Old 15-01-2013, 01:12 PM   #1
FGII-XR6
FGII-XR6's Avatar
Default Headlight cleaning
I have read various headlight cleaning methods and all require time and plenty of elbow grease using various grades of wet and dry then a fine polish.
I heard Autosol works well and tried it on headlights that failed a blue slip inspection.
initial attempts were a failure using a cloth to clean it then I read it works a lot better if you rub it with bare fingertips. I tried this and in 10 minutes the headlights looked like new. no wet and dry needed. I now have my blue slip and the inspector was impressed seeing I had only been gone about 25 minutes.
hope this helps someone
[SIGPIC][/SIGPIC]
Rides:
Old 15-01-2013, 01:37 PM   #2
my67xr
my67xr's Avatar
Technical Contributor: For members who share their technical expertise. - Issue reason: This contribution: 04 SX TX AWD, drama's replacing upper outer joints w/Nolathane replacements
Default Re: Headlight cleaning
good work,
i have even used hand cleaner as a first cut on really bad lenses.
but dont use the coarse stuff with pumice/sand.
Meguiars plastic cleaner/polish is good to maintain the shine and clear lenses too.
Money Talks, but all i ever hear is it saying Goodbye!!
click below to view my build threads
67 XR Fairmont
04 SX TX Territory AWD
my67xr is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2013, 06:06 PM   #3
Bossxr8
Peter Car
Bossxr8's Avatar
Rainex works well too.
Old 15-01-2013, 06:20 PM   #4
Nikked
Oo\===/oO
Nikked's Avatar
Best to get a headlight restore kit, as they come with a UV fluid that you apply to the lense after polising to help them from turning milky again.
Check out my Photo-chop page
T...I...C...K...F...O...R...D
\≡≡T≡≡/
Nikked is offline   Reply With Quote Multi-Quote with this Post
Old 15-01-2013, 06:58 PM   #5
Itsme
Itsme's Avatar
I have used Wet & Dry with Autosol, 1st attempt was ok by hand polishing....
When I did the next set I buffed the lights using my buff on high speed, Headlight finish was like brand new look....perfect.
Itsme is online now   Reply With Quote Multi-Quote with this Post
