Old 19-10-2012, 01:20 PM   #1
tim_pato
tim_pato's Avatar
Default 120 amp main fuse keeps blowing
pulled over to answer my phone went to take off and the ute stalled, tryed again started fine let the clutch out and pooof, i replaced the fuse and pooof! i have torn the old girl apart, cant find anything. Ive pulled all the fuses out and still its shortibg somewhere, i pulled out all the relays and still no dice. any ideas?
tim_pato is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2012, 02:33 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: 120 amp main fuse keeps blowing
bad earth to the motor possibly or battery to the chassis?
this might cause the car to not enough power for the coils/ecu, when you tired to accelerate it couldnt keep it up and stalled?
then cranking it over with a bad earth killed the same fuse?
if im thinking about the right fuse, the 120A is for the Lighting and Starter motor.
can you check the voltage at the battery, with ign off, and then again when the engine is running?
post up your findings
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2012, 03:54 PM   #3
tim_pato
tim_pato's Avatar
can't do naught, the fuse pops before the bat term is pushed all the way on. altenator maybe?
Old 19-10-2012, 04:15 PM   #4
my67xr
my67xr's Avatar
is the alternator soaked in power steering fluid maybe?
67 XR Fairmont
Old 19-10-2012, 05:41 PM   #5
tim_pato
tim_pato's Avatar
dont think so
Old 19-10-2012, 08:01 PM   #6
Gaz
Got Ghia?
Gaz's Avatar
Starter isn't directly fused, only the ignition wire to the solenoid IIRC. If you only popped the 120A main fuse and not any other fuses (check them all, inc in cabin) I'd be starting by checking for shorts in engine bay the fuse box perhaps the output of this fuse has someone earthed to the body. From memory power goes through the 120A fuse first, and then the smaller fuses for the various circuits.
2007 BF MKII Ghia V8 - BA GT Exhaust| F6 Intake | Superlows | 19" GT-P's | 30mm Swaybar | - Sold
2002 AU2 XR8 Ute - Manual | Leather | Injected LPG | Pacemakers
Gaz is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2012, 08:08 PM   #7
my67xr
my67xr's Avatar
here is the wiring diagram if it helps-
http://fordforums.com.au/wsm/wire/aubx/Part%2024-5.html
67 XR Fairmont
Old 19-10-2012, 08:34 PM   #8
Barnaby
Barnaby's Avatar
No electrical cables fouling the clutch mechanism? Both in the cab & under the hood?
Are you handy with a multimeter?
Barnaby is offline   Reply With Quote Multi-Quote with this Post
Old 19-10-2012, 08:44 PM   #9
tim_pato
tim_pato's Avatar
Smile Re: 120 amp main fuse keeps blowing
checked all other fuses removed all of them and all relays, still shorted, looked for shorts and couldnt find/see any.
Old 19-10-2012, 08:45 PM   #10
tim_pato
tim_pato's Avatar
thanks mate i apprciate that, however i do have a gregorys.
Old 19-10-2012, 08:47 PM   #11
tim_pato
tim_pato's Avatar
checked all that. I have a multimeter, dont know how to use it.
Old 19-10-2012, 08:51 PM   #12
tim_pato
tim_pato's Avatar
after hiring a car trailer and geting it home. once unloaded i tryed disconnecting alternatot, nothing, as in no shorts, started fine, reconected alternator, no shorts, started fine! which is good cause its not going to be a ***** fight getting it into the shed, bad cause i still need to tear it apart to find out what and where it was shorting.
Old 20-10-2012, 01:55 AM   #13
mik
mik's Avatar
done any modifications recently? fitted extractors got wiring with shielding burn`t through?
Old 20-10-2012, 06:31 AM   #14
tim_pato
tim_pato's Avatar
yeah pacemakers a few months ago, i did have a look, ill check again today. Plan is to pull the engine bay fuse box and associated harness out and give iy a good going over, ill try and chase up another altenator aswell.
Old 20-10-2012, 10:38 AM   #15
mik
mik's Avatar
yes it`s surprising how even sometimes with a good installation you can over look something or it can shift due to the engine rocking or some other reason, in my brothers case recently he fitted a v8 into an old toyota wagon(sleeper) and had wiring tucked behind the head(not secured properly in his excitment to get a run in the v8 powered wagon) , it moved and got cooked on the extractors.
good luck anyway.
Old 20-10-2012, 02:55 PM   #16
AUFanboy
Power wire from the alternator shorting out on the alternator housing? There's a little bracket it goes through, should be a rubber insulator in there.
AUFanboy is offline   Reply With Quote Multi-Quote with this Post
Old 20-10-2012, 04:53 PM   #17
tim_pato
tim_pato's Avatar
FML, idiot of the week? only put this alternator in last week. oh well found a few places where the wires had rubbed through blown fuses waiting to happen i guess
Old 20-10-2012, 05:18 PM   #18
mrfordfairmont
351 clevo
mrfordfairmont's Avatar
i had the same problem with the alt wire which stated a fire in the engine bay
2006 ford territory turbo stock as a rock for now
2004 territory ghia
click here for pics
work daily ke laser ghia RIP
click here for pics
Daily EF II fairmont wagon RIP
click here for pics
XD 351 clevo lowered
click here for pics
thanks to
p.e.a.c.h performance at stafford
http://www.peachperformance.com
mrfordfairmont is offline   Reply With Quote Multi-Quote with this Post
Old 21-10-2012, 12:12 AM   #19
mik
mik's Avatar
good find mate, , well done.
