Old 28-03-2017, 12:23 PM   #1
hereford108
Default 2012 Focus electric steering replacement
Electric steering module has give up. Only option is to replace full steering rack. I have sourced one (not cheap) but have yet to fit it. Looking under the car there seemed to be a 3 part subframe that is attached to all sorts of things. Has anyone attempted this job before or is it not a job for diy?
hereford108 is offline   Reply With Quote Multi-Quote with this Post
Old 29-03-2017, 08:51 PM   #2
hereford108
Default Re: 2012 Focus electric steering replacement
I have got more info on this now and I will be attempting it this weekend. If I don't get too frustrated I will take some photos and try and post a step be step of the job.
Old 29-03-2017, 11:06 PM   #3
80rs
http://www.focusfanatics.com/forum/m...ement-how.html
if your in melbourne jollys have a lw focus steering rack $78 self serve
80rs is offline   Reply With Quote Multi-Quote with this Post
Old 30-03-2017, 09:34 AM   #4
hereford108
Unfortunately I'm in Perth. Already bought one, $880. These things are $3,000 brand new!!
Old 30-03-2017, 09:51 AM   #5
DZFord
DZFord's Avatar
Check your PM hereford108
Old 04-04-2017, 07:54 PM   #6
hereford108
I have now replaced the steering rack. Total time 9 hours. I'm sure I could do it in around 6hrs next time. If I get time over the next couple of weeks I will post a step by step with photos.
Old 14-05-2017, 06:27 PM   #7
ado15666
Hi. Did you have to get the rack programmed by Ford, I have been told this was required.
ado15666 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2017, 08:47 AM   #8
hereford108
All we did was have the steering alignment done and everything seems to be fine. I'm presuming the rack was already programmed from the car that it came off, so we didn't bother.
Old 15-05-2017, 09:54 AM   #9
ado15666
So you bought second hand! What did you pay?
Old 15-05-2017, 03:33 PM   #10
jase_elxr8
https://fordforums.com.au/showpost.p...04&postcount=4
jase_elxr8 is offline   Reply With Quote Multi-Quote with this Post
Old 15-05-2017, 08:20 PM   #11
hereford108
$880 which was much cheaper than the quotes from ford, $3,000 new plus $1,000 to fit or $2,400 second hand, fitted
Old 15-05-2017, 09:02 PM   #12
ado15666
Hi
I have found a BV6C 3D070 rack. Do you know what part number yours was?
I need a CV6C 3D070 rack. Dont' know what the difference is!
Old 16-05-2017, 08:31 AM   #13
hereford108
No idea. The wreckers I bought mine from contacted Ford using my vin number to make sure it was the right part.
Old 16-05-2017, 10:01 PM   #14
ado15666
Seems it is a supersession of the part starting with the one i have found to the current part number listed by Ford. They cant tell me if or what was changed or different.
Old 17-05-2017, 08:49 AM   #15
hereford108
What I do know, is you have to have the one that matches your vin number and there are lots of different ones.
