Hi All,
A new LW Focus Trend joined the family beginning of December last year. I'ts got over 3400km on the clock now. Been very happy with features and and performance so far. The only issue I have is that when I put the aircon on recirculated air, it switches back to normal outside air after 5 minutes. When I mentioned this at the 3000km service they said they couldn't reproduce it, obviously not tested it. Is this an issue? Or is it a setting that can be changed? Thanks in advance. |
A few screw loose
Welcome.. am a Focus Trend owner too. About 3,000 km on the clock. Have yet to get the "check up" done. I did notice about the recirulated air thing. I find it quite odd it switches to outside air after awhile. I'm not sure if it's an issue but probably a setting. Not sure how to change it though.
It would be a safety feature. Saw a bit on TV last week about the very quick buildup of carbon dioxide levels inside cars when aircon set on recycle. The levels get very high and causing drowsiness.
Very smart feature that should not be ältered. |
happens in my LT focus as well. a bit longer than 5 minutes i think, but definitely happens
also changes to fresh air automatically if i change it to de-fog the front windscreen also the rear windscreen de-fogger also turns off after a certain amount of time, not sure why |
This happens in our LW Sport (with climate control). Looks like it's a "feature" . Bit annoying though.
#6 | |||
#7 | |||
Tried it on my LW Sport, and after 15 minutes it was still on recirc!
I'll tyr again tomorrow on a longer trip.
Thylacine ![]() LW Focus Sport Diesel Kuga Trend Diesel |
#9 | |||
Tried it again today. After 35 minutes it was still on recirc. I wish it would turn back to fresh air because my wife always leaves it on recirc which is potentially dangerous on long trips.
I miss the manual lever to control air re-circulation. You can control the amount of fresh air opening. The push button re-circulation is either you have full open or fully closed air circulation. Very expensive to repair too as what happend to my honda civic when the motor lever arm broke and the air intake does not fully close. Also have to wait a long time as the part was ordered from overseas (Thailand maybe).
#12 | ||
Thank you for the replies.
It could be a safety feature but sure is annoying when you have to push a button every 5 minutes. I'll talk to my dealer to see if anything can be done to increase the time limit at least. |
Hi all
According to the car manual the only time the switch turns on and off is when/if you have climate control fitted. On the manual version A/C the car manual states that you can toggle/switch between recycled air. It does not say anything about switching itself off at any length of time. I feel it stupid that it keeps switching off every 5 mins. or so. I have just bought a new Focus Trend and have asked the dealer for some explanation. All Ford has said that this is natural and there is nothing wrong with the switch.(no why's or therefore's) Lets get practical if there is warm air coming into the car the A/C has to work that much harder so you do not get the full benefit of the A/C and the bottom line is more fuel consumption. Ford will have to come up with a better explanation other than the ones I have read here in this forum. |
#14 | ||
I have a sport with climate and it does automatically switch from recirc to fresh. However it doesnt do this within 5 or even 15 min. I notice it only switches back to recirc after a long period of reaching what I think, it thinks is the set temp.
I actually like this feature! |
#15 | |||
Hi That is right with the climate control the recirc. turns off and on so it can regulate the temp. inside the car. I have not got climate control in mine. All Ford can tell me that there is nothing wrong with the switch. I still want to know why the recirc. switches off on the manual A/C units. |
#16 | |||
