Old 05-04-2010, 03:24 PM   #1
baz
Default 2001 cougar brakes
I don't like the amount of travel in my brake pedal, Its a manual and i've had new brake pads installed, the brakes are not spungy just seem to go half way to the floor, is this normal with these cars ?
baz is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2010, 09:05 AM   #2
thearrow
Check your brake fluid level and if it is OK take it to your mechanic and have your system checked for leakages.
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 06-04-2010, 06:28 PM   #3
baz
Default cougar brakes
thanks, but the fluid level is fine and there does not seem to be a leak
Old 07-04-2010, 12:24 PM   #4
thearrow
As the braking system is hydraulic get the brake booster checked it could be that it is not operating up to the correct pressure. There must be a reason for it as it is not normal. Just a process of elimination to find the fault.
See how you go and let us know also if you need a new one let me know.
