Old 13-06-2006, 11:15 PM   #1
$90esky
Hiding in wheel smoke
Default hi beams
hey all i just bought a 4 door mkII escort 2L from the original owner with 66000 km's on the clock for 90 bucks. I need to get it licensed and was wondering whether they actually came with hibeams because there is no swwitch for them and doesn't look like the reflector changes at all. If they didn't come with hibeams does that mean I don't need to have them?
Thanks for any help
$90esky is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2006, 11:38 PM   #2
mk2_1979_escort
Congrats,
Yes all Mk2 escorts came with high beams, simply push the left hand stalk (indicator stick on the LEFT) away from you once your park lights are on, if all wiring is in tact a blue light should light up on your dash. PM if you need more help.
mk2_1979_escort is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2006, 11:39 PM   #3
white lightning
white lightning's Avatar
What he said!
white lightning is offline   Reply With Quote Multi-Quote with this Post
Old 13-06-2006, 11:51 PM   #4
$90esky
thanks heaps, I didn't know where the hibeam switch was, but unfortunately they don't work but the blue light comes up on dash so something does exist there lol. I'll get on to it tomorrow (if i finish work before 6pm).
Old 13-06-2006, 11:52 PM   #5
$90esky
Also quickly has anyone rigged up a return device for the indicator switch, and if so how did you do it?
Old 14-06-2006, 01:15 PM   #6
T3man
T3man's Avatar
The indicator has a return cam - it is at the back of the steering wheel. It is common for them to break the small tab that locks into the back side of the wheel boss. You can repair it by drilling a very small hole and fitting a small metal thread - then cut the thread head off, leaving the thread end protruding about 3-5mm.
OR if an aftermarket steering wheel has been fitted then usually they don't have the hole drilled in the back of the boss for the little tab to fit into.
There are separate fuses for low and high beam - the fuse box is on the passenger side firewall in the engine compartment. It is very common for the ends to corrode - old Euro style fuses.
PS I never liked the indicator on the left on my Eskies so I always swap the multi-function stalks side to side - lights and wipers on left, indicator on right.
Old 14-06-2006, 01:58 PM   #7
whooligan
whooligan's Avatar
How do you do that without them being upside down?
I actually prefer the indicator on the left hand side. When you do a left hand turn you can switch them off with your knee as you take it off the clutch....I'm still trying to figure out right hand turns. :
whooligan is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 06:19 PM   #8
T3man
T3man's Avatar
Use your other knee??? LOL.
It makes no difference to the indicator stalk which side it is on - it will work correctly on either side.
And to me it makes more sense to push the light switch down to turn the lights on - same for the wipers. Try it and see if you like it for yourself ... if you don't it's easy enough put back to standard.
BTW the reason I first did this back in 1975 was when I was using my Esky as a driving school car. Learners (and even experienced drivers) would be forever turning on the wipers instead of the indicators LOL. On my current Esky it's so the wife isn't forever turning the wipers on instead of the indicators
Old 14-06-2006, 06:36 PM   #9
Matt89
man thats a mad buy does she have rust.
Matt89 is offline   Reply With Quote Multi-Quote with this Post
Old 14-06-2006, 10:59 PM   #10
$90esky
only a small amount of rust in the front door pillars and thats all
Old 15-06-2006, 02:15 PM   #11
crispymk2
crispymk2's Avatar
I fixed my indicator cam with a zip tie to make the lump the right size... man those things can fix anything
Try an Escort "expert" cause Tony at ERR just gave me an entire box full of broken ones that I used to pull apart and make a good one free
GGR | SCT | Tein | Samco | Whiteline | Mongoose | Forge
crispymk2 is offline   Reply With Quote Multi-Quote with this Post
