Old 17-08-2007, 01:25 PM   #1
simonr
Focus Rookie
simonr's Avatar
Default eBay: 2.3L Duratec Engine
Can someone please buy this!!
http://cgi.ebay.com.au/2-3-litre-For...QQcmdZViewItem
04' Panther Black Focus Zetec
Custom Euro Plates, ST side indicators, MK2 Badges, ST Snorkel, White 17"s, Exhaust, Springs, Volant Intake,Angel Eyes, Body Kit, St170 Lower Grill, F/C Throttle Body, DBA slotters
simonr is offline   Reply With Quote Multi-Quote with this Post
Old 17-08-2007, 01:39 PM   #2
BlackLS
Asking a bit much IMHO. Although new etc; getting one from a low km wrecked escape/tribute could be a LOT cheaper. Not sure if this has VCT or not.
If the latter, perhaps its a straight dropin to replace the 2.0L
Also the ebay article says that its good for supercharging/turbo over the 2.0L; the 2.3L has weaker rods over the 2.0L and where the 2.3L can only take 7-8PSI stock safely, the 2.0 can handle 10-11PSI.
Old 17-08-2007, 01:55 PM   #3
melbzetec
Old enough to know better
melbzetec's Avatar
Also probably doesn't come with an ecu, and if it did would be tuned differently to a Focus.
Would be interesting to find what a wrecker would charge for a Mazda SP23 engine.
Was probably for a Caterham type project...Backed out because it was all too hard with an escape engine?????????
Old 17-08-2007, 02:12 PM   #4
BlackLS
The only thing I can see being a problem with the tune is the fuel mixtures with it not knowing how to ritchen the mixture for the extra 300cc. A dedicated fuel computer would overcome this quite well.
If you tried to put the Mazda SP23 engine and its ECU into the LS; the ECU wouldn't match the igntion barrel/key transponder/BEM?. You'd need their ecu as well and possibly the engine loom to be able to control the VCT.
Old 17-08-2007, 05:47 PM   #5
FRA
Mr Focus
FRA's Avatar
If your looking to mod this engine, Mazda SP23 and Focus 2.3L USA have some different engine parts.
Cosworth: 2.5" high flow exhaust system, piston & rod 8.5.1 Ford Racing: Tail lights, engine cover, racing wing, cnc'd head, manifold, 70mm tb. Lentech: Torque Convertors with 23 spline input shaft, valvebody
Oz racing: WRC OBX: 4-2-1 race header
SCT: xcal3, dash scan.
FRA is offline   Reply With Quote Multi-Quote with this Post
