Old 05-02-2005, 06:53 PM   #1
russellw
Chairman & Administrator
russellw's Avatar
Community Builder: In recognition of those who have helped build the AFF community. - Issue reason: Raptor: For Continued, and prolonged service to the wider Ford Community
Default New Tech Article - AU Wiring Diagrams **UPDATED**
Thought we'd give this a try and see if it's of any use.
I've started the series with the Exterior Lighting Diagrams - let me know if they are of any use and what other ones you'd like to see posted.
The second and third sets are up as well in the test area they are for the Instrument Cluster and the Courtesy Light Wiring.
They are fairly large in order to show enough detail.
Russ
__________________________________________________
Observatio Facta Rotae
russellw is offline   Reply With Quote Multi-Quote with this Post
Old 05-02-2005, 06:59 PM   #2
RED_EL_XR8
RED_EL_XR8's Avatar
Russ
they come up fine Russ, detail is good!! please dont stop there.
RED_EL_XR8 is offline   Reply With Quote Multi-Quote with this Post
Old 06-02-2005, 12:59 AM   #3
JC
JC's Avatar
Russ, any chance of getting the ESS wiring diagram from the AU series 1 T series cars. I have been thinking about changing my Vol +/- buttons to do this, but have no idea where the wires should go!
Mods: Tune, ShockWorks, GTE 19” - 8” & 9” with 245 & 275/35/19 Michelin Pilot sport 5s
Daily: SZ Territory RWD 6R80, 20 x 8.5” rims 19” with 245s and Gabriel shocks & SSL King springs
Ford Performance Club ACT
Old 06-02-2005, 04:29 PM   #4
russellw
russellw's Avatar
Try either THIS or THIS and see if it's of any help.
Russ
Old 06-02-2005, 04:33 PM   #5
Casper
Contributing Member
Casper's Avatar
Fantastic info Russ, lets just hope its used for good (nice interior effects) rather than evil (NEONS!)
Really appreciate all this info Russ, its fantastic.
Older, wiser, poorer.
Old 06-02-2005, 05:02 PM   #6
b2tf
not here much anymore
b2tf's Avatar
Yeah thanks for these Russ, saves me some searching.
2024 F150 XLT
Old 07-02-2005, 12:09 AM   #7
JC
JC's Avatar
Thanks Russ - I'll give it a go.
I'll let you all know when I blow up my gearbox!
Old 07-02-2005, 10:59 AM   #8
russellw
russellw's Avatar
This may also help:
ESS wiring circuit
Changes to the wiring to accommodate ESS is in two parts. These are:
1. Wires and a resistor contained within the steering wheel to connect the shift button switches to the clockspring (former radio switch circuits).
2. A new harness runs from 4 pin plug at steering column to the PCM via the Mode switch. This circuit contains three resistors, two are cable tied to
the loom behind the glovebox. These can only physically fit one way, otherwise the transmission won’t shift. The 8k ohm is located behind the driver’s air bag.
PCM PIN FUNCTION
ESS switching input
The function of PCM pin 11 has changed from being the Power/Economy switch input to become the ESS switching input. Pin 91, is Signal Return.
Circuit operation
V Ref (5v) is applied internally within the PCM to pin 11, through a current limiting resistor. A signal voltage will be created by the external circuit depending on the status of the individual switches. There are four different voltage conditions that the PCM will recognise as a particular shift or mode request. (These are shown in the diagram posted).
Russ
Old 07-02-2005, 11:04 AM   #9
EFFalcon
Last warning
EFFalcon's Avatar
fantastic addition
I know that if i didnt have these diagrams in the workshop manual it would make life hard :P
EL GT - Supercharged
OFFROADER - Ford Explorer
Old 12-02-2005, 01:48 PM   #10
russellw
russellw's Avatar
Updated to include:
Fuel Systems
Power Doors / Windows / Mirrors / Seats
Russ
Old 17-04-2005, 10:30 PM   #11
FRD888
LEDFUT
FRD888's Avatar
Default Au xr8 series 1 Low Beam problem
Firstly, found the wiring diagrams and locations idea a help in this issue I have. My problem is that the RHS headlight will not work in Low Beam. It works fine with the parkers on and high beam but no low beam. The LHS works fine so wherever the CCT breaks off from the Relay to the RHS headlight is the problem. I tried chasing back the loom as far as I could and found on the lightblub there is a brown lead (perhaps power) and two black leads (perhaps earths switching in and out depnding on high low beam). Is there an accessible way to test the low beam wiring and I am capable with a multimeter.
Any help would be much appreciated as Ive basically sussed the problem I just am not sure which wire is which and how to get access to them.
FRD888 is offline   Reply With Quote Multi-Quote with this Post
Old 16-05-2005, 02:18 PM   #12
bubbagump308
FALCON HELL!!!
Default AU Series II XL Ute, STEREO Wiring
Hey there i was wondering if anyone knows the wiring colour codes for the plug in the back of the stereo for the CD/Cassette/AM/FM for the AU II Falcon XL ute? I am just trying to faultfind the problem with CD player on the bench but i cant find the ignition circuit on the plug. Maybe just me but would help heaps if there was a diagram to go by. :
bubbagump308 is offline   Reply With Quote Multi-Quote with this Post
Old 27-06-2005, 02:04 AM   #13
JC
JC's Avatar
Ignition (power) is red & dk blue. Memory wire is the big fat yellow one.
Oops - response is only a month late.
