I have purchased this;
http://www.boomco.com/products.php?p...etCurrencyId=3 And it has arrived today, so a weekend job beckons. I even had to buy a new socket set! Anyone done this before? Any tips appreciated. I will try and document the process for those who may want and give it a go. Here's the start.... Box; ![]() 2 Part unit; ![]() Connected; ![]() Slide out cup holder; ![]() Open; ![]() |
I've got a similar unit for the Focus. To be honest, I wasn't sure how it would go, and whether I would ultimately want to keep it, so I didn't screw it in - I used double sided tape instead.
And after 12 months it's still in place. If you can do something similar, I'd try that first, so see if you like it or not. You can always screw it in later, and the double sided tape would help make sure the thing didn't move ![]()
His: 2019 Ford Focus SA Trend with Driver Assist Pack: 1.5 Ecoboost 3-cylinder (yes, 3 cylinders!), 8-speed automatic in Ruby Red. ![]() Hers: 2020 Ford Puma JK: 1.0 Ecoboost 3-cylinder, 7-speed DCT in Frozen White. |
I have seen the armrest that you have on ebay.
Do you have to modify the vehicle in any way? Like drill holes etc? The Boomerang requires no drilling or cutting. This is what attracted me to it. That and the excellent reviews about build quality, which just opening the box I could see were correct. I can install this and if not suitable remove it without leaving a mark. Very clever. |
Yes, mine needs drilling to make it permanent, but as I said, double sided tape is holding it. So far.
After 12 months, I doubt it is going anywhere.
Must be very good double sided tape. |
having Fiesta withdrawals
I have thought about one a few times. Saw one that also has a drink holder under the armrest part. Only thing I don't like about them is that they would make it awkward to get to the Handbrake.
New: Ford Focus RS in Ultimate Green number 82/315 Past: 2009 Ford Fiesta LX in Vision Blue - Sold |
#8 | |||
#9 | |||
I have installed the unit, will post install pics later. This unit has a cup holder that slides out; ![]() I have no real problem using the handbrake. Would only ever be an issue if doing a handbrake turn........ |
Before...
![]() Remove cupholders ![]() Remove & discard plate that holds plastic console down ![]() Exposed handbrake cable holder. You need to remove the bolts holding this down as it is anchor point for the armrest rear support. What I did find is that the Aussie Fiesta has a different bolt set up than the Euro specs. In the Boomerang instructions it states that the nuts need to be removed & discarded from the brake cable holder. This would leave "studs" that allow the supplied M10 spacers to be fitted. The aussie version uses a bolt here, not a nut. So I removed those, cut the heads off and reinserted them with locktite to create "studs". ![]() Rear support fitted over handbrake cable ![]() Another view of support bolted in. ![]() Plastic console/cupholders replaced and armrest slide in to place with 4 bolts holding it. ![]() Success! ![]() ![]() ![]() ![]() ![]() All up about an hour to install, and that included the modifications to the bolts. Very hard to separate the initial bits of plastic in the console. But the unit is STRONG. I reckon I can lean maybe half my body weight on to it without any flex. If you've got a spare 200 bucks, well worth the effort. |
Yikes, expensive - looks mega practical tho
#12 | ||
Fiesta accessory offered by Ford in some markets.
http://www.ford.com.ph/servlet/Satel...allery-overlay Part Number: A66SX645A62AB |
#13 | |||
#14 | |||
I noticed its not listed in the Australian Ford website. |
#15 | ||
Just ordered my own now
![]() Eagerly awaiting the delivery. How did you remove the trim covering the handbrake cable though? I couldn't get it off last time when we were servicing and ended up adjusting the cable lying under the rear axle. |
#16 | ||
Extremely hard to get apart, but possible.
You need a small flat screwdriver. Just insert towards the rear of the console and gently pry the two sections apart. They are really connected so don't be surprised at how hard you have to go. Be brave! At the 2:20 mark of this video you can see how the clips are set up. http://www.youtube.com/watch?v=2SzaI9Ch-us Ours are very similar though not exactly the same. Good luck, post pics. |
#17 | ||
#18 | ||
Still waiting on delivery...
First it was stock shortage, then it was incorrect shipping charges. It'll be very hard for me to recommend buying from Boomco to anyone. Apparently it's shipped now with a tracking number. According to that it left San Francisco on 2/1/13. |
#19 | ||
I also got the incorrect shipping at order. But buying regularly from the States I knew that the shipping quoted was wrong and expected it.
Still, having had this issue with my international order I would have expected them to have fixed it by now. While I have no doubt you have a sour taste in your mouth, which is understandable, I'm sure you will have a grin cheek to cheek the first time you head out with your left arm comfortably resting on the product. It is that good. |
#20 | ||
So it's arrived and I've fitted it.
The centre console in our Fiesta is definitely not the same as the Euros. The centre console under the cupholders is actually melted together. When I pulled the centre console apart, the melts ripped out too. Not sure why they melted it though, no extra rattles and the centre console comes back together solidly. I had to do the same thing with the bolts. I did it with a mechanic mate of mine so he had studs to replace the OEMs though. Loctite is very highly recommended given the amount of torque that will be put on those studs, you certainly don't want any give in them. The faux leather on the top feels great and the plastic surrounds look very OEM. Matches exactly with the silvery plastic around the air vents and headunit. The arm going up is solid aluminium and weighs a fair bit too and when fitted, the whole thing is solid. There is a bit of give in the armrest when I really lean into it, but much less than expected for a unit of that kind of design. As a warning though: Do not get the Boomerang XT Armrest if your Fiesta is a Manual The reason why I say that is because when the armrest is down, it does make reaching the handbrake and gearshift quite awkward. I find that the armrest does fundamentally alter my driving position. Cruising down a highway on cruise control, having the armrest there feels amazingly comfy. Doing quick turns around the city though and I find i almost always keep the armrest up because i keep banging my left elbow into it. To be fair, I have fairly long arms. The armrest is almost completely irrelevant to my sister. She even manages to get to the gearstick and handbrake without all the issues I have. Overall, it's certainly a nice piece of kit. Does its job and Boomco gave it's best shot at making the best armrest for the Fiesta and it shows. But I'm still concerned about it's longevity, considering all it's moving parts and despite it's quality and how OEM it looks, how it gets in the way of the gearshift and handbrake certainly doesn't feel OEM. |
#21 | ||
I have a manual.
I am 6 foot 5 inches. I have no problem with gears or handbrake. The Mrs is 5 foot 1 inch and with the seat so far forward she cannot even use the armrest. But I love it. Cruised up to Whitfield last weekend so a bit of twist and turn with plenty of gear movement. fantastic! |
#22 | ||
Thailand Specials
