26-10-2012, 02:37 PM | #1 | ||
FordTarius
Hi all,
Intend to replace the sparkies this w/end on the old petrol au3. Does anyone know if we can still use the standard NGK BPR5EY-11 as opposed to the recommended (and $$$) iridium IGR5C13 ? Would I have to increase the gap to 1.3 on the std's?? thanks! -ash
---------------------- Forte | AU3 (2002) ---------------------- |
26-10-2012, 07:34 PM | #2 | |||
Auto Nerd
27-10-2012, 12:33 AM | #3 | ||
Rob
standard for me. Iridium seem a waste of $
Supercharged Nissan 350z 280rwkw Blueprint series 3 AU V8 manual |
27-10-2012, 01:37 AM | #4 | ||
Bosch double platinum plugs for the win. They last well over 100,000km on a petrol engine or around 100,000km on LPG.
PoweredByCNG: Sick and tired of all the ignorant 'gas is crap' comments out there. |
27-10-2012, 12:47 PM | #5 | ||
Flairs - Truckers Delight
stick with the old BPR5EY-11's for petrol mate. BPR6EY's for LPG.
I reliably get 50,000k out of a set of BPR6EY's (and that's on spark-picky LPG!) and at less than four bucks each, they can't be beaten.
27-10-2012, 07:50 PM | #6 | ||
i`m a bit of an iridium fan, 115,000 k`s out of the last set still going ok, only changed them because they`ve been in for years, tbh i was a bit afraid they where going to have permanently welded themselves into the head, but they came out easy.
03-11-2012, 11:02 PM | #7 | ||
rexnet
i gapped mine @ 1.1mm but i have a VCT engine. the BPR5EY-11 are good. i changed mine every 10-15k km
05-11-2012, 03:20 PM | #8 | ||
10-15k? you're throwing away perfectly good plugs mate
05-11-2012, 03:34 PM | #9 | ||
Those cheaper plugs are designed for 20,000kms though really,yeah you can get more but they aren't designed with this in mind.
05-11-2012, 03:43 PM | #10 | ||
BEAR
The 11 at the end of BPR5EY-11, should be the gap, set at the factory. BPR5EY-13 should have a gap of 1.3mm. I always check, cos I'm an old fart. Generally speaking, close the gap by 0.1mm for gas, (less carbon atoms in LPG) and go one range hotter.
If you're still in control.....you're not going fast enough. |
