Old 14-03-2012, 10:25 AM   #1
saber
Default Strange leak from exhaust, is it coolant or something else?
Hi guys
Got a bit of a weird one I’d like to run past you.
Recently I changed the water pump, radiator and thermostat on the old mans AU III Egas ute.
As I didn’t have any coolant on hand, I filled up with rain water (which had been filtered).
While checking for leaks, I found water (well what I thought was water) slowly dripping out of a hole in the exhaust (ie where the pipe first enters the muffler).
I thought “Damn, the old mans done his head gasket”.
After bleeding the cooling system, I took the ute for a drive. All was working well.
A week later, I was back working on the old mans ute; this time I was doing the transmission service.
After taking the car for a decent drive, I left the car running, and popped my head underneath to do one final inspection, checking for leaks around the transmission pan.
I then noticed there was still water dripping out of that hole in the exhaust. The thing is, the water was pretty cool, not even lukewarm.
I checked (and rechecked) that the car was at operating temp. The temp gauge was reading in the correct place (needle sitting at “O”), the thermo fans were both running, and the exhaust was hot to touch.
I haven't had a chance to run a compression test; that's next on the list.
Do you think this is still a coolant leak, or something else?
saber is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 10:31 AM   #2
Professor Farnsworth
Fossil fuel consumer
Location: Mod For: Pub, Bar, Sales Yard, Show 'N Shine, Photoshop, AU to BF, FG to FGX, Territory & Sports Bar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Many years of valuable contributions to the forum, including some superb build threads.
Default Re: Strange leak from exhaust, is it coolant or something else?
first step would be to put coolant in the header tank, which will answer the question pretty quickly.
Professor Farnsworth is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 10:44 AM   #3
Rambunctious
Cool water can come from the aircon drain and also the gas convertor.
Rambunctious is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 10:54 AM   #4
Kryton
Kryton's Avatar
Thats what it will be - aircon drain.
Kryton is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 11:01 AM   #5
saber
Yeah there was coolant in the header tank; as far as I know, the level isn’t going down...
Hi mate. Nah the leak isn’t coming from the converter or air con drain tube. The leak is coming from the exhaust, I saw it with my own eyes!
Old 14-03-2012, 11:09 AM   #6
BHDOGS
Falling onto the exhaust somehwre then running down and dripping off?
Old 14-03-2012, 11:09 AM   #7
RSPEC#78
FORD FANATIC
RSPEC#78's Avatar
its condensation mate. Every car will do it to a certain extent, depending on ambient temp
RSPEC#78 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 11:14 AM   #8
so you ended up putting proper green/red/whatever coolant in it? my point is you'd be able to tell from the colour if it were proper coolant.
Old 14-03-2012, 11:42 AM   #9
Torment47
Mr Hoon
Torment47's Avatar
I get drips from exhaust on my au and i don't use my air con.....
Torment47 is offline   Reply With Quote Multi-Quote with this Post
Old 14-03-2012, 11:43 AM   #10
condensation from the tail pipe is normal
Old 14-03-2012, 11:47 AM   #11
Torment47
Mr Hoon
Torment47's Avatar
Hence why i agreed with respec#78
Old 14-03-2012, 01:25 PM   #12
saber
Yeah 100% true.
As of yet I haven’t used proper coolant, only water. The reason being if the head gasket is gone, I’d have to drain the cooling system to remove the head (yes a dumb reason not to use coolant I know!!!)
But you’re 100% correct: If I did use the proper coolant, I’d know for certain if it’s a coolant leak or condensation.
Should condensation be forming if the engine is at operating temperature? I would have thought that the tailpipe would be so hot that any condensation within the tailpipe would have evaporated...
I mean, don't get me wrong...I'd be very happy if it was simply condensation, and not a blown head gasket...
Old 14-03-2012, 01:38 PM   #13
GasoLane
Former BTIKD
GasoLane's Avatar
I'm with the condensation crowd.
Try taking the car for a good 1/2 hour drive, then see if anything is coming out.
If it was anything serious like a head gasket there would be steam coming out of the exhaust and bubbles in the cooling system.
Trust me on this, I had a V12 Jag where the left tailpipe looked like a normal internal combustion engine and the right looked like a steam engine
Old 14-03-2012, 02:01 PM   #14
Mr Hardware
Flairs - Truckers Delight
Mr Hardware's Avatar
Isn't that what the catalytic converter is there to do? Convert some of the noxious gases to (amongst other things), water?
Isn't that the main reason why exhaust systems 'wear out'? Because they rust from the water by-product from the process the catalytic converter undertakes?
Old 14-03-2012, 02:05 PM   #15
Kryton
Kryton's Avatar
If you think its the head gasket leaking water (coolant) explain how the water comes out of the exhaust cold when the engine and exhaust is at operating temp.
Its most likely the aircon drain or condensation.
Old 14-03-2012, 02:12 PM   #16
Torment47
Mr Hoon
Torment47's Avatar
Well if that is the case that would explain why my muffler has a hole the size of a campbells soup tin.....
Old 14-03-2012, 03:22 PM   #17
saber
I can't, that's why I'm asking here
I hope its condensate, and not the head gasket!
I found an interesting article on areas to check to determine if you’ve done a head gasket. I’ll definitely be checking the exhaust manifold this weekend!!!
http://autofix.com.au/blog/ef-el-hea...n-problem-area
Old 14-03-2012, 04:42 PM   #18
RSPEC#78
FORD FANATIC
RSPEC#78's Avatar
the cat changes nox and carbon monoxide and other nasties to a more safe carbon dioxide. it can produce moisture but the moisture in your exhaust is from hot exhaust gases hitting the cooler exhuast pipe and cooler outside air temp, producing condensation. Nothing to be concerned about....
Old 14-03-2012, 04:46 PM   #19
RSPEC#78
FORD FANATIC
RSPEC#78's Avatar
Besides, if you are really concerned about the head gasket. Get a "sniffer" test done on your cooling system. If theres a leak it will show up on the test. the test uses a tube with dye in it, which changes colour when exhaust gas is detected
Old 14-03-2012, 05:22 PM   #20
ronwest
All Bran = Regular Member
As has been said numerous times it's condensation. Every car I've ever had has done it.
Old 15-03-2012, 10:53 AM   #21
saber
Thanks guys for all your help and suggestions.
I’ll do more testing (hopefully) on the weekend. Thinking of using proper coolant to see if the drips from the hole in the exhaust changes colour, a compression test, checked the exhaust manifold (as per the above link) and a head gasket testers (if the above 3 tests indicate a head gasket leak).
Hopefully it’s just condensation, and not a head gasket leak!
Anybody know where I can purchase a compression tester? Been meaning to buy one for a while, but unsure where to pick one up.
Old 15-03-2012, 11:54 AM   #22
ronwest
Autopro, supercheap, Burson's, They'll all have them.
I think my new one cost me $40 from Autopro.
edit: Here you go... google is your friend http://www.supercheapauto.com.au/sea...ression+tester
