Old 12-02-2019, 02:13 PM   #1
deve
Default 2012 Focus with strange issue (computer related?)
Hi
This has happened a few times over the last month (and twice yesterday). Hoping someone may be able to shed some light.
I started my car yesterday to find that the steering lock took longer to release than usual. This got my attention as the last time this happened the following occurred.
With the engine running, I moved the transmission into R, however the car would not move. (Same with D). Engine was running fine - just the car would not move. Engine would rev when I pressed the accelerator but there was no motion.
I turned the car off. Then when I tried to start the car again, the car would not start / engine would not turnover.
After 5-10 minutes (of the car being switched off) I again tried to start the car. Car started easily and I was able to drive off without any issues.
Took it to a local mechanic soon after it happened. There were a few error reports coming up when he ran his checks, so he cleared all of them. Wasn't sure what the problem was.
And then, (after the computer had been reset by mechanice) the same thing happened last night.
Would appreciate hearing any thoughts on this.
Thanks
Steve
deve is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2019, 02:38 PM   #2
11ford11
Default Re: 2012 Focus with strange issue (computer related?)
What were the codes
Check connections at gearbox
Rescan and write down codes
11ford11 is offline   Reply With Quote Multi-Quote with this Post
Old 12-02-2019, 06:17 PM   #3
marg99
symptons suggest TCM cannot identify which gear the transmission is in. Some times it is because your battery is on way out and voltage drops interfer with signals to TCM/ECU
Old 13-02-2019, 12:12 AM   #4
GTLEGEND
Valued Contributor: For members whose non technical contributions are worthy of recognition. - Issue reason: Every advice post I visit where OP are seeking advice for their new vehicle, he is there and adds valuable support and advice for rectifying the problem. Really is a Legend. Technical Contributor: For members who share their technical expertise. - Issue reason: The quality of information he provides is in depth and highly valued by those posting questions.
Agree with this, both valid points, DTC check will confirm.
GTLEGEND is offline   Reply With Quote Multi-Quote with this Post
Old 01-10-2019, 08:38 PM   #5
stefcio007
When the car starts it takes a while for the battery charging system to kick in I’ve seen (raw data). If your battery voltage drops too low before this happens then the steering remains locked. I have had this happen a few times.
Your battery is on its way out or just needs a charge (stand-alone charger).
2020.25 Focus SA ST-Line Wagon + DAP
2011 Focus LW Trend (Diesel) [sold]
2006 Territory SY Ghia (AWD)
stefcio007 is offline   Reply With Quote Multi-Quote with this Post
