Old 11-07-2011, 05:31 PM   #1
auxr
auxr's Avatar
Default auxr8 coil pack installation
Sorry guys, have exhausted all the usual how to threads but I can't locate anything on how to install coils packs and an ignition coil to a AU XR8 series 2, 220 kw motor.
Can anyone point me in the right direction.
auxr is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2011, 06:02 PM   #2
AUIIPURSUIT
pursuit ute baby
AUIIPURSUIT's Avatar
Default Re: auxr8 coil pack installation
draw down your current config, then remove, replace, reinstall.
pretty easy?
my ride : AU xr8 pursuit ute
AUIIPURSUIT is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2011, 06:15 PM   #3
auxr
auxr's Avatar
Thanks AUIIPURSUIT - thought it was relatively simple, but didn't know if there were any special tools required.
Ignition coil is the same process ?
Old 11-07-2011, 06:39 PM   #4
FTe342
FTe342's Avatar
coil packs are the ignition coil
T3 TL50 #147 Silhouette Auto ESS - Brembos - Last of 3 in T3 spec, only AUIII TL50 ever built -14.2 sec @ 98mph bog stock. Only customer ordered T3 TL50 built, only LWB sedan plated AUIII and the last performance enhanced LWB sedan built by Ford Aust.
AUII Fairlane Ghia Sportsman 5.0L in Blue Pearl
OWN THE ROAD
FTe342 is offline   Reply With Quote Multi-Quote with this Post
Old 11-07-2011, 06:45 PM   #5
auxr
auxr's Avatar
FTe 342 - that's what I thought - the two error codes showing were
1) - cam sensors
2) - ignition coil.
So, if that's the case - should be easy peezy - thanks for the replies.
Old 11-07-2011, 08:18 PM   #6
AUIIPURSUIT
pursuit ute baby
very simple mate.. no special tools.. just get the cylinder numbers written down so the firing order is correct.
Old 20-12-2023, 12:11 PM   #7
david lee
how easy is it to change the coil pack on a au xr6
david lee is offline   Reply With Quote Multi-Quote with this Post
Old 20-12-2023, 05:42 PM   #8
As easy as for and EF Falcon. So much easier done from underneath the car or above by someone with long thin fingers and the air cleaner box and associated air inlet ducting removed. Make sure you reconnect the wiring for the adjacent suppressor capacitor as it also supplies a required earth for the ignition system. Worth looking to extending the associated low tension wiring and relocating the coil pack to somewhere more easily accessible (fender, firewall or on top of the inlet manifold) at the same time perhaps using this as a starting point : https://www.ebay.com.au/itm/15286083...Bk9SR760rNyQYw
