05-11-2011, 05:22 PM | #1 | ||
I was embarking on replacing my rad hoses this morning and the top rad hose outlet disintegrated.
I figure that now I am going to have to replace the rad. I am not sure what replacement rad to buy though. I run a PWR trans cooler in series with the rad but now think I will bypass the rad. Would I now buy a rad minus the internal trans-cooler component? Does such a product exist? Finally, are there any brands of rad I should avoid? Thanks again. |
05-11-2011, 05:37 PM | #2 | ||
I bought a ford rad when mine split. Buy a manual falcon rad that wont have the cooler inside it.
AU XLS. |
05-11-2011, 05:50 PM | #3 | ||
You can just get the end tank changed over, instead of a new radiator, but a radiator shop would have to do it, and they'd rather sell you another one.
Personally i'd buy a genuine Ford one (manual, without the inbuilt cooler) like Beer Baron said. And definitely just use the PWR cooler, as the auto radiators have a tendancy to split inside, and mix your auto fluid with coolant. |
05-11-2011, 05:54 PM | #4 | |||
AU DIE HARD
Got mine off Fleabay for $80 2 years ago . no problems
http://www.ebay.com.au/sch/i.html?_n....c0.m270.l1313
05-11-2011, 07:19 PM | #5 | ||
Bugger!
Assuming you have the cash, get a rad shop to fit ally side tanks. Expensive, but those stupid plastic tanks'll never crumble again!
Whoops, there goes another factory setup! Chop and change - butchering cars since 1990 |
05-11-2011, 07:39 PM | #6 | ||
Replace the rad with a better unit from NatRad or the likes ... I went with one of their ADRAD units ... no plastic end tanks ... better internals.
I'd suggest getting a manual version as well and just bypass the transcooler lines from the rad altogether.
05-11-2011, 08:48 PM | #7 | ||
Anyone have opinions on either Repco or 'Motorcool' radiators.
My local Autopro have the motorcool ones and reckon they are rebadged Jayrad units........but my ********-o-meter went off and I thought I would come here and ask first! |
08-11-2011, 04:27 PM | #8 | ||
JCTO AUII Falcon
I got one on special from ADRAD....copper core and brass tanks for $180.00, helps to know people in the industry and picked up from ADRAD on cash sale. This is of course in Perth.
08-11-2011, 08:25 PM | #9 | |||
AU XLS. |
09-11-2011, 01:44 AM | #10 | ||
imo if the radiator is that old that the end tanks are crumbling, it`s time for a new radiator, i would`nt bother with fitting new end tanks.
i`don`t know if any of you guys think the same, , but i have a use by date in mind for these alloy cored radiators, my first one i found a pin hole so small it was`nt really leaking any noticeable amount, but had a small green deposit of dried coolant colored bird poo on the core of the radiator at about 5/6 years old, but it was definatly on the way out, i only found it because i was fitting an oil cooler at the time, i`m in 2 minds about getting an after market one with a copper core, i don`t think there is much cost difference between them and the factory alloy one. |
09-11-2011, 07:31 PM | #11 | |||
AU XLS. |
09-11-2011, 07:54 PM | #12 | ||
good stuff, thx Beer Baron, you made up my mind for me, i`ll go the copper, for my next one, all this modern light weight alloy and plastic.... progress.....eek
