Old 09-02-2012, 08:04 PM   #1
REDDYZ
REDDYZ's Avatar
Angry Vacuum leak..
Throttle hang + Poor mileage + loss in power = Vacuum leak.
After doing such and extensive work on engine I was thinking what could possibly go wrong in near future? Well, its hardly a month I had good time with my kat without any hassels. Now there is a vacuum leak somewhere thats drawing excess air while idling causing rpms go over 2500. Searched everywhere for leaks but no luck.
I could hear the leak but couldn't find where. Wasted a spray can of contact cleaner but couldn't trace the leak. By passed oil catch can but didn't make any difference.
I don't know if it is co incidence or consequence day before yesterday I found instrument cluster and dvd player were reset on its own. Then after a while it happened again. After a bit of investigation I found the accessory cable on positive battery terminal was loose. I couldn't figure out how that happened. Couldn't make it tight or loose. Eventually I snapped the bolt and bolted that cable on the main bolt that locks terminal onto battery.
Since then idling has changed. Every time I depress clutch or shift to neutral rpms goes over 2000 and drops down after few seconds. Mileage has gone from 8.9L to 14.5L. Replaced IACV and disconnected TPS plug while engine running which didn't made any difference. I think its time to strip things around engine..
Ex Cougar - 00' MTX 2.5L (Limited edition Eibach Cougar); Dark Green Tourmaline; Lowered with Eibach tuned suspension from factory; SVT UIM, LIM & Throttle body; Supercat 2.5" dual exhaust with twin pipe quad outlets; Custom headers; Custom coloured instrument cluster; K&N Apollo CAI kit; Calibre oil catch can.
Now driving a Lexus RX 450h. Your guess is correct that I am a family man now.
REDDYZ is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2012, 01:30 AM   #2
Cougar2K
Default Re: Vacuum leak..
Hey Yogi,
Sorry to hear about your troubles there!
That's a hell of a blow out on the mileage.
Here I thought I had my own lil gremlins to deal with occasionally but seems one has cropped up into your engine bay too now!
Well at least with you personally having recently stripped the engine right back, you'd be in the best position to hopefully identify where this problem lies or has come on from after all...
Best of luck with it and here's too a speedy recovery back to the good times again!
Cougar2K is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2012, 08:22 AM   #3
falconhell74
falconhell74's Avatar
Probably wrong but is your air flow meter playing games? just a thought
XC GS OLD SCHOOL MUSCLE
Audi A4 S-line quttro
Xc falcon
Previous fords-
xc falcon 500 ,250 x flow 3 speed
xc gs worked 250 x flow 4 speed
xa Fairmont 302 auto wagon
xb falcon 250 log auto 4 door
xb falcon 200 log auto ute
xc gs project - had to sell :-(
xc gs 302 4 speed 4 door
xc gs 351 auto 4 door
zf fairlane 302 auto
zk fairlane 250 x flow carb auto
zl fairlane 250 x flow EFI auto
xg ute , BA falcon dedicated gas
xd, xf x 3 ,ea,eb,ef,au x 3,telstar tx5
falconhell74 is offline   Reply With Quote Multi-Quote with this Post
Old 10-02-2012, 08:54 AM   #4
REDDYZ
REDDYZ's Avatar
Originally Posted by Cougar2K
Hey Yogi,
I feel like am maintaining a V8 now. I wouldn't worry much as am confident its vacuum leak. Since I did engine by myself am confident that engine part has no issues. Yesterday I used contact cleaner to check around LIM & UIM gaskets which has no leaks. Its definitely the vacuum hoses running around engine. I will definitely find it soon. Thanks & I hope my kat will be normal soon.
Airflow meter is not leaking, I checked it. To check its functionality I have to hook up scan tool later today to see if it is playing up. Its definitely leak though. I can hear the leak but can't trace. I could hear from sides and top.
Old 10-02-2012, 03:31 PM   #5
thearrow
If you have a vacuum leak you can bet it will be the source of ALL your troubles.
Find the leak and you will be OK.
I sprung a leak one day on the Harbour Bridge and was lucky I wasn't killed.
Owning a Cougar is like owning a Super Model
Good to own but "High Maintenance"
2000 Model Eibach Cougar (Auto) - Now dead & buried
thearrow is offline   Reply With Quote Multi-Quote with this Post
Old 11-02-2012, 02:31 AM   #6
REDDYZ
REDDYZ's Avatar
I think over the period of time vacuum leaks are inevitable on cars. Unless you park your car in lockup garage all the time.
I know that theres vacuum leak on my kat as I can hear it and there is throttle hang as well. So, I tried to wiggle and later pulled all vacuum hoses to see if they are loose. One of the hoses didn't feel alright so, pulled it a just a bit hard and it came off. It was partly holding and partly off.
This was the culprit. The vacuum hose that was off.
It runs along firewall behind engine and connect to HVAC that is mounted on firewall. On some kats it is mounted in UIM. Its hard to see it and accessing it is far thing.
Fixed that hose and everything is back to normal. No throttle hang, no over revving, no leak sound. Reset the ECU so that it forgets that it use to and has to pump extra fuel.
What a relief... all happies now
