Old 15-12-2013, 09:38 AM   #1
beatleboy17
Question Propshaft bolts
Someone has nicked my prop shaft and also taken the bolts with it. Luckily I have a spare form a previous MK 2 Escort, its a two piece with the constant velocity joint, as fitted to Rs2000's MK2. I have bought the bolts to new the prop on Ebay, but the centre bearing and the rear pinion to diff flange bolts both don't fit. The prop fits perfect, but both sets of bolts seem too big. Its a Timken (English) axle. the bolts are genuine Ford items as stated on both separate Ebay listings from different sellers. There only seems to be the one size available for both applications, or does anybody know different
GENUINE NEW OLD STOCK ORIGINAL
Ford Finis No. 1436053
dimensions M10 x 1 x 25mm x2 bolts for centre bearing
HIGH TENSILE 12.9 GRADE PROPSHAFT FLANGE TO DIFFERENTIAL FLANGE BOLTS AS USED ON SIERRA CORTINA ESCORT RWD MODELS. THEY ARE M10 X 1 X 17MM FLANGE HEADED BOLTS x 4 bolts
beatleboy17 is offline   Reply With Quote Multi-Quote with this Post
