Old 09-05-2006, 07:02 PM   #1
EB Pete
EB Pete's Avatar
Location: Under the bonnet, trying to keep as clean as above!
Default timing chain tensioner filter?
hi all. well today i bought a new timing chain set with all the gaskets and was just looking for other things i need and i noticed something. i am pretty sure the chain tensioner is supposed to have a filter in with it with 3 O rings either side? well heres a pic of mine that came straight out of the timing cover.
i'm guessing someone has worked on it before i had the car. should i get one and put it in or is it not really needed?
one more thing. is there any way to test that the regulator valve that supplies oil to the tensioner is working with the engine dismanteled?
EB Pete is offline   Reply With Quote Multi-Quote with this Post
Old 09-05-2006, 07:07 PM   #2
John_LS1
yep the filter goes on the end of the first peice pictured. has 1 O ring on either side. unless its still stuck in the second peice?
Old 09-05-2006, 07:11 PM   #3
EB Pete
EB Pete's Avatar
and is there supposed to be an O ring between the retainer (second thing in pic) and the timing cover?
anyone no about the regulator valve?
Old 09-05-2006, 07:15 PM   #4
John_LS1
yeah should be some sort of washer/Oring. when i put mine back on i used a O ring and some 3 bond gasket maker.
Old 10-05-2006, 08:13 PM   #5
EB Pete
EB Pete's Avatar
no one know anything bout the regulator in the block?
Old 12-05-2006, 07:10 PM   #6
EB Pete
EB Pete's Avatar
well i can't find a filter anywhere. so i'm not sure what i'm going to do. might just turn me back on it, and hope it's all good.
Old 12-05-2006, 07:18 PM   #7
EDXR6T
sorry to hijack but...
what's the recomended tourk for the nut. or is it just till it's firm/tight
EDXR6T is offline   Reply With Quote Multi-Quote with this Post
Old 12-05-2006, 10:10 PM   #8
EB Pete
EB Pete's Avatar
no it's right. don't think anyone knows anyway. the retainer (second from left) is 15Nm, retainer plug (1st from left) 10Nm. hope that helps
Old 24-08-2022, 03:09 PM   #9
Scottsdot
Default Re: timing chain tensioner filter?
2022 an update. Just spoke to ford. This filter is NLA, NO LONGER AVAILABLE. Trying to find workaround as mine broke as i tried to get orings off.
Scottsdot is offline   Reply With Quote Multi-Quote with this Post
Old 06-09-2022, 07:55 PM   #10
D.W
I've probably got a good second hand one kicking around in my junk somewhere. Not sure if that's any help?
D.W is offline   Reply With Quote Multi-Quote with this Post
