Old 08-01-2014, 10:28 AM   #1
reddevil6
Default how to bottle feed 2.0l pinto
As the title say basically how do I bottle feed a 2.0l pinto does the bottle have to be higher than where the line goes to? Or can I sit the bottle on the ground with the pump inlet hose in the bottle? Do I feed it to the fuel pump inlet? Or the
carbi inlet?
reddevil6 is offline   Reply With Quote Multi-Quote with this Post
Old 08-01-2014, 02:28 PM   #2
atec77
Default Re: how to bottle feed 2.0l pinto
carbi inlet?
Best talk to the bloke you get the new bottle from , or talk to the installer , seems like you lack the skills right now
Old 08-01-2014, 03:18 PM   #3
supershifty
Missing a sock...
supershifty's Avatar
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Dave has been a long time active member on the forums and in particular has been a busy volunteer whenever there are cruises and toys runs etc held in South East Qld. He actively gives up his time and ensures that the events are provided for, be it commun
I'll assume you're trying to "bottle feed" petrol to your engine from a suitable container to bypass the fuel tank, not install nitrous. I'll also assume the engine hasn't been started in a while.
If your fuel pump is in known good order then it should pick up fuel with the bottle placed on the ground and a length of fuel line running from the bottle to the fuel pump - this will take some cranking to get the fuel up, make sure you've got a good battery.
To bypass the fuel pump, the bottle will have to be higher than the carb and you'll have to start a siphon action to get fuel running down the line before connecting it to the carb fuel inlet.
A little knowledge is a dangerous thing here. It can be a disaster waiting to happen. Post back with more detail of what you're trying to do. I really don't want you to get burned.
Real friends + great times = sheer bliss!
Considering becoming an organ donor? Click here
QLD Events, Cruises and Get Togethers: Click here
Gain success instantly - lower your standards.
It's not government funded - it's taxpayer funded.
supershifty is offline   Reply With Quote Multi-Quote with this Post
