Old 20-10-2005, 12:16 PM   #1
FADI75
Sponsor
Default Add a Amplifier using Low Level Output on your BA BF or Territory
Forget High-to-Low converters. We offer a Low Level output for your Falcon BA/BF or Territory. Now you can add a amplifier with ease to your existing factory stereo
For more info please go to www.asllogistics.com
Fadi Baddour
ASL Logistics
Ph: +61 3 9588 2755
Fax:+61 3 9588 2855
e-mail: fadi@asllogistics.com
AUTHORISED FORD REPAIR CENTRE
email: info@aslautomedia.com
FADI75 is offline   Reply With Quote Multi-Quote with this Post
Old 01-11-2005, 11:25 AM   #2
cogdoc
Hi Fadi,
Sounds great! So is this a direct RCA out from the factory head, with no signal processing? From what I understand, the factory head sends specific output to both the cabin speakers, and a similar "chopped" via crossover signal to the sub. I'm after one full range L / R RCA out to go into a parametric EQ for distribution to dedicated amps and speakers.
Thanks man!
http://www.carformance.com.au/
cogdoc is offline   Reply With Quote Multi-Quote with this Post
Old 02-11-2005, 12:38 PM   #3
FADI75
Sponsor
Originally Posted by cogdoc
Hi Fadi,
Thanks man!
Yes, this signal is sourced from the unit before it is amplified by the power IC. From there it can be supplied in to power amps. Please be advised the warranty will be void if this modification is undertaken
thanks
fadi75
Old 02-11-2005, 03:23 PM   #4
cogdoc
you've got mail!
Old 25-12-2005, 03:10 AM   #5
XtRmn8
Is this a kit that can be sent to Perth or is it something that needs to be done on-site?
Cheers!
XtRmn8 is offline   Reply With Quote Multi-Quote with this Post
Old 27-12-2005, 11:39 AM   #6
FADI75
Sponsor
hi
yes it has to be done at asl. we have an overnight service so we need the radio module only, we will modify and send back to u the same day we receive it.
cheers
fadi75
Old 28-12-2005, 02:27 PM   #7
XtRmn8
Originally Posted by FADI75
hi
cheers
fadi75
fadi75,
Is the radio mudule easy enough to pull out without doing any damage to the rest of the dash (ICC)??
Do you put female RCA connects as part of this kit, so that I can plug my RCAs in and run them straight to the amp??
Cheers mate,
Goran
Old 28-12-2005, 04:21 PM   #8
FADI75
Sponsor
Originally Posted by XtRmn8
fadi75,
Cheers mate,
Goran
its very simple to remove, if ur not to sure please contact us us after new year and we can tell u exactly what to do over the phone. no damage will occur on ur icc, very basic procedure, and yes we include rca's coming out from radio module and a remote wire as well.
cheers
fadi75
Old 11-02-2006, 02:21 PM   #9
Shermanator2
Fadi,
My main objectives is to build upon the TFT/6 indash upgrade that you did last week ago in order to create a system that is somewhat the same as Factory Fitted Ford Premium Sound (if not better). Now on the "Factory" Fitted Premium sound- how is the amplifer connected to the ICC in the first place? is it not RCAs? How is this the low level output connection upgrade differ from the Factory fitted premium sound setup?
Secondly you mentioned that once this upgrade was done, thier will be no sound emanating unless I provided the amplifer and speakers why is this? I am a bit confused?. I realise I have to provide the amplifer speaker etc but don't the front speakers run directly from the headunit (ICC)? or do they also have to go via the amplifer. Sorry for the multitude of questions I am totaly new to incar audio and setups.
Thirdly their is some conflicting statements on how many speakers the Factory fitted premium sound is supplied with- Just wondering if you know how many speakers Ford actually provide and thier locations?
Thanks
Chaminda
Shermanator2 is offline   Reply With Quote Multi-Quote with this Post
Old 13-02-2006, 08:16 PM   #10
FADI75
Sponsor
Originally Posted by Shermanator2
Fadi,
Thanks
Chaminda
The main amplifier in the BA-BF and Territory's is connected via one plug. No RCA's just connections from the main harness to the AMP and this supplies a Subwoofer only. Our system differs by tapping a pure low-level signal from either 2, 4 or 5 including the Subwoofer into RCA's that can be connected to any amplifier. Not just the supplied factory one. We also tap a 12v trigger wire to power your amp so you don't have to connect your amps to the Acc line.
Once the upgrade has been done to isolate the low-level output we disconnect the output to the power IC's. If we don't do this you are basically halving the output to the amps. We can supply it connected inline but we don't recommend it. If you wish to keep the existing speakers the way they are we can tap a subwoofer output only.
Lastly, from the outputs on the ICC units there are 4 speaker outputs on the base setup and 5 including subwoofer on the premium.
fadi75
Old 14-02-2006, 09:02 PM   #11
Shermanator2
Thanks Fadi
Will be in touch once I pay dad off and then get the amplifer and woofer.
