24-06-2020, 05:25 PM | #1 | ||
Ok I ordered these new clips from Ford to replace the missing rocker panel clips on the passenger side but they don't clip ???
Anyone else have the same issue and have a fix for it. https://www.dropbox.com/s/1j61y3yf45...12.21.jpg?dl=0 https://www.dropbox.com/s/fxje4c9jp0...11.57.jpg?dl=0 https://www.dropbox.com/s/ia6z0vsnlo...00.35.jpg?dl=0 https://www.dropbox.com/s/n4kmrcffz9...59.32.jpg?dl=0 I push them in and nothing ????
FORD FG MKII G6 2013
FORD Mondeo Titanium MD Hatch 2015 K&N Air Filter |
24-06-2020, 06:13 PM | #2 | ||
Have a look at the below attached image. You need both the pin clip and nut labelled HM1 and HM2 in the image, part numbers W716503 S300 and W716350 S300 respectively. Do you have them both?
MD Mondeo Rocker Mouldings.pdf |
24-06-2020, 07:18 PM | #3 | |||
24-06-2020, 10:14 PM | #4 | ||
Doesn't the clip secure into nut? i.e. you need to push them into what they call the nut. What was the part number you bought? I think you need them both to work in conjunction with each other.
W716503 S300 : https://www.ebay.com.au/itm/OEM-Genu...EAAOSw7RJeh4k6 W716350 S300: https://www.ebay.com.au/itm/Ford-OEM...frcectupt=true |
24-06-2020, 11:00 PM | #5 | |||
25-06-2020, 09:04 AM | #6 | ||
I wouldn't get them from Ford. We're missing 4 on our MD and I went to spare parts while it was getting the battery harness recall. They stated $10.80 each. For a plastic clip.
25-06-2020, 01:44 PM | #7 | ||
Already got them mate as already stated and no one else has them in Australia good luck buying them from overseas expect them to show up in a few months if ever.
25-06-2020, 04:59 PM | #8 | ||
Have it all fixed now I took it to a panel shop and discovered there was a misalignment and slight damage they fixed it all up and checked the other side for me and for added measure they used Automotive Silastic at key locations to prevent the clips popping out again as they said this is common on the MD's.
25-06-2020, 05:08 PM | #9 | |||
25-06-2020, 05:20 PM | #10 | |||
At least I don't have to go to Bunnings now.
