Old 17-03-2013, 03:15 PM   #1
zdcol71
zdcol71
zdcol71's Avatar
Default re: new registration
Guys, I am thinking of purchasing a ZC Fairlane. Price doesn't matter for this question. It is straight, complete(all seat belts, knobs dials etc.) Has 351, apparently 4V heads, electronic ignition, 2 1/2 dual pipes ,extractors, 600 cfm holley, has been on gas with plate attached under bonnet. Interior is clean and tidy, and all "things" work as they should. The gear selector is the only dodgy part of the inside, apparently the cable is not genuine,off a truck to get the car home and not been rectified.(I can replace linkages/cables with spares I have.)Also appears to have a leak in hosing on the power steering unit, (again I have spares)
The car appears to have been lowered ,I'd guess 2 inches, has 18"rims(very wide) and apparent minor rust (under a reasonably good paint job) in the sills,doglegs, and a obvious spot on the front edge of the bonnet. I know there will be more under the paint, but my question is, given the condition, what needs to be done to register it. It was last registered in Qld, June last year, guy is doing renos and just let it lapse, I will be registering it as normal rego( not SI plates) but will walk away if there are major regulatory probs with getting it done. Obviously it will need Safety Cert, but what else is required to re register.
Thanks for any help
: 30 years later
zdcol71 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 03:21 PM   #2
wulos
Forum Director
wulos's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: All the behind-the-scenes effort. Technical Contributor: For members who share their technical expertise. - Issue reason: For his advice, tips/tricks in the Art and Photography section of the Forum.
Default Re: new registration
Please take the time to write your post out clearly, and where possible use correct grammar(rather than SMS text style post).
I, like many that post here, am far from perfect with written English, but that first post was EXTREMELY difficult to read.
wulos is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 03:33 PM   #3
zdcol71
zdcol71
zdcol71's Avatar
Wulos, I don't know how it came across in "that first post" ? This is the only post and I thought it was pretty clear and readable. Am I missing something?
: 30 years later
Old 17-03-2013, 03:39 PM   #4
Giant Cranium
VF2 SSV WAGON
Giant Cranium's Avatar
i can read it pretty easy, not perfect but not unreadable
Giant Cranium is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 03:53 PM   #5
wulos
Forum Director
wulos's Avatar
The price doesn't matter for this question.
It is straight and complete with all seat belts, knobs dials etc. The motor is a 351, apparently 4V heads with electronic ignition, 2 1/2 dual pipes and extractors. It has a 600 cfm holley, and converted at some stage to gas as indicated by compliance plate attached under bonnet.
The interior is clean and tidy, and all "things" work as they should. The gear selector is the only dodgy part of the inside. Apparently the cable is not genuine. It was a spare part off a truck (fitted when the vehicle had broken down) in order to get the car home and not been rectified since. I can replace the suspect linkages/cables with spares I have.
The Fairlane appears to have a leak in the hosing connected to the power steering unit. Once again, I have spares.
The car appears to have been lowered. At a guess, it is sitting approximately 2 inches lower than standard. Vehicle is fitted with very wide 18" rims.
Despite having a reasonable good paint job, the body has minor rust apparent in a few locations. The most obvious is in the sills, doglegs, and an obvious spot on the front edge of the bonnet. I know there will be more under the paint.
My question is, given the condition, what needs to be done to register it?
The Fairlane was last registered in Qld, expiring June last year. The previous owner was/is doing renovations and had let it lapse.
I intend upon registering it with normal rego (not SI plates), but will walk away if there are major regulatory probs with getting it to pass.
Obviously it will need Safety Cert, but what else will be required to re register?
Thanks for any help
Post interpretted & retyped to make it easier to read
Old 17-03-2013, 04:05 PM   #6
SEZ213
SEZ213's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Always puts a good amount of thought into his posts and voices his ideas and opinions in a well thought out and constructive manner. I have certainly seen many threads where his input has been constructive to the topic and overall the forum has benfited f
If your safety certificate is in order, it should be just a matter of going to Queensland Transport with your prepaid CTP insurance and your completed registration form and register it.
2012 Focus ST
Tangerine Scream
Continually having a battle of wits with unarmed opponents.
Sez
Photo's by Sez
SEZ213 is offline   Reply With Quote Multi-Quote with this Post
Old 17-03-2013, 04:05 PM   #7
wookie836
Highway wanderer
wookie836's Avatar
*interpreted
wookie836 is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2013, 12:20 AM   #8
zdcol71
zdcol71
zdcol71's Avatar
Oh Please!!.... 60,583 members and my question gets a "watch your grammar"?? I have interpretted that as "never say then when you meant than", and well picked, but I think people get the drift.
: 30 years later
Old 18-03-2013, 12:23 AM   #9
zdcol71
zdcol71
zdcol71's Avatar
PS , Thanks Sezzy, I hope it is that easy.
: 30 years later
Old 18-03-2013, 12:30 AM   #10
flappist
Well I tend to agree that it looked like it was written by schoolkid on a phone.
You were not told to "watch your grammar", you were informed that it was of a low standard approaching SMS style.
Rather than take this as some form of personal attack why not take it as it was meant to be and learn from it as it was posted by a Forum Director.
Old 18-03-2013, 12:31 AM   #11
XR6TCraig
Not sure what part of registering a car in QLD is causing you difficulty. Whenever I have done it, the process has gone something like this:
1) Get a current safety certificate. You'll need a roadworthy car for that bit which may be your stumbpling block!
2) Fill out the paperwork.
3) Present said certificate and paperwork along with a wad of cash to the Dept of Transport upon which you will recieve plates, rego papers and CTP.
4) Fit plates to car and drive as you please
5) Fit rego label when it arrives in the mail a couple of weeks later
That is all!
Octane BFII XR6 Turbo manual sedan. SOLD
2014 BMW S1000R
2006 Toyota Landcruiser GXL 1HD-FTE
XR6TCraig is offline   Reply With Quote Multi-Quote with this Post
Old 18-03-2013, 01:46 AM   #12
zdcol71
zdcol71
zdcol71's Avatar
Thanks for the reply, Craig.
I assume that, with the work that I can perform myself, the safety certificate is not a major issue.
The paperwork, hopefully, given my apparent school child level of grammatic correctness, will not be a major issue.
I'm more unsure of the previous work done to the vehicle, ie, lowering of the suspension, oversize wheels, aftermarket electronic ignition, and sports steering wheel etc.
Will these need to be replaced, or can any one give me the right answers as to what is (Transport Qld) required to register a modified vehicle. How close to "sold as new" does a 43-44 year old vehicle need to be before it becomes a little more than filling out the paperwork and getting the registration plates/label /certificate.
: 30 years later
Old 18-03-2013, 06:10 AM   #13
XR6TCraig
Those questions will be addressed when you present the car for a safety certificate I would have thought.
2014 BMW S1000R
Old 18-03-2013, 09:01 AM   #14
vanman_75
XD Sundowner
vanman_75's Avatar
Anything not in the guidelines, you will have have to replace . How big are your wheels ? How low ? Ignition means nothing ! And how small is the steering wheel ?
If old mate who owns it hasn't changed anything since he registered it , then I'm guessing all will pass .
But going by your post I reckon he got a legit roadworthy and changed all those things after ...more info required dude ...
something old something blue
vanman_75 is offline   Reply With Quote Multi-Quote with this Post
