Old 18-11-2012, 12:03 AM   #1
BAGT514
BAGT514's Avatar
Default Tyre pressures - Toyo TQ drag radials
Hi guys - I am going out for a test & tune day at AIR and I am running my 275/40/17 Toyo TQ's for the first time. I am not going to be able to change pressures too much on the day so what ballpark figure should I run them on? Car is a 2011 FG GTP tuned to 382 rwKw...
Any advice from people who have run them or the 275/40/17 ET streets would be greatly appreciated.
Shane
Official member of the OCMD Club
"Semi - Silhouette" 2003 BAGT #514
2007 GT500 factory supercharged motor built!
Sensation Blue 2011 FG GT-P # 101
KPM Streetfighter Monster
5.2lt MMR short motor / Stage 3 MMR heads / Boss 302 Exhaust cams
FR20 Simmons / Tein Coilovers / Eaton Tru Track / Very scared 305/25/20" Nitto Invo's
ZF fitted with a NIZPRO Stage 2 input shaft & Excedy Clutches
http://www.fordforums.com.au/showthread.php?t=11408502
BAGT514 is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2012, 12:07 AM   #2
T4ME
T4ME's Avatar
Default Re: Tyre pressures - Toyo TQ drag radials
18psi cold will be fine.Is this the KPM day tomorrow?
T4ME is offline   Reply With Quote Multi-Quote with this Post
Old 18-11-2012, 12:09 AM   #3
BAGT514
BAGT514's Avatar
Yes - thats the one
Old 18-11-2012, 12:13 AM   #4
T4ME
T4ME's Avatar
Expect to get allot of passes in as not many have entered.
Old 18-11-2012, 12:20 AM   #5
BAGT514
BAGT514's Avatar
I know - 1 was number 6 out of 20....
For $200 & 4 hrs I will get to learn my car down the track
Old 18-11-2012, 12:41 AM   #6
xr6t_ute
xr6t_ute's Avatar
There will be someone there with a tyre gauge, if your spinning drop them down slowly after each run till you find the best launch.
Get them to 18 cold and start dropping from there depending if you spin or not.
Daily driven workute....10.33 @ 136mph
Gtx3582
Stage 2 Nizpro kit.
HEADSEX TUNED
xr6t_ute is offline   Reply With Quote Multi-Quote with this Post
Old 24-02-2014, 10:46 PM   #7
SIMBAD
RAPID GT-P
SIMBAD's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This thread: BA-BF diff cradle removal for diff bushes
Just curious how these tyres went for you? Cheers
Full Difilippo big boy exhaust /4.5" body ballistic metal cats / boss 315 plenum & twin throttle body coupled to bpr airbox / powerbond underdrives / herrod 290 cams / malwood opt 3+ / hrs Pegasus rims 19x8.5 front - 9.5 rear / nitto invo 245-35-19F & 275-35-19R / whiteline swaybars/ Under bonnet bling / 4.11 harrop truetrac
Enhanced by BLUEPOWER
supercharged 363 dart takes on au work ute http://fordforums.com.au/showthread.php?t=11342906
SIMBAD is offline   Reply With Quote Multi-Quote with this Post
