Old 30-06-2006, 11:26 AM   #1
xbgs351
Default The Aussie Cossie - Waggot DOHC
xbgs351 is offline   Reply With Quote Multi-Quote with this Post
Old 30-06-2006, 11:29 AM   #2
GreenMachine
Mopar/No Car
GreenMachine's Avatar
Tech Writer: Recognition for the technical writers of AFF - Issue reason: Sensational write up about drum brakes.
Amazing stuff - aussie aussie aussie!
Waggot were also known for the twin-cam conversions for the Holden grey motor - something like 220hp from a twin carb 161ci 6cyl...
ColumnShift Media
'72 Plymouth Scamp
'80 Courier
'13 Kawasaki ZX14-R
'13 Berlina
'92 Suzuki DR650
If you don't fight - You lose
GreenMachine is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2006, 09:41 PM   #3
xbgs351
One reply to this post - that's pretty **** weak, considering the motor was an Australian alternative to the Cosworth FVA. The renowned Cosworth DFV was basically a merging of two FVA's.
Old 01-07-2006, 09:48 PM   #4
Gammaboy
Grinder+Welder = Race car
Gammaboy's Avatar
Steady! I didn't see it before :P
Interesting motor, I knew Waggot did some fairly special Holden 6 heads, but never heard of the F2 beasty. Any idea why it didn't take off?
Looks alot like the MX5 1600 externally.
Lovely bundle of Bananas exhaust
"No, it will never have enough power until I can spin the wheels at the end of the straightaway in high gear"
- Too much power is never enough....Mark Donohue on the Can Am Porsche 917.
Gammaboy is offline   Reply With Quote Multi-Quote with this Post
Old 01-07-2006, 11:16 PM   #5
xbgs351
It's understanding that you hadn't seen it as it had slipped all the way down to around page 4!
The engine won three Australian Formula Two (AF2) championships. I believe CAMS rule changes spelled the death of the engine. AF2 rules changed in the 70's to production based 1.6 litre, single cam, 2 valve per cylinder engines and I don't think the engine was eligible for F5000.
I have read that the Waggot DOHC/4 motors were pumping out 247 horsepower, which is pretty damn good for a 2 litre motor in 60's. (If a Cleveland was putting out the same hp/litre you would be looking at around 716 horsepower) Put the Waggot engine in a car with a total weight of around 400kg plus driver and you are looking at one fast ride.
To get an idea of Formula Two cars were like, have a look at these videos of some historic race meets in Europe.
http://www.qv500.com/racecam/video/spa.mpg
http://www.qv500.com/racecam/video/pau.mpg
Old 02-07-2006, 12:50 AM   #6
XplosiveR6
Viper FG XR6 Turbo
XplosiveR6's Avatar
Its funny how the ricers think that DOHC engines are "high-tech" and modern, when these motors where being produced back in the 60's.
XplosiveR6 is offline   Reply With Quote Multi-Quote with this Post
Old 02-07-2006, 01:13 AM   #7
Walkinshaw
Two > One
Walkinshaw's Avatar
respect
Old 02-07-2006, 01:27 AM   #8
ebxr8240
Performance moderator
ebxr8240's Avatar
All copies off this motor...
http://www.wilcoxengines.demon.co.uk/bda.htm
The Toyota 1600 4AGE is dead set copy..
It took the Yanks and Poms along time before they fitted this style of motor in your average car...
Daily driver GTE FG..
Old 02-07-2006, 12:36 PM   #9
xbgs351
Have a look at the date of the article. It's October 1968. The Cosworth BDA didn't come about to 1969.
Old 02-07-2006, 12:45 PM   #10
xbgs351
Ernest Henry conceived the first double overhead cam, 4 valve per cylinder engine for Peugot way back in 1912.
