BA Mk2 Fairmont
Hi,
I had to disconnect the battery on our 2007 LT CL. I've put in the code that was in the manual but it doesn't seem to be working. I got timed out and have to wait 30 minutes with the key in the ignition. So annoying! I'm inputting the code as the manual states ie pushing 1 until I get to the number for the code then 2 until I get the number for the code etc Any help is appreciated. |
IT Drone from Sector 7G
![]() Join Date: Nov 2011
Might be a good idea to pull the radio out and check the code on top of the unit is the one you're entering. I have a LV MkII with the Sony head, mine is very simple, four Torx screws and she's out.
Worst case scenario is that you've got a replacement manual with someone else's code. |
you need special tools to remove the LTs radio They are thing metal strips that push up a locking pins on each side of the radio
look here;http://www.ebay.com.au/itm/NEW-FORD-...item3a60cd380f |
