while the clutch is in I go from 5th, to 4th, to 3rd etc cos it does syncro damage if you miss the gears for example 5th to 3rd or 4th to 2nd is a big no no, ( at least in my boyfriends books!) Hope this helps, it feels awkward at first if all youve driven is an auto but it'll soon become second nature and you'll really enjoy it. I have an auto T3 TS50 now and I wish I had of held off for a manual cos I miss it....
Previous proud owner of a T3 TS50 Blueprint Build no. 196 and a Pursuit 250 Blueprint - both gone to a new home in NSW
26-02-2008, 10:02 PM | #18 | ||
Fiat POWAAH!
When you get real good, once the car is moving you won't even need the clutch ;)
26-02-2008, 10:11 PM | #19 | |||
LOW AND SLOW
"Any Color You Like As Long As It's Black, Matt Black, With Flames, And A Bit Of Pinstriping". |
26-02-2008, 10:12 PM | #20 | ||
Lucifer's Angel
You'll get a hundred different answers here, so your best bet is to go and have a couple more runs with a driver trainer.
They can teach you the way things have to be done for the test, and then as you become more comfortable/lazy, you'll work out whats best for yourself, your car and your driving style. I tend to "feather" the clutch when reversing into parking spots and such. For the amount of time you spend doing it, I can't see too much of a problem. I learned and did my driving test in one, because Dad said there was no other way to go. Then I drove an auto for 5 years, until I bought the BA, and had to remember how to drive a manual quick smart when driving it home from the auction centre in peak hour traffic. Now I have upgraded to a HR licence on a crash gearbox, and actually feel a little lost when I have to drive autos.
SINISTER BA XR6 Blueprint, manual, 4490's, Redback 2.5" dual exhaust, BA Typhoon rims, tint, fog light covers, BF tailights, blue illuminated window switches, Ghia bootlid carpet, lower grille, FPV door spears, steering wheel & interior bits, XR6T + F6 intake, K&N filter, Typhoon spoiler, tuned, sway bars, custom angel eyes & plates..YUM!
If there's one thing guys in Holdens hate more than being beaten by a Ford... It's being beaten by a girl driving a Ford |
26-02-2008, 10:20 PM | #21 | ||
i'm baaaack....
learn to double clutch and use engine braking instead of brakes
also saves lockups when going down gears if you like to drive hard... |
26-02-2008, 11:08 PM | #22 | |||
Sleeping Beast
26-02-2008, 11:15 PM | #23 | |||
i'm baaaack....
26-02-2008, 11:23 PM | #24 | |||
Cane Farmer
Just drive by feeling with a manual...That's what I do. And remember, slow is smooth...smooth is fast!
1994 ED XR6T - Cobalt Blue. 2009 FG XR6 - Black. Quote:
26-02-2008, 11:37 PM | #25 | |||
My instructor was really really impressed with my gear changes, but I lacked smoothness at take off. Now due to just plain experience in my auto thought coped fine with it yesterday.
26-02-2008, 11:40 PM | #26 | |||
Cane Farmer
I find that locating the rev limiter and dropping the clutch works well with take offs.
26-02-2008, 11:53 PM | #27 | |||
27-02-2008, 12:09 AM | #28 | |||
27-02-2008, 01:31 AM | #29 | ||
V8 Ute V8 Boat
when taking off just rev it up to redline and let go of the clutch then you wont stall it.
WARNING it my leave rubber
VE SS Ute manual 09 AU XR8 UTE 200KW manual 02 Challanger Ski boat V8 01 125 Thumpster 2010 Swag All set for the weekend |
27-02-2008, 11:33 AM | #30 | |||
_Oo===oO_
