Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Race Brakes Sydney
Race Brakes Sydney Street and race performance pad / rotor combinations as well as brake upgrades and Exedy clutch kits. Website Link
Old 27-08-2012, 08:46 PM   #1
LPGUTE
LPGUTE's Avatar
Default Pads for BF XR6T
hi matt, i got a set of caliper from a BF XR6T and need front and rear pads, also rear rotors, is there a way to tell whether it had the vented rear or not? it got DB1675 style pad from bendix. what braided brake hose suit them best will be fitting them on an AU XR6
Many Thanks
2001 AUII Factory LPG Manual XL Styleside Box
High series bonnet
Clear Side Indicator
K&N Air Filter
BAXR6T Snorkle
Low Fronts, Super Low Leafs
LPGUTE is offline   Reply With Quote Multi-Quote with this Post
Old 28-08-2012, 10:22 AM   #2
FLOORED
Race Brakes Sydney
FLOORED's Avatar
Default Re: Pads for BF XR6T
If you have the DB1675 pad then you have vented rears but fitting that kit to the rear of a AU will have some issues as they foul on the backing plate and the handbrake lever from memory. There have been some people on the forum that have made them fit whicj i think involved removing the backing plate but you may want to read up on fitting the rear 328mm kit before you buy rotors etc. Front pads are fine and also braided lines are ok i will have to custom make some.
MATTHEW PEARCE
RACE BRAKES SYDNEY = When you want it to stop
Street to track is what we expertise in
Phone 02 9609 1101
sales@racebrakessydney.com.au
www.racebrakessydney.com.au
