Old 22-03-2016, 11:17 PM   #1
Philthy82
Default Fiesta Ws steering wheel volume control issue
Hi, I have a 2010 fiesta and the up/down volume controls on the steering wheel only just work if I pretty much push my thumb through the steering wheel!
How do I go about opening it up and cleaning the buttons contacts, or should I just replace the cluster with a new/used one?
Cheerz
Philthy82 is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2016, 04:44 PM   #2
Pursya
Default Re: Fiesta Ws steering wheel volume control issue
You cannot open it up. It's a sealed unit.
We had the same issue with our WT and had it replaced under warranty.
Do not do this yourself if you do not have the skills. Even the Ford dealer stuffed the repair up and damaged the airbag. Which they had to replace.
Pursya is offline   Reply With Quote Multi-Quote with this Post
Old 24-03-2016, 06:29 PM   #3
Philthy82
Ok. Thanks for the advice. Might just put up with it for the time being. Was definitely going to disconnect the battery in case the airbag decided to pop! Lol
Old 25-03-2016, 10:17 AM   #4
Pursya
I don't think the airbag popped.
If I remember right they damaged the connections somehow. Said they were very fragile.
Old 25-03-2016, 10:56 AM   #5
Philthy82
Ok, thanks for the advice