Old 06-05-2006, 01:08 AM   #12
GT-P 390
GT-P 390's Avatar
Hello Fadi
This modification sounds exactly what I'm looking for as I wish to install an Alpine V12 MRV-F450 into my BA GT-P.
Can you tell me the voltage that you are achieving at the RCA's and do you get any noise in the system after completing this mod?
BANKRUPT II - 2007 BFII GT-P Auto, Neo, stock...well at least for the next few days
BANKRUPT I - 2005 BAII GT-P Manual, Velocity, Herrod Extractors and Cats, Xtreme 1300kg Ceramic Clutch and Lightened Flywheel, Bluepower CAI, Herrod Suresix Shifter, John Bowe S/S Signature Series Exhaust, King Springs (Race Series), Bilstein Sport Shocks and 30mm Whiteline adjustable front sway-bay, 3.7 gears.
FPV/Tickford Owners Club of W.A. Member.
GT-P 390 is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 11:23 AM   #13
FADI75
Sponsor
Originally Posted by GT-P 390
Hello Fadi
Hi,
As these are not fixed line level outputs and are controlled via the volume control the voltage at the RCA's varies. We have done lots of these mods and have never had a complaint about noise in the system.
cheers
fadi75
Old 11-05-2006, 10:16 PM   #14
GT-P 390
GT-P 390's Avatar
Hi,
cheers
fadi75
Ok, can you send me some instructions on how to get this thing out and I'll send it over to you.
Old 12-05-2006, 09:10 AM   #15
FADI75
Sponsor
Hi
Please email me directly on fadi@asllogistics.com so i can send u attachment.
fadi75
Old 02-05-2010, 11:22 AM   #16
Gonadman2
Just wondering if you guys have been able to do this to the FG Premium ICC?
Gonadman2 is offline   Reply With Quote Multi-Quote with this Post
Old 02-05-2010, 02:06 PM   #17
FADI75
Sponsor
hi
Sorry, we havent looked at it as yet.
cheers
ASL
Old 04-06-2010, 12:14 PM   #18
jacewraith
jacewraith's Avatar
wow im glad i found this, this upgrade is exactly what im wanting to do to my BA, ive contacted my local super tech and asked for a quote on doing this but they came back with $350.00 wich i thought was a little steep, i have the premium sound so ide be wanting all speakers and the sub connected to amps. could you please p.m me with a quote please, im on the gold coast so ide have to send it to you??
also you mentioned that you only needed the RADIO MODULE ? is this possible to separate from the ICC so as the car can still be driven? or do you require the whole lot?
thanks in advanced
jace
jacewraith is offline   Reply With Quote Multi-Quote with this Post
Old 07-06-2010, 10:15 AM   #19
FADI75
Sponsor
thanks in advanced
jace
jace
$220.00 pls freight back to you. you can seperate the cd module and reconnect the BEM where u can still start your car but we dont advise to drive since you lose some of the functions like speedo central locking etc...
please send it to modify.
cheers
fadi75
Old 01-04-2011, 10:47 AM   #20
xr6ute
xr6ute's Avatar
Default Re: Add a Amplifier using Low Level Output on your BA BF or Territory
Hi mate. i live in NZ and am after this modification, is there anyone over here that can do it?
xr6ute is offline   Reply With Quote Multi-Quote with this Post
Old 04-04-2011, 09:09 AM   #21
FADI75
Sponsor
hi
you can email bala@aslautomedia.com he is in NZ at ASL where he can assist you.
cheers
fadi75
Old 04-04-2011, 09:13 AM   #22
xr6ute
xr6ute's Avatar
I rang him on friday and he didnt really seem to know about it. I have decided to buy a High/Low convertor for now. Myt email him today and see what he says again. Cheers!
Old 04-04-2011, 12:44 PM   #23
FADI75
Sponsor
hi
email me directly and we will contact him. fadi@aslautomedia.com
cheers
fadi75
Old 13-07-2011, 10:10 PM   #24
Jocool
hi
cheers
ASL
Have you looked at this for the FG at all?
Cheers.
Jocool is offline   Reply With Quote Multi-Quote with this Post
Old 14-07-2011, 08:53 AM   #25
FADI75
Sponsor
Cheers.
hi
we are working on one but we still having some issues, not sure on release time as yet
cheers
ASL
Old 15-07-2011, 12:22 AM   #26
Jocool
Thanks for getting back to us. I would certainly be interested in any and all developments on that front.
Cheers.
Old 06-08-2011, 04:53 PM   #27
Jocool
Any news Fadi?
Old 08-08-2011, 08:48 AM   #28
FADI75
Sponsor
hi
you can contact ASL in NZ ask for Bala
cheers
ASL
