Old 05-06-2015, 07:05 PM   #1
robertjp
Default Ford Focus LW mk II, misfire on cyliders 1 + 4
Had the engine warning light come on the wifes car (Trend 1.6 manual), I ran the scanner through it and came back with a misfire on cylinder 4. Booked in, they cleared that fault and then it swapped to cylinder 1.
The ford guy says that the next thing they need to check is the coil plug pack and the fuel system.
Has anyone else had similar issues.
robertjp is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2015, 02:17 AM   #2
Top_Ghia
Technical Contributor: For members who share their technical expertise. - Issue reason: has been consistently providing good technical advice etc. to AFF members, by having the vast technical knowledge he has with the various Ford products. A valuable AFF member
Sounds like a coil pack. I'm pretty sure the same coil fires 1 and 4 in a wasted spark arrangement.
Top_Ghia is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2015, 05:48 AM   #3
robertjp
Default Re: Ford Focus LW mk II, misfire on cyliders 1 + 4
Yeah that's what I'm thinking. (hoping!)
Old 06-06-2015, 03:29 PM   #4
Imolator
Quad Cam
Imolator's Avatar
The Trend uses the 2.0 Direct injection engine doesn't it? The 1.6 is only in the Ambiente I'm pretty sure anyway.
Sounds like coil pack to me.
Imolator is offline   Reply With Quote Multi-Quote with this Post
Old 06-06-2015, 03:36 PM   #5
robertjp
Yeah my mistake it is the Ambiante,
Old 18-06-2015, 07:05 AM   #6
xr8_wnaB
xr8_wnaB's Avatar
Check your spark plug gaps. I have the 2013 Focus Sport, very disappointed, I found the gaps were, from factory, pot one 1.1, pot 2 1.1, pot 3 1.49, pot four 1.69. Ford recon this is OK. I took the car back because of a vibration in the engine at different revs and the head bloke at Ford tells me its fine. I bought my own new set of plugs from another ford outlet, double checked the gaps, problem solved.
BA mkii XR8
298rwhp, SWEET rumble
Handles like a dream.
xr8_wnaB is offline   Reply With Quote Multi-Quote with this Post
