Go Back   Australian Ford Forums > Site Sponsor Forums - In Alphabetical Order > Shockworks
Shockworks Ford damper specialist located in Melbourne's S.E suburbs. Website Link
Old 16-07-2013, 10:49 AM   #1
Shockworks
Default Ford XY dampers
Shockworks is proud and quiet excited to have our first Ford XY dampers finished and ready for test and development. These guy's are adjustable monotube dampers front and rear. The rear dampers are inverted with the adjuster at the bottom mount for easy damping force changes. We should have these available for sale in Spring. We will continue to support the Ford models old and new with an AU kit on the way in the future.
Shockworks is offline   Reply With Quote Multi-Quote with this Post
Old 16-07-2013, 11:01 AM   #2
Shockworks
Default Re: Ford XY dampers
I forgot to mention we are also working on an CNC machined alloy top mount with a spherical bearing to reduce the sideload on the low XY Falcons.
Old 08-08-2013, 02:46 PM   #3
SPArKy_Dave
Too many Fords........ :)
SPArKy_Dave's Avatar
Awesome stuff!
What are the total extended and compressed lengths of the shock absorbers?
I only ask, as one of the big issues when lowering these in the front, is running out of physical shock travel.
Current Projects
97 EL V8 wagon - cool cruiser, or street bruiser? CLICKY
93 XG panel van - at your door in 60 secs, or the first hr is FREE........ yep, that's the goal.
95 XG ute - awaiting a head gasket...... grrrrr.
74 XB GS pano..... factory optioned with all the good stuff..... not much there now. ........long term resto.
XB Coupe and Van TV Ad
you know........ there's a little bit of Bathurst in every Ford Falcon.... think about it
SPArKy_Dave is offline   Reply With Quote Multi-Quote with this Post
Old 08-08-2013, 03:28 PM   #4
Shockworks
Originally Posted by SPArKy_Dave View Post
Awesome stuff!
Hey Sparky,
The open length of the damper is 327mm and 225mm for the compressed length for the front. The rear is 396mm open and 245mm closed. We are also making an alloy CNC machined top mount with spherical bearing that will help with the travel issue and the sideload the damper see's with the low cars!!
Brett
Old 08-08-2013, 03:41 PM   #5
SPArKy_Dave
Ah, ok, I did a comparison a while back, when trying to find the shortest x-series front shock. (see pic)
Found the Koni's to be the shortest compressed, at 210mm overall, incl the shortest body overall.
(Apparently the chinese Ultima's are identical lengths to the Koni's.
The Sportsryders, were the longest, at 230mm, and by far the hardest to compress.
Current Projects
Old 08-08-2013, 03:49 PM   #6
SPArKy_Dave
At 225mm, a shock top spacer would still be needed IMO, (or a top mount with up to 20mm extra height - max, before bonnet clearance becomes an issue) when running 2inch lowered or more.
I found that after approx 3-4 inches lowered, the upper ball joint approaches it's angle limits.
(after shortening the bump stop)
There is still movement, but IMO, not enough for acceptable wheel travel, unless the balljoint is wedge shimmed - as the Yanks do on the mustangs, when fitting a Shelby drop on the UCA.
Current Projects
Old 08-08-2013, 04:25 PM   #7
Shockworks
Thanks very much Sparky for the heads up about the lengths. Still have a bit to learn about the old girls and will be in our test XY at Calder on the weekend to see how the first damping forces go in the car. All the dampers in the picture seem to be twin tube which is OK but the Shockworks are adjustable monotubes. We can reduce the closed length but just shortens the rod travel and thought this was a good compromise to start with. The new alloy top mount will sit the top mount a bit higher and with the bearing won't have the compliance of the rubber bush so may be able to go a little higher with the mount, but will see first.
Brett
Old 08-08-2013, 04:50 PM   #8
SPArKy_Dave
Sounds like a heap of fun, wish I could tag along!
I only live local in Croydon.
I'm a self employed sparky by trade - 240/415V Domestic/Commercial/Industrial/Solar,
and have a small factory in Croydon also, for excess stock storage, etc -
but have a couple of 4 posters in there, a wheel alignment machine and other goodies, for my after hrs R+D work. :P
Been playing with the x-series falcons for yrs.
Anything I can help with, let me know!
Current Projects
Old 08-08-2013, 06:37 PM   #9
Shockworks
Hey Sparky,
Looks like we will have to meet as any help is always welcome. When you get a chance PM me with a contact number and I will give you a call in the next couple of days!!
Excess stock you say Mmm. Running out of room haha
Thanks mate
Old 12-08-2013, 08:05 AM   #10
FPV8U
BOSS 5.4L Enthusiast
FPV8U's Avatar
Was checking out XYYNOT last night on Facebook, this package will be well tested, what a cool car (Albeit with an LS1..)
FPV8U is offline   Reply With Quote Multi-Quote with this Post
Old 12-08-2013, 11:23 AM   #11
Shockworks
Hi FPV8U,
The driver, James is really happy with the car and was awesome to be in the car for a few laps. He is a really good steerer and I was very surprised at his skill as I am not the best passenger especially going side ways We where going down the back straight in forth gear at about 140Kph fish tailing all the way.
It's good to feel the car as we still need to improve the overall package but a great first test.
Old 27-09-2016, 06:19 PM   #12
old_mate
Smash the Boost
old_mate's Avatar
old thread but do you still have something available for the XY? I'm rebuilding my low and very slow Fairmont; been super happy with my FG's coilovers and would be more than happy to use Shockworks dampers as opposed to the Koni's which was where I was heading.
2023 Hyundai Palisade
1971 Fairmont Sedan
1974 SWB F100
Keyboard Warrior - A Person who, being unable to express his anger through physical violence (owning to their physical weakness, lack of bravery and/or conviction in real life), instead manifests said emotions through the text-based medium of the internet, usually in the form of aggressive writing that the Keyboard Warrior would not (for reasons previously mentioned) be able to give form to in real life.
old_mate is offline   Reply With Quote Multi-Quote with this Post
Old 06-10-2016, 11:55 AM   #13
Shockworks
Hey old mate,
Yes we still have adjustable XY dampers in stock and being a Shockworks customer will look after you with a good price for the damper set mate:-)
Brett
Old 06-10-2016, 11:38 PM   #14
old_mate
Smash the Boost
old_mate's Avatar
Thanks Brett; I have sent you a PM
1971 Fairmont Sedan
1974 SWB F100
