07-12-2014, 01:53 PM | #1 | ||
Tried fitting a S2 XR cluster into my newly bought S2 fairlane 6cyl and the low coolant red symbol was flashing. I noticed that my fairlane being a six has not got a plug on the header tank is. Is there a way of getting around this. Thanks in advance.
07-12-2014, 04:47 PM | #3 | ||
Next upgraded Mk1 Leopard
LOL
UK But it would work
07-12-2014, 09:55 PM | #4 | ||
Was wondering if I could take the globe out. But I wasn't sure if it was gonna effect the lighting around the cluster. Will try it out tomorrow,thanks.
15-12-2014, 09:25 PM | #5 | ||
If I remember correctly the coolant light is a LED on the circuit board so it doesn't fail to light up A 180 ohm resistor to earth on pin 3 of the J2 plug on the cluster ( the one on the right) will fix it
[SIGPIC][/SIGPIC]