Old 07-07-2005, 08:20 PM   #14
smee
FishermanDan
smee's Avatar
Default fuel tank sender
NF 9K160 A SENSOR FUEL TANK, FAIRMONT/FAIRLANE/GHIA/LTD $19.04
is this right part/price ? for a EF fuel tank sender ?
I rang ford about a month ago and they want $180 !
edit: it is a sedan!
smee is offline   Reply With Quote Multi-Quote with this Post
Old 07-07-2005, 09:41 PM   #15
russellw
russellw's Avatar
EL 9275 A SENDER UNIT, (-)4 DOOR WAGON - $ 147 is the correct item - for some reason the whole Fuel section isn't loaded for EWF-EL but they are carry over parts to AU anyway. As that's a trade price listed above (as explained elsewhere) the $180 is about right.
Russ
Old 28-07-2005, 12:11 AM   #16
oxhatha
just need to no wiring colour codes for au series 1 xls ute radio
Old 28-07-2005, 12:35 PM   #17
russellw
russellw's Avatar
Accessory feed is Violet/Red
Battery +ve is Yellow
Ground is Black
See this diagram HERE
Russ
Old 28-07-2005, 12:42 PM   #18
dansedgli
dansedgli's Avatar
Thats great work Russ, I cant seem to find the tacho wire for an AU1 XR though? The instrument cluster one doesnt show it. Any ideas?
Turbo AU ute ~ Nice legs, shame about the face. 282rwkw at 15psi.
dansedgli is offline   Reply With Quote Multi-Quote with this Post
Old 01-09-2005, 09:23 PM   #19
fairmontfan
Cool
does anyone know the colour codes or have the wiring diagram for the mobile phone wiring in a au ford fairmont 2000
fairmontfan is offline   Reply With Quote Multi-Quote with this Post
Old 02-09-2005, 11:59 PM   #20
russellw
russellw's Avatar
The AU Wiring Diagram for the phone is HERE.
The locations are HERE.
Russ
Old 05-09-2005, 04:37 PM   #21
xalent
Red Eye Racing
xalent's Avatar
I'm looking for wiring diagram for an AU XR8 engine and ecu. Any other tech info would be appreciated. Am transplanting the XR8 motor into a F350.
Can anyone help??
xalent is offline   Reply With Quote Multi-Quote with this Post
Old 05-09-2005, 06:54 PM   #22
russellw
russellw's Avatar
Can anyone help??
Have a look HERE - images 06C and 06D should provide some basic info. Let me know what else you need and I'll see what I have.
Russ
Old 06-09-2005, 06:18 PM   #23
fairmontfan
thanks for that Russ.
Old 07-09-2005, 10:40 AM   #24
xalent
Red Eye Racing
xalent's Avatar
Thanks Russ.
With that and your EEC-V section, reckon it shouldn't be too hard though I don't quite know how to go about bypassing the Engine Enable Input from the security side of the Body Module. Any ideas? Otherwise might have to go to aftermarket computer though would rather stay with original.
Greg
Old 07-09-2005, 07:42 PM   #25
russellw
russellw's Avatar
I can't see a lot of options except to use a coded Smartlock key and a BEM with the key programmed to it.
To quote:
KEYPADS
The keypad is a small radio transmitter that transmits to the BEM a unique rolling code; along with a lock or unlock code for the doors or boot a panic feature is also incorporated. The new key for a sedan has four buttons.
These are Lock, Unlock, Boot/tailgate and Panic. The keypad for the commercial vehicle has 3 buttons; the boot tailgate button is deleted. The buttons are colour coded for easy identification.
Up to 4 keypads may be programmed to the BEM. If additional keypads are to be programmed by your dealer, it is essential that all keypads are available for reprogramming as all codes are cancelled and reprogrammed by the learning process. It should be noted that the BEM will only respond to the keypad when the ignition is turned off.
The Smartshield system uses a specially encoded ignition key. Each ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code. This code is used by the immobilisation system to validate the key and start the engine. The transponder ignition key must be programmed into a vehicle's Body Electronics Module (BEM) before it can be used to start the vehicle.
Smartshield BEMs each contain a unique electronic identification code. The BEM code must be programmed into the transponder ignition keys before the vehicle can be started. The BEM also shares security data with the Powertrain Control Module (PCM) and must have learnt the PCM code before the vehicle can be started.
Smartshield PCMs each contain a unique electronic identification code. The PCM code must be programmed to the BEM before the vehicle can be started. The PCM challenges the BEM with a randomly generated code. The BEM then verifies that a valid Transponder Ignition key is present. The BEM then responds to the PCM, which allows the vehicle to start and run.
Russ
Old 08-09-2005, 12:52 PM   #26
xalent
Red Eye Racing
xalent's Avatar
Yeah probably would be easier to try and incorporate the BEM into the transplant.
Do you have any wiring diagrams for the BEM? And also any cable colour schedules?
Thanks mate
Greg
Old 08-09-2005, 09:40 PM   #27
russellw
russellw's Avatar
I'll dig them up and post them over the weekend.
Russ
Old 08-09-2005, 10:18 PM   #28
xalent
Red Eye Racing
xalent's Avatar
Thanks
You're a champ!
Old 09-09-2005, 11:39 PM   #29
russellw
russellw's Avatar
The BEM diagrams are now available HERE
Russ
Old 08-10-2005, 08:36 PM   #30
RBAKER
Default fuel gauge circuit
help! the fuel gauge system looks simple, but it involves components;
interface computer and instrument drivers (located on instrument
cluster panel) and possibly a link to the EEC; a diagram may assist to
understand and solve probs
