Old 01-09-2013, 05:40 PM   #1
Simple6
Simple6's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Tech article on rear bushes.
Default KN Laser Stereo
Quick thing I'd like to mention regarding some information I found almost impossible to find on the Internet.
A EF/EL Falcon stereo adaptor from Aerpro will plug directly into the Ford Laser factory loom and then allow you to colour match to your new stereos loom. Only the earth isn't including in the factory loom so you'll have to do that separately.
Part numbers are APP051 (has ISO connections on end) or AP7901F (no ISO connection on end). Either one will do the job, just you'd cut ISO connections off the first one, unless you were going to use them with another adaptor harness.
I went down this path because I couldn't find any wiring diagrams and anything on the Internet was contradictory to my colours in the factory loom. And for $15 for the amount of time (and skinned knuckles) I saved - well worth it.
KN Ford Laser 1999
Single DIN stereo originally
1976 XB Falcon 500 Wagon - BUILD THREAD
Sherwood Green | 3spd/250CI | Running Whitewalls on a 2.5" Drop
Simple6 is offline   Reply With Quote Multi-Quote with this Post
